Cardinal Red vs Radiant Red color difference
Discussion in '1st Gen. Tacomas (1995-2004)' started by BiNiaRiS, Dec 27, 2016.
  1. Dec 27, 2016 at 1:03 PM
    BiNiaRiS
    BiNiaRiS [OP] Well-Known Member
    Portland, OR
    Anyone know how close these are in color? Wondering if a Cardinal Red canopy would be close enough in color to match with my Radiant Red double cab.
    Thanks!
  2. Dec 27, 2016 at 2:51 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    cardinal is a deeper red, radiant is a bright red
  3. Dec 27, 2016 at 3:12 PM
    tntacomaguy
    tntacomaguy Well-Known Member
    I'll have to get a pic of mine. I have that exact coloring on my truck and camper. Depends on the light as to how bad it clashes. I'm OCD enough that it drives me crazy. But I got a great deal on the shell and couldn't pass it up. I'll try to get a pic tomorrow
  4. Dec 27, 2016 at 3:13 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    true point, if you get it for under 300 who cares, just paint it :D
    mine was from a purple 97, used stripper and wet sanded it down. my uncle primed and threw a coat of paint on. it matches but not perfect, idc cause you can't tell unless you are standing next to it
  5. Dec 27, 2016 at 3:28 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Cardinal Red (pre-2001) and Impulse Red Pearl (post -2001) are very close and very different from Radiant Red.
    Cardinal Red canopy on my Impulse Red extra cab.
  6. Dec 27, 2016 at 3:37 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Another view
    Here is one of me being towed by a Radiant Red Tundra
  7. Dec 27, 2016 at 5:15 PM
    BiNiaRiS
    Portland, OR
    According to this, those darker reds should match up with Sunfire Red and Impulse Red. I'm talking about cardinal red which should be this:
  8. Dec 27, 2016 at 5:17 PM
    BiNiaRiS
    Portland, OR
    Shouldn't that canopy be Sunfire Red Pearl? Here's the breakdown on colors over the year:
    http://www.toyotareference.com/tacoma/1995-2004
