Cargo net that goes across the bed?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crustykent, Nov 5, 2017.
  1. Nov 5, 2017 at 11:34 AM
    crustykent
    crustykent [OP] Member
    2017 Tacoma TRD Offroad
    I've seen several comments about cargo bars and cargo nets..... Maybe the answer is in one of those responses but I just don't see it. I'd like to find a slightly stretchy net the goes across the bed, not over the bed. Use it to keep things from rolling up into the bed of the truck, keep things near tailgate..... Any ideas?
  2. Nov 5, 2017 at 11:39 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    There's an oem bed cargo divider. Pricey, but worth it.
    https://www.amazon.com/dp/B01ASASC3S/ref=cm_sw_r_cp_awdb_2I2.zbZDE3Z60
    tcBob likes this.
  3. Nov 5, 2017 at 11:46 AM
    crustykent
    thanks, I like this one, will keep in mind for sure! :)
    EatSleepTacos likes this.
  4. Nov 5, 2017 at 11:54 AM
    tacosurpreme
    tacosurpreme Member
    Central MA
    2012 TRD Sport
    EatSleepTacos[QUOTED] likes this.
  5. Nov 5, 2017 at 12:07 PM
    Loudog504
    Loudog504 Well-Known Member
    Luis
    Baton Rouge, LA
    2017 Tacoma TRD Off-Road 4X4 DCLB
    How does the divider work if you have other tie downs in the track? Can it be pulled out and moved around or do you need to have the track free of other things to move it about?
  6. Nov 5, 2017 at 12:09 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The tie downs can be removed anywhere on the track, so if one gets in the way just pop it out and then pop it back in.
  7. Nov 5, 2017 at 12:12 PM
    Loudog504
    Luis
    Baton Rouge, LA
    Yeah bad example. Meant more of like tonneau cover brackets that can't be moved. Can the divider pop out the tracks to move it about or does it only slide on the rails?
  8. Nov 5, 2017 at 12:17 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Ahhh, I understand now. I can't comment on that because I've never seen one in person. Some people in this thread discuss it though.
    https://www.tacomaworld.com/threads/tonneau-cover-bed-divider.404667/
    Loudog504[QUOTED] likes this.
  9. Nov 5, 2017 at 12:30 PM
    Loudog504
    Luis
    Baton Rouge, LA
    Thanks! Looks like the divider itself can be removed but the brackets it sits on can only slide around on the rails. Someone posted a link to a ratcheting cargo bar that might work for what I need and 10x cheaper lol
  10. Nov 5, 2017 at 12:46 PM
    su.b.rat
    su.b.rat broken truck
    the slightly stretchy net to which you refer can be found at U Haul stores for $20.
  11. Nov 5, 2017 at 12:48 PM
    behls
    behls Well-Known Member
    Dave
    Lehigh Valley, PA
    2017 SR5 DCSB Quicksand
    $300?!?!?! christ almighty.
    I made one, bought two pieces of bungee rope and a piece of netting. Tied it to the bed cleats on the top and put little hooks through my bed mat with a washer and nut that hold the bottom. It was 12 dollars all in.
    bungee rope and netting off of ebay. and hardware for a buck at the local shop.
  12. Nov 5, 2017 at 5:38 PM
    mtntacoma!
    mtntacoma! Member
    Ed
    S Cal
    17 TRD Sport, Auto, 3.5, Barcelona Red
  13. Nov 5, 2017 at 5:45 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
  14. Nov 5, 2017 at 5:52 PM
    tcjacado
    tcjacado Well-Known Member
    I saw a post today that showed a someone used the trunk net from a Toyota Camry. He put d rings on the corners and clipped the bottom to the tie downs in the corners and he put L brackets up top and hooked the d rings to those.
  15. Nov 5, 2017 at 6:01 PM
    LDL
    LDL Well-Known Member
    San Diego, CA
    2017 Tacoma 4x4 DCSB
    Air conditioning, floor mats, seat belts
  16. Nov 5, 2017 at 6:06 PM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
  17. Nov 5, 2017 at 7:04 PM
    bcnu
    bcnu Active Member
    The Big Island, Hawaii
    2016 SR5 4x4 Access Cab / V-6 A/T Quicksand
    I have one of the OEM bed dividers and find it useful for many things, but most of the time I have it removed and stored. Part of what I like about it is that in addition to being used as a vertical divider, it can be mounted horizontally and that may help to hold some things in the bed, to support a load at bed-top level while other stuff is underneath, or to obscure what is under it to discourage sticky fingers of passersby. The thing is expensive, but because I bought my truck through the Costco buying program I was able to buy the divider and the OEM bed mat from my dealer at 50% off list.
    But more than the aluminum divider, I find my cargo net handy. And it can be used to restrain things from moving around as well as going over the load. The bottom edge can be attached to the D rings and the load placed on that part of the net while the top attaches to the movable cleats, if you catch my drift. I have had several cargo nets over the years, and found one that really stands out for quality -- a Spidy Gear bed net. The first one I had lasted 20 years, and would still be going if I had not used it on some equipment with a sharp metal edge. Just be sure to get the Truck Bed - Small size.
  18. Nov 6, 2017 at 3:51 PM
    crustykent
    Thanks for all the replies, lots of options !!!
  19. Nov 6, 2017 at 5:19 PM
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
  20. Nov 6, 2017 at 6:32 PM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
