Castrol EDGE 5W-30 Full Synthetic Motor Oil, 5 qt
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Asdfghjkl123, Jul 30, 2017.
  1. Jul 30, 2017 at 1:02 AM
    Asdfghjkl123
    Asdfghjkl123 [OP] 2010tacomadoublecabv6
    california
    2010 Tacoma double cab v6 sr5
    Oem
    Just curious does anyone else use this oil? I am thinking about using oem filters along with this oil from now, I wonder if oem oil filters will have any benefits on my truck.
  2. Jul 30, 2017 at 1:25 AM
    PapaBear
    PapaBear Never test how deep the water is with both feet.
    Austin
    SIN CITY
    07 DCSB PR 4.0... Aaaand she’s GONE
    Soft Suspension Hard Rubber ®
    I do not use Castrol but let me just give you the spiel others may give you. Mobil 1 FS 5w-30 and Toyota filters are great. If you have the money and want the best in the business, Amsoil FS 5w-30 and Toyota filter, Period. If you prefer Castrol, no one will judge you. It's your truck and you do as you please, I'm just giving you my 2 cents since you asked :thumbsup:
  3. Jul 30, 2017 at 1:45 AM
    Asdfghjkl123
    california
    Oem
    @PapaBear you got a v6 correct? do you use 5 quarts or 5.5 quarts and thanks for your opinion as well. I will take that into consideration
    PapaBear likes this.
  4. Jul 30, 2017 at 1:48 AM
    PapaBear
    Austin
    SIN CITY
    I do have the 4.0 1GR. I believe it is somewhere in between 5.4 and 5.6 quarts if I'm correct. Don't quote me though, I know it's below 6 quarts. The reason I usually like to stick with Mobil 1 is because for $37, I get a box of 6 quarts FS at Costco. I could buy Toyota filters in bulk but I usually just buy 1 at a time right from my dealer.
  5. Jul 30, 2017 at 3:32 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Any synthetic oil will be good along with toyota filters. If you extend your drain intervals get a oil analysis done to be sure it can handle it.
    TRDSport10 and Rambo54 like this.
  6. Jul 30, 2017 at 3:52 AM
    lawrenccar1
    lawrenccar1 Well-Known Member
    Springfield, Virginia
    2015 4x4 DCSB TRD Off-Road
    i just used it a couple weeks ago (first time synthetic now that free oil changes are gone) along with toyota filter.
    Asdfghjkl123[OP] and Rambo54 like this.
  7. Jul 30, 2017 at 11:25 PM
    Asdfghjkl123
    california
    Oem
    @lawrenccar1 any noticeable difference with your trucks performances??? Also which filter do you use?
  8. Jul 31, 2017 at 6:22 PM
    studunk1
    studunk1 Well-Known Member
    stu
    jeff city, MO
    13 Access Cab sr5
    running boards, bug deflector, window deflectors, tail gate liner, bed mat
    Have not used Castrol synthetic, but the regular Castroll since 1979, exclusively.....hundreds of thousands miles, never had an oil problem. It was used for racing engins...John Force, and daughter use it in their dragsters. Would be my choice if I switched to synthetic.
  9. Jul 31, 2017 at 8:24 PM
    Silver2015
    Silver2015 New Member
    2015 Tacoma SR5
    Just curious about synthetic oil. It's my understanding that we are to "only" use conventional oil as I don't believe Toyota recommends it for the Gen 2. Or at least that is my understanding for my 2015 prerunner.
  10. Jul 31, 2017 at 8:47 PM
    80schild
    80schild Well-Known Member
    Chad
    Flori-Bama
    2007 TRD Sport Access Cab
    No. The only reason Toyota requires synthetic for the 3rd gen is because it calls for 0w-20, and it's mostly so they can reach the fuel economy standards (0w-20 is only available in synthetic).
    It's perfectly fine to use synthetic 5w-30 in the 2nd gen.
    TRDSport10 likes this.
  11. Jul 31, 2017 at 9:48 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Castrol is good stuff. Many people claim that their engines run noticeably quieter on it versus any other motor oil.
  12. Aug 1, 2017 at 4:00 AM
    lawrenccar1
    no difference noticed, used toyota fiter
  13. Aug 1, 2017 at 5:08 AM
    TacoMeSir
    TacoMeSir WiFi Guru
    Tim
    North GA
    2024 TRD Off-Road Hybrid Premium
    Stock
    Castrol Edge (TWS) 10w-60 is the OEM Fill for my 2011 BMW M3. This stuff is much better than most think. When I changed out my Rod Bearings in my S65 V8 that is in my M3 they where surprisingly in good shape. I was very skeptical of this oil as I'm an Amsoil guy and run it in my Taco religiously with an Amsoil filter. I say go for it if it's a good deal and your gut feeling is a good one. Mobil is always a good choice also. I prefer Amsoil in my Toyota's.
