Catalytic converter rattle ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sness, Aug 11, 2013.
  1. Aug 11, 2013 at 10:28 AM
    sness
    sness [OP] Member
    MO
    06 Access Cab SR5 4wd 4cyl 5spd man
    Picked up a hell of a rattle, shows up most at fast idle at start up then goes away after idle drops. I can simulate most of the time by just idling it up. Had wife do it while I checked and sounds like to me the inside of the converter is rattling. Any thoughts ?
  2. Aug 11, 2013 at 10:52 AM
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    There is a crappy clamp Toyota uses on the left side cat. Many times they break, but they don't fall off. They just vibrate towards the rear of the truck. Follow you left pipe backwards until it bends towards the right. That is where I found mine. I overlooked it twice because it had rusted and blended in with the piping. My money is on that.
    Even though the clamp is missing from the back of the cat, my cat doesn't rattle, but perhaps yours is. See the below thread for a picture of the clamp I'm referring to.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/284494-rattleing-buzzing-sound-under-truck.html
    DrFunker and Chilly like this.
  3. Aug 17, 2013 at 3:00 PM
    sness
    sness [OP] Member
    MO
    First pic is heat shield I took off. Question, is it the catalytic converter shield and if that's the catalytic converter(2nd pic round object) what's the little muffler looking thing behind it without a shield ? And can I go without this shield I just removed ?
  4. Aug 17, 2013 at 3:03 PM
    drunktaco
    drunktaco Well-Known Member
    Sage
    Southwest Va
    Icon ext travel C/O's, Total Chaos UCA's, King R/R shocks, All-Pro leaf pack, lights, RCI skid, Brute Force sliders, ect.
    That round thing is your other cat I believe. You have 4. And it's cool to run without them. I don't think they do much anyways
  5. Aug 17, 2013 at 3:06 PM
    sness
    sness [OP] Member
    MO
    4 converters ? I just have single exhaust 4 banger
  6. Aug 17, 2013 at 3:09 PM
    drunktaco
    Sage
    Southwest Va
    Oops my bad, you only have 2 then I believe. Ill let someone with more 4 banger knowledge step in and correct me if I'm wrong here. I'm not sure if you have a resonator on your exhaust or not. If its not another cat, that's probably what it is. Does it have any wires/sensors running to it?
  7. Aug 17, 2013 at 3:12 PM
    sness
    sness [OP] Member
    MO
    Think oxy sensors is right in front of it, lol. Just climbed out from under it 20 mins ago and can't remember, fkn suks getting old
  8. Aug 17, 2013 at 3:15 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    You and I have four, there are two waaay up in there that you can see if you crawl under.
  9. Aug 17, 2013 at 3:16 PM
    drunktaco
    Sage
    Southwest Va
    If there's one in front and behind it, it's probably another cat
  10. Aug 17, 2013 at 3:16 PM
    drunktaco
    Sage
    Southwest Va
    He's got a 4 cylinder
  11. Aug 17, 2013 at 3:17 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Beat on it with your fist and see if it rattles if it does it's inside the shields are to avoid setting the grass on fire under the truck.
  12. Aug 17, 2013 at 3:23 PM
    sness
    sness [OP] Member
    MO
    I just wanted to make sure it wouldn't hurt the floor pan leaving the shield off. I may end up putting it back on, I've been know to wade some weeds in it getting to a fishing hole. I'm just glad I got rid of that damn rattle !!
  13. Aug 17, 2013 at 3:40 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    You may.
    There is a shield on the floor pan, but it was designed to protect against a shielded cat. Keep a close eye on floor temperatures, you don't want to melt your carpet.
    My dad had a '74 Blazer and when he installed headers, there was enough heat from the collectors to melt the soles of my Chukkas. He fabbed a shield and added glass under the carpet.
  14. Aug 17, 2013 at 3:43 PM
    rogerkamp8817
    rogerkamp8817 Well-Known Member
    Orange County, California
    2010 Toyota TRD Off-Road 4x4, AC, Superwhite
    my truck rattled for a long time until i found out the noise was from the cat as well. i went to the car wash and put the head of the pressure washer into an opening in the heat shield without taking anything apart. the pressure of the water blew out chunks of dirt and rocks and the noise was gone.
  15. Aug 17, 2013 at 6:15 PM
    sness
    sness [OP] Member
    MO
    That would have been to easy and I wouldn't have got to roll around on my back grinding the head of the bolts off.
  16. Sep 9, 2018 at 11:28 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
