Car wash snapped my antenna off
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jm1550, Jan 7, 2017.
  1. Jan 7, 2017 at 2:43 PM
    jm1550
    jm1550 [OP] Member
    AJ
    2014 Tacoma
    drive through the car wash and my antenna snapped off. I tried to take the broken base of the screw out but ended up screwing it down even further. Tried drilling it out and then tried unscrewing the entire thing.
    Called my local dealer they said try unscrewing the black base that sits inside the silver 4 notch piece. That didn't budge. I chewed it up pretty good. Can i unscrew the silver notched peice or does not move either.
  2. Jan 7, 2017 at 2:53 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Rambo54, dYL0n and Taco Addiction like this.
  3. Jan 7, 2017 at 2:53 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Looks like your antenna broke off a bit above the mount. If so, you can file the top flat. Use a 1/8" or smaller drill bit to drill into the center of the antenna to give the EZ-out something to bite on.
    Then try to back it out.
  4. Jan 7, 2017 at 2:54 PM
    trdsport6
    trdsport6 Well-Known Member
    West NC
    2015 Super White access cab TRD
    bilstein 5100 @2.5 front and rear Method NV BFG KO2 275/70/17
    What car wash was it?
  5. Jan 7, 2017 at 2:57 PM
    jm1550
    jm1550 [OP] Member
    AJ
    2014 Tacoma
    Hoffmann car wash. I drilled down into the hole pretty good. It's chewed up and not coming out. Can I unscrew the silver peice with the notches and then take the black inner peice out ? Does the black innner peice screw down into anything ?
  6. Jan 7, 2017 at 2:59 PM
    trdsport6
    West NC
    The black piece probably sits in your fender with a plastic clip of some sorts would be my guess. I would try contacting the car wash also to replace it. I worked at car washes all through high school and we were always good about replacing if a stock antenna broke off.
    Rambo54 likes this.
  7. Jan 7, 2017 at 2:59 PM
    Hunter7
    Hunter7 Well-Known Member
    Paul
    2015 tacoma double cab long bed
    :rofl:
    Antennas UR us Car wash:rofl::rofl::rofl:
    File IFR and trdsport6[QUOTED] like this.
  8. Jan 7, 2017 at 2:59 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Jimmyh and tomwil like this.
  9. Jan 7, 2017 at 3:13 PM
    jm1550
    jm1550 [OP] Member
    AJ
    2014 Tacoma
    Ok if I take the bezel nut off can I take the black peice out and then just replace the black peice and the put the bezel nut back on I'm wondering ? Still get a few channels I'd rather not take the entire antenna assembly apart.
  10. Jan 7, 2017 at 3:15 PM
    BassAckwards
    If the threads are ruined where the antenna screwed in, you have to replace the whole assembly to fix it
  11. Jan 7, 2017 at 3:16 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Wow, guess it wasn't a touchless car wash
  12. Jan 7, 2017 at 3:16 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    the bezel nut needs to comeout before anything else.
    do not damage the bezel nut, the antenna assbly is not sold in individual parts..
  13. Jan 7, 2017 at 3:17 PM
    14 Tacoma
    14 Tacoma ColeMcMathisaDouche
    Clinton
    IL
    2014 TRD Sport
    Cheap ebay bumper, plus others
    Are the threads damaged where you accidentally drove it deeper? If it can still be unscrewed if you can get to it, you could try a small left handed drill bit trying to get it to catch. Works similar to an easy out on pieces that are not siezed or torqued down.
    Otherwise you're probably looking at replacing the entire mount
  14. Jan 7, 2017 at 3:34 PM
    Yoda's TRD
    Yoda's TRD Well-Known Member
    David
    Haslett, MI
    2025 TRD Sport Hybrid
    Not to rub salt in an open wound, but I'm pretty sure it says to remove your antenna before going in a car wash in the owners manual.
    Sorry to hear about the damage, hope you get it fixed soon ....
  15. Jan 7, 2017 at 3:38 PM
    JTD408
    JTD408 Well-Known Member
    Santa Clara
    2015 DCSB 4x4 TRD Sport
    Icon stage 3 SCS stealth 8's Clazzio sear covers Weathertech floor loners Redline hood struts
    Exactly. This happened to mine and I had to order a whole attena kit. What a pain in the ass. You will be pulling the head unit, interior pillar, and fender well. Not fun!
  16. Jan 7, 2017 at 3:40 PM
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    Rambo54 likes this.
  17. Jan 7, 2017 at 3:41 PM
    nm4553
    nm4553 You had me at "Meat Tornado"
    Nick
    NEPA
    2017 DCSB TRD Sport
    SCS Stealth 6 Matte Bronze on Toyo Open Country 265/70R17, Fox 2.5 Coilovers, Bilstien 6150 w/ Remote Resi, Dakar Leaf Pack, Wheeler's Bumpstop, OVTuned
    Yeahh..most car washes basically tell you to enter at your own risk. Antennas, window visors, etc. are usually fair game and you assume the risk.
  18. Jan 7, 2017 at 4:04 PM
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    Happened to me twice
    Once at local car wash 2nd time at dealer - Cant stand my dealer so I fixed myself
    Drill with small drill (as quoted above) just a little to make small hole in center then use a easy out
    Go slow push hard try not to slip off and hit fender
    Maybe spray some wd40 or similar first
  19. Jan 7, 2017 at 4:11 PM
    jm1550
    jm1550 [OP] Member
    AJ
    2014 Tacoma
    Ok that's what I thought. I'll try and find an antenna wrench for the bezel nut. Replacing the assembly shouldn't be too bad
  20. Jan 7, 2017 at 4:15 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    My 2013 came with a little plastic wrench to remove the antenna.
