Catalytic Converter Cleaning
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sustequa, Feb 5, 2024.
  1. Feb 5, 2024 at 2:01 PM
    Sustequa
    Sustequa [OP] Well-Known Member
    2017 Red Tacoma TRD Sport
    Hey guys, I drive a 2017 TRD Sport 4x4 and I took my truck to the dealer for a quick diagnosis on a separate issue, but in the inspection, he mentioned it sounded like there was some debris inside the catalytic converter, which would make sense since I just had the dirtiest offroading trip I've ever taken. I tried doing some simple Google searches to remove it, but I can only find videos where people have cut them off. Does anyone know how to remove and clean one of these things?
  2. Feb 5, 2024 at 2:06 PM
    50Buck
    50Buck Living rent free Timmy the Tool's head
    They don't get debris from off roading unless you had mud flowing up your tailpipe.
    They are welded into the exhaust system. You don't remove them for "cleaning" or anything else.
    Vmax540, rtilton12, WallyIAm and 6 others like this.
  3. Feb 5, 2024 at 2:06 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    How can there be debris in the catalytic converter?
    It would have to get sucked in through the intake.
    rtilton12, b_r_o, RIX TUX and 2 others like this.
  4. Feb 5, 2024 at 2:07 PM
    Sustequa
    So, funny story. Definitely had muddy water flowing back through the exhaust
    Malvolio likes this.
  5. Feb 5, 2024 at 2:11 PM
    Sustequa
    I learned a lesson really fast about checking water depth before driving through it. Intake did not go under, but the tailpipe was submerged until the tow got there
  6. Feb 5, 2024 at 2:25 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I’ve never heard any stories of debris getting into a catalytic converter due to the exhaust system being submerged in water.
    I have however had a catalytic converter break down from old age and have loose stuff rattling around in it. It was quite a bit older than your 2017 though.
    In any case, I wouldn’t worry about it, unless you sense issues while driving the truck.
    gen2eng, Chew, Wulf and 3 others like this.
  7. Feb 5, 2024 at 2:29 PM
    Sustequa
    That puts my mind at ease. Thanks for the replies. I just fixed her back up from all the stuff I broke so I guess I'm just maintenance happy
  8. Feb 5, 2024 at 2:40 PM
    50Buck
    If it's sitting submerged and not running you could have it fill the exhaust. Generally an unlikely scenario, though.
    OP if it was submerged for a time you may want to check your rear diff, unless you have a breather relocation kit already.
    Chew likes this.
  9. Feb 5, 2024 at 2:44 PM
    Sustequa
    I don't have a breather relocation kit, but after this last trip, I'm getting one in a week. I spotted and smelled a leak in the front diff so I replaced the axle seal and flushed/refilled the front diff, checked the rear and refilled it, and also had to replace the starter but after all that, seems like it's running fine with no leaks. The breathers are not clogged but if I plan to do more offroading, and I do, I'm getting a relocation kit.
  10. Feb 5, 2024 at 2:44 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Was the dealer saying that they could clean it?
    RIX TUX and Chew like this.
  11. Feb 5, 2024 at 2:46 PM
    Sustequa
    Nah they just remarked about it. I went in to get my airbag light looked at because it stayed on. There weren't any trouble codes and it shut off as I left the dealer.
  12. Feb 5, 2024 at 2:47 PM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    You do not get debris in there from off-roading... :bananadead:
    (Sometimes the ceramic can break (in case of impact, sometimes due to age or defects) and then you do have some rattling in there. You don't necessarily clean that out...
    If you had mud up there - coming from your tailpipe, you no longer have a taco...
    I was going to make a joke... but then I found this:
    (and I'm not promoting this - I'm not sure that is is not a gag!)
    Malvolio, Chew and doublethebass like this.
  13. Feb 5, 2024 at 2:49 PM
    Sustequa
    haha thanks for the info, I'll probably just forget about it at this point, it doesn't sound like it's a major issue and there's no emissions testing in my state
  14. Feb 5, 2024 at 2:56 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    A sound of debris bouncing about in the converter normally means some of the honeycomb material has broken loose.
    Are there any dents in the converter from your recent off-road excursion?
    balljoint, skidooboy and Chew like this.
  15. Feb 5, 2024 at 2:57 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    might be something stuck between the cat and the heat shield
    Chew likes this.
  16. Feb 5, 2024 at 2:58 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    Is it Friday :bananadead::crazy::facepalm:
    RIX TUX and ace_10 like this.
  17. Feb 5, 2024 at 3:01 PM
    Sustequa
    Nope, it was mostly mud and the sort that I was driving through, I was hoping to find some clay or something to climb but our trip was cut short haha
  18. Feb 5, 2024 at 3:04 PM
    ace_10
    ace_10 Well-Known Member
    Rural NoVA
    1st Gen, Best Gen X2
    OP, does your engine breathe (inhale) through its tailpipe?
    RIX TUX and TomTwo like this.
  19. Feb 5, 2024 at 3:09 PM
    Clearwater Bill
    Billy
    Largo Florida
    Malvolio, RIX TUX and doublethebass like this.
  20. Feb 5, 2024 at 3:24 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    it cant get over the axle bend and past the muffler, the exhaust would blow it out, the insides of the convertor are prob broken
    not a charger likes this.
