Car not starting after kill switch installation
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bluspectre, Jul 21, 2020.
  1. Jul 21, 2020 at 9:46 PM
    bluspectre
    bluspectre [OP] Active Member
    2007 Tacoma V6 4.0L Speed Auto
    hey, ill try to keep this short. Installed a kill switch on my 2007 v6 and car won't start now. No blown fuses that I have seen, battwry still works and lights and stuff turn on. I have tested the volts on my fuel pump relay and it seems like none of the holes are getting any power on any key position. Is there a fuel pump kill switcj or inertia button somewhere that I need to push?
  2. Jul 21, 2020 at 9:49 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’d inspect what ever it was you did for the kill switch.
    How did you wire the kill switch?
    There is no inertia switch button.
  3. Jul 21, 2020 at 9:49 PM
    bluspectre
    Also i don't hear any noise when putting key into start. I did originally when testing it with the fuel pump wire cut but it stopped eventually
  4. Jul 21, 2020 at 9:51 PM
    bluspectre
    I went in under the steering wheel and cut the green and black wire. I tried reconnecting just them back together and the problem still is there which makes me think my car shut off its fuel system all together as if it was my wiring it probably should turned on
  5. Jul 21, 2020 at 9:52 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    See if you can narrow down the problem by removing the kill switch you installed
  6. Jul 21, 2020 at 9:57 PM
    bluspectre
    I did, I connected the original cut wire with a butt connector but there was still no luck. I also didn't record any volts on the wire no matter what position the key was in
  7. Jul 21, 2020 at 9:58 PM
    TnShooter
    Deogee
    STOCK
    You cut wire to the EFI relay?
    The wire that activates the relay?
    Have you checked the EFI fuses.
    Do you have power to the C/Open Relay?
  8. Jul 21, 2020 at 10:02 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    You sure the battery connections are snug? Battery isnt dead?
    TnShooter likes this.
  9. Jul 21, 2020 at 10:04 PM
    TnShooter
    Deogee
    STOCK
    Kind of be nice to know what the wire went to?
    Where did you get the information on what wire to cut?
    Shellshock likes this.
  10. Jul 21, 2020 at 10:05 PM
    Jason TRD OR
    Jason TRD OR SIBI BUILT LLC
    Sibi Built LLC Placentia, CA
    16 Tacoma TRD Off Road 4X4
    King suspension w/ compression adjusters custom valving and 700# coils. Icon DJ uca. Icon RXT leafs Option #3. Durobumps. Demello rock sliders. Demello 30” Light Bar Baja Hoop bumper with Smittybuilt X2O winch w/ Amber baja design fogs w/ single row Baja Designs S8 amber light bar. Brute force Fab HC rear bumper. Behind Grille Light bar. TRD Pro Skid plate. Pelfrey Mid and Transfer case skid. TC spindle and cam tab gussets. Pop and lock. Method NV wheels 16”. SpiderTrax 1.25” wheel adapters. Yokohama Geolandar M/T (315/75/16). CMC. Radiator core reinforcement. Pro grille. Tailgate inlays. Baja Designs A pillar Ditch lights. Leer 100 XQ shell w/ power locks. In bed mounted spare. Blacked out emblems. Bed Mat. Bed Stiffeners. K&N air filter. Black Headlight Mod w/ LED projectors. Wrap Armor Anti glare hood and bedside decals. American flag decals. Northstar 24F AGM Pro battery. Differential breather relocate to rear tail light. Prinsu Designs Cabrack and Cap rack. OVTUNE Sibi Custom performance 4.88 91 fuel AGM . Nitro Gear 4:88 gears. Mountain hatch tailgate insert. In bed mounted Krazy Beaver shovel with Relentless quick fist bedrail mounts. MESO ultimate turn signals. AJT Designs Quicksand Key Fob. ECGS front needle bearing bushing replacement. Tepui LoPro 2 RTT.
    Kill switch did the job.
    essjay, CurtB, Maticuno and 7 others like this.
  11. Jul 21, 2020 at 10:18 PM
    Muddinfun
    Muddinfun Well-Known Member
    Did you check the 30A AM2 fuse?
    Jimmyh and TnShooter like this.
  12. Jul 21, 2020 at 10:19 PM
    bluspectre
    Having trouble posting a pic of the wire, but I got the info from another post on here. https://www.tacomaworld.com/threads/kill-switch-mod-write-up.88252/ this is it. The power has completely stopped to the wire though even when it is connected back to the original
  13. Jul 21, 2020 at 10:21 PM
    bluspectre
    Well shit, that's it. Or at least its blown. Could I temporarily swap it with the abs now
    Muddinfun[QUOTED] likes this.
  14. Jul 21, 2020 at 10:21 PM
    TnShooter
    Deogee
    STOCK
    I think maybe he cut the st2 wire, it’s the only G/B I see.
    Which is indeed powered by that fuse.
    Good call man.
    Jimmyh and Muddinfun[QUOTED] like this.
  15. Jul 21, 2020 at 10:22 PM
    bluspectre
    It was, man you guys are so great
    Taco-Obsessed and Muddinfun like this.
  16. Jul 21, 2020 at 10:27 PM
    bluspectre
    Alright that seemed to be it, going straight to oreilys tmmrw to get some 30A. Thanks guys
    dk_crew, TnShooter and Muddinfun like this.
  17. Jul 21, 2020 at 10:28 PM
    Muddinfun
    You could. Or, I’m pretty sure the Drivers PW fuse in the under dash fuse box is the same.
    mjmcpeterson likes this.
  18. Jul 21, 2020 at 10:31 PM
    bluspectre
    I'm such a headass, after I got it started and stuff I tried turning the kill sitcwitch on and it blew my other fuse. Ffs. I'm just gonna scrap this kill switch for now but for future purpose, is there a better place to qire in a kill switch
  19. Jul 21, 2020 at 10:33 PM
    Muddinfun
    There’s something wrong with the switch you’re using that is shorting to ground.
  20. Jul 21, 2020 at 10:34 PM
    bluspectre
    I'm not super electric savvy(as you can prob tell). What does that mean and would I be able to fix it
