Carbon build up on spark plugs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kkthejeep, Sep 22, 2024.
  1. Sep 22, 2024 at 8:37 AM
    Kkthejeep
    Kkthejeep [OP] Member
    2019 TRD Off Road DCSB
    She's kinda near stock... for now
    I replaced the plugs yesterday at 59,300 miles. I have been tuned (OTT) since about 26k miles. My truck is mainly a daily driver but is set up to be a tow rig when needed. When the plugs were replaced I had noticed carbon build up on the lower 1/8" of the threads on all of the plugs. Cylinder #5 plug had oil on the threads, the rest were bone dry. I am not used to seeing any build up of anything on plugs and am wondering if something is going on. After I replaced the plugs, the MAF sensor was cleaned (wasn't dirty to the eyes) and cleaned the throttle body. Air filter is the K&N oiled; I have never had any issues on my personal vehicles with oiled filters with MAP or MAF sensors with over 100k miles per engine of reliability to go off of. But the filter is clean and no oil film on MAF.
    Is there an issue going on here or is this normal being tuned?
    CrashZone likes this.
  2. Sep 22, 2024 at 9:01 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    consult a spark plug guide
    looks good to me.
  3. Sep 24, 2024 at 3:35 AM
    Tacorific
    Tacorific Well-Known Member
    NE Iowa
    Barcelona Red 2018 SR5 I4 4X4
    Torque Pro, LED Map & Dome lights, Westin Hitch, Ride Rite Air bags with Daystar perches, Utility Package Rear Cab Panel
    Looks good to me too.
    I find that I get cleaner plugs when I use Top Tear gas exclusively.
    t0p_d0g likes this.
  4. Sep 24, 2024 at 3:53 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    I’m curious what octane are you using and is it a top tier fuel?
  5. Sep 24, 2024 at 5:32 AM
    Kkthejeep
    99.9% of the time I fuel up with Sunoco 87oct. My OTT tune is for 87oct. If I'm towing in higher elevations it's 91oct but that's rare. I'm just used to plugs looking dry and rusty in color and not sooted like these. The soot at the exhaust happened quite litterly over night.
    Now that I have about 90 miles on the new plugs, fuel economy based off of the trip summary has improved about 2 mpg from 17ish.
  6. Sep 24, 2024 at 6:18 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    I have found higher octane fuel burns cleaner but I would say with original plugs and 59,300
    your plugs look fine to me.
  7. Sep 24, 2024 at 6:31 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Are you trying to create a problem here?
    grogie likes this.
  8. Sep 24, 2024 at 3:01 PM
    LS14ME2
    LS14ME2 Kind of a big deal
    In hiding, CA
    2017 SSM Sport DCSB 4x4
    Center console divider thingy, rubber bed mat and side steps for the wife.
    This..
    Those plugs look like they still have a lot of life left to give.
  9. Sep 24, 2024 at 3:42 PM
    Kkthejeep
    I'm a bit confused here. 60k mile spark plug life expectancy as well as a required component to be replaced at 60k miles. Platinum iridium last for 100k miles, not ones we install. My fuel economy nearly got a 2 mpg bump. What all started this was my exhaust suddenly going from a dirty bronze in color to a black soot. Soot in the exhaust is something I'm not familiar with and seems like a bigger problem in the long term.
  10. Sep 24, 2024 at 8:43 PM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    Here’s my original plugs from my truck bought new in December of 22. They have well over 100k on them.
    Not a thing wrong with your plugs.
    t0p_d0g likes this.
  11. Sep 25, 2024 at 3:46 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    60k is Toyota recommended service… not sure why so early on spark plugs . I can see this if u tow and off-road a lot . Everyday driving don’t see the point. Of changing that early . Most vehicles I have owned changed at 100k .. plugs u have look good . Maybe u had some plugs that were loose and using cheap gas why u had some dark build up in the exhaust .
