Carhartt Seat Covers vs. OEM Leather for Overlanding/Camping
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bigtrout, Apr 4, 2021.
  1. Apr 4, 2021 at 5:17 AM
    bigtrout
    bigtrout [OP] Well-Known Member
    New truck coming in few months. Will be Toyota leather trimmed seats.
    I've always been a Wet Okole man, and would be replacing a very weathered set. Found fit great, just finicky to get adjusted properly. Unfortunately, after 3 years on the truck, the Wet Okoles also appear to have compressed some of the foam at the hinge of the seat bottoms and backs - resulting in some nasty gaps.
    Been looking at Carhartts to slap on over the leather in the new Taco. After the experience with Wet Okole's, I think I'm much better off with a looser fitting cover. I presume they can't be as tight-fitting as neoprene covers.
    Thoughts on how snug the Carthartts are?
    The seats regularly get a dose of some dirt, water, and the occasional scratch.
    Are the stock leather/leatherette trimmed seats in a TRD Sport durable in the long run? Do I even need covers?
    Or does the leather not hold up well to the outdoors.
    In the end, its mostly spills from the kid and rain/snow, and the build up grime from the outdoors that settles on things over time.
    Thoughts on sticking with the OEM leather/leatherette or going Carhartt?
  2. Apr 4, 2021 at 5:30 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I have the Carhartts, they fit a little loose, but I like that, it's easy to remove and wash them.
    That's said; I couldn't imagine paying for leather, and covering them, might as well enjoy them if you like leather (I don't).
  3. Apr 4, 2021 at 5:31 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I bought the carhartt mossy camo's. These are suppose to go on in minutes, but for some reason the driver side seat was a bitch to slip on the cover...very tight. At any rate the passenger side seat went on like butter. They were a bit wrinkly for the first few weeks, but as of now they look great. Its hard to tell they are not actually the seats. Hopefully whenever it comes time to clean them it should be as easy job.
    On another note, i helped a buddy install coveking's in his truck, yeah they went on ok, but not without cursing, and some blood loss. I'd hate to be the one to pull them off to clean down the road.
  4. Apr 4, 2021 at 5:37 AM
    bigtrout
    I have no choice on the leather! Its the only upholstering option on a manual TRD Sport Premium in Canada...
    Either of you have a minute to send a pic later on, I'd greatly appreciate it.
    How do the Carhartts deal with water/liquid? I assume like my jacket, water beads a tiny bit but ultimately gets absorbed. How "water resistant" are these anyway?
  5. Apr 4, 2021 at 5:49 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    A simple spill, water will roll off.
    Here ya go bud
    eurowner likes this.
  6. Apr 4, 2021 at 6:07 AM
    SELAroadrunner
    SELAroadrunner Well-Known Member
    Ron
    WSNC
    17 Sport
    wheel decals
    Hope is better than the crappy quality clothes they’ve been making the last 15 years....made in ABA. DTCFTW!!
  7. Apr 4, 2021 at 6:12 AM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    I have the Carhartts and would describe the fit as a little loose. I did wash them before installation. They still have a little water repellency about as you would expect. Water will initially bead up and then soak in. I have not removed them since I installed them several years ago . I have successfully cleaned the occasional spot with a spray cleaner and a damp rag.
    I still keep an Aries seat cover in the truck to throw over the seat for when I'm really wet or dirty:
    https://www.autoanything.com/seat-c...RGNWZJw21E1F3GyZtJFU6ADMTMZftV1RoCrK8QAvD_BwE
    My original seats are fabric.
  8. Apr 4, 2021 at 6:31 AM
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    I ran toyota covers for a decade and a half. Seats looked absolutely brand new underneath. Not so much as a crease in the bolster. I attribute such to good sense getting in and out and a tight fitting seat cover.
    I have a front set of the Rough Country headed my way for evaluation for $100.
  9. Apr 4, 2021 at 6:36 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Why not enjoy your leather seats now and then cover them later if / when they start to look like shit. Unless you plan on selling the truck in a year or two, what the heck are you preserving them for?
    bulalo likes this.
  10. Apr 4, 2021 at 6:37 AM
    .45 Calibear
    .45 Calibear Well-Known Member
    Tri-Valley - San Joaquin Valley, CA
    17 TRD Off Road - REI Crawler
    Broverlandering kinds
    Had neoprene covers before and the driver side wore out from constant sliding on and off of the seat. The seams also separated. Got the Carhartt covers and they still look brand new after a year. That’s that duck canvas for you.
  11. Apr 4, 2021 at 6:49 AM
    zoo truck
    None
    Reason i got the carhartts is they were noted to be a tough cover not easily ripped. I've got a bad habit of forgetting to take tools out of my back pockets when getting into the truck...especially screwdrivers. So far so good.
  12. Apr 4, 2021 at 7:47 AM
    bigtrout
    Idea is to have the seats covered when needed (most of the spring through to fall) and then otherwise just enjoy the leather. In 12 months, the truck sees about 7 months of time where seat covers are useful. So I hear you - use the leather, and that's the plan when the truck doesn't see trail use for longer periods of time.
    In addition to fitting loose so that the cushioning doesn't deform, I'm hoping the Carhartts come on/off fairly quick.
    Can the Carhartts be treated with a DWR type spray to improve the water-repellent quality?
    GSDLVR123 likes this.
  13. Apr 4, 2021 at 8:05 AM
    GSDLVR123
    GSDLVR123 Well-Known Member
    Randall
    2023 TRD Pro (Solar Octane)
    As others have said the covers fit snugly- I love them. I don’t go over landing but I own a horse farm on a river and these covers protect the seats wonderfully. I bought a seat for my son’s 2002 TRD OR Tacoma- he also does blacksmith work so we both remove the covers , wash them and put back on. We both use a water repellent spray. I have put over 100k miles on my truck in just over 2 years a lot of those in 4WD mud and muck- these covers are great. 0B76C12C-2395-46ED-B172-CF29104BA74C.jpgAAECF05E-D2E4-49D9-A994-3B8E6E4CF767.jpg AAECF05E-D2E4-49D9-A994-3B8E6E4CF767.jpg 0B76C12C-2395-46ED-B172-CF29104BA74C.jpg AAECF05E-D2E4-49D9-A994-3B8E6E4CF767.jpg
    RCBS likes this.
  14. Apr 4, 2021 at 8:07 AM
    GSDLVR123
    Randall
    Sorry for the duplicate pics- I’m on my iPad in the field and can’t figure how to delete the extras. Haha
  15. Apr 4, 2021 at 10:02 AM
    RichVT
    Rich
    Northern Vermont
    A spray on or wash in product should enhance or restore the water repellency.
  16. Apr 4, 2021 at 1:58 PM
    bigtrout
    So I take it if you wash the covers, its not a half-day of cursing and skinning knuckles trying to get them on and off?
    And, if they're loose I take it there is also no irregular compression of the foam seat cushion (from being bound in the seat cover)?
    Thanks for the pics by the way!
  17. Apr 4, 2021 at 6:12 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    No, not to remove and reinstall, of course to wash and dry em take a bit, I put in dryer on low for a bit then hung outside.
    I didn't notice any deformation of the cushions.
  18. Apr 5, 2021 at 7:56 AM
    GSDLVR123
    Randall
    Well to be honest...My son removes and puts the covers on....so to me it is like washing clothes, it doesn't look difficult - I've seen it done but never done it (LOL).
  19. Apr 5, 2021 at 3:35 PM
    zoo truck
    None
    Should be only a 15 minute job removing. and reinstalling the carhartt covers. It'll take longer to wash them.
  20. Apr 5, 2021 at 3:41 PM
    Fish.Taco.Ma
    Fish.Taco.Ma IG: @fish.taco.ma
    Dean
    2017 Silver Sky Tacoma TRD Offroad
    I feel like the leather seats should be able to wipe off easy. The factory cloth seats not so much. For not much more than the carharts you can upgrade to custom prp seat covers
