Carrier bearing seems to be squeaking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by reppinthe509, Apr 16, 2018.
  1. Apr 16, 2018 at 5:59 PM
    reppinthe509
    reppinthe509 [OP] Well-Known Member
    Washington
    07 Tacoma TRD Offroad
    I took my truck in today for the u joint warranty enhancement. I'm getting a squeaking noise and after them having it for 3 hours they said it was ready. Nothing wrong with the u joints. So I got in to leave and put it in reverse still squeaking.
    Went back in and had a tech come listen to it. First he said it was the rear brake drums (it wasn't).
    Then he said it was the heat shield rubbing on the drive line (it wasn't).
    Then he crawled under and found it to be the carrier bearing. He said that that wouldn't be covered under the warranty enhancement and that I'd have to replace the whole driveline.
    Does anyone know if this is actually covered?
    Do a the whole driveline actually need replaced?
    wilcam47 likes this.
  2. Apr 16, 2018 at 6:18 PM
    gmc8
    gmc8 Well-Known Member
    Gary
    Smoky Mountains
    I don't know if it's covered but you damn sure don't need an entirely new drive line. From what you listed above, I'd be looking for another dealer.
    kimo, outlawtacoma and wilcam47 like this.
  3. Apr 16, 2018 at 6:21 PM
    Tacomalx4x4
    Tacomalx4x4 Well-Known Member
    Corey
    Wv
    07 6spd DCSB silver
    3inch ultimate, straight exhaust, XD's 285's, grill, lights, fog mod, jvc unit. Rear cam mod, pioneer 3ways
    I just replaced mine on 07, carrier was squeaking too. You have to drop the front part of shaft but all you need is the carrier bearing. Bout $170. And no it’s not covered under warranty.
    kimo likes this.
  4. Apr 16, 2018 at 6:29 PM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Squeak in reverse is most likely ujoint. Never heard of that as symptom of worn middle bearing. That'll screech and/or clunk.
    Tech proved he is either an idiot or doesn't want the work or is scamming you.
    Try different dealer.
    Had a dealer once tell me joints couldn't be replaced and quoted me a full drive shaft. Went to oreiley and got joints for $16 each and paid a local tire/general auto shop $50 to install them.
    outlawtacoma likes this.
  5. Apr 16, 2018 at 6:31 PM
    Tacomalx4x4
    Corey
    Wv
    07 6spd DCSB silver
    If the bearing has play it needs replaced
  6. Apr 16, 2018 at 6:33 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I got one at Autozone for around $60+tax.... definitely dont need a new driveline unless you want to throw away money!
    REDdawn6 likes this.
  7. Apr 16, 2018 at 7:13 PM
    reppinthe509
    Washington
    Did you do it yourself?
  8. Apr 16, 2018 at 7:21 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
  9. Apr 16, 2018 at 7:32 PM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    I had the dealership tell me that I needed a new driveshaft a few years ago. I said hell no took it to a local shop and they replaced my u joints. Got reimbursed by toyota just last week .
    Show them the propeller shaft letter if they still balk go to a different dealership
  10. Apr 25, 2018 at 1:14 PM
    reppinthe509
    Washington
    So I ended up taking it to a local shop to have the bearing taken care of. they just called and said the u joint is completely toast as well. I told them to save the parts and I would bring them in to show them how wrong they are. It pisses me off how much a dealership can miss and then try to tell me I need a whole new drive line. I'm on the phone with the dealer right now to try and get this reimbursed.
  11. Apr 25, 2018 at 1:17 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    clunk/vibrate/feel like youre going to die at 12 mph...
    https://www.youtube.com/watch?v=jzabcym5Lek
  12. Apr 25, 2018 at 1:22 PM
    reppinthe509
    Washington
    how did you end up getting reimbursed?
    They're telling me that I'm SOL because they can't replicate the noise if it's already fixed. (because we already replicated the noise).
  13. Apr 25, 2018 at 1:28 PM
    taco2010trd
    Tampa, Florida
    I received a letter from Toyota and it had the steps listed to get reimbursed. Search on here, there should be a copy of the letter .
    I was fully reimbursed for the cost to replace my u joints. Mine were replaced by an independent auto shop .
