Capacity of door hinges (hang weight, shear strength)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by elricfate, Jul 15, 2020.
  1. Jul 15, 2020 at 4:03 AM
    elricfate
    elricfate [OP] Well-Known Member
    2009 Tacoma AC Silver Mica
    Good morning! Does anyone know the hang weight capacity for our generation's door hinges?
    Say someone added an extra 10lbs to their door hang weight, do you think there's enough safety margin built into the hinges that the doors won't misalign over time as the hinge fails?
  2. Jul 15, 2020 at 4:19 AM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    I would say there is enough strength for 10 pounds. People often put their weight on the open door just climbing into the truck. The suspension takes the weight.
    elricfate[OP] likes this.
  3. Jul 15, 2020 at 4:20 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Adding some massive speakers?
  4. Jul 15, 2020 at 4:22 AM
    DG92071
    DG92071 Well-Known Member
    I've installed 20-25 pounds of extra weight in quite a few doors but none were on a 2nd gen Tacoma (yet). I've never had a problem and the 2nd gen Tacomas hinges look similar to others that I have added that weight to.
  5. Jul 15, 2020 at 4:25 AM
    elricfate
    Solid core panels.
  6. Jul 15, 2020 at 4:26 AM
    BSK
    BSK Keyboard not responding. Press any key to continue
    Trabant 501 Kombi
    Cigarette Lighter Delete
  7. Jul 15, 2020 at 4:32 AM
    DG92071
    What is a solid core panel and why do you want to install it?
    It sounds pretty obvious what it is, I would like to know what it's made out of and its purpose.
  8. Jul 15, 2020 at 4:55 AM
    elricfate
    It's just a side project I am exploring. I'd really like to have the doors be more beefy. It would be neat to go back to the heavy door seal feel.
  9. Jul 15, 2020 at 5:04 AM
    Captainskidmark
    Captainskidmark Well-Known Member
    Northern Illinois
    2015 4X4 TRD SPORT DCLB ~ Black
    ECGS 4.56 gears with Detroit True Trac in the rear. Camburg Ball Joint UCAs Dirt King LCA Dobinson IMS rear shocks Dobinson IMS w/ 352 coils DAKAR EL096 HD LEAFS AR172 17"x8" BAJA RIMS (5 wheel/tire rotation) GX470 Front Brake Upgrade SS extended brake lines Front and Rear (Toytec) 285/70/17 BFG A/T Toyota Roof Rack over Cab A.R.E. Z series CAP with Rhino Rack rooftop rails , -RED/WHITE LED BED LIGHTING -12V AUX POWER AND USB MAGNAFLOW CAT BACK RAAMmat Sound Abatement Pioneer AVH-2440NEX w/ Android Auto + Morel Speakers 120 VAC Block Heater Pelfreybilt Front/Mid Skids ATH Bed Braces ATH FRONT BUMPER - FULL LOOP BAJA DESIGNS FOGS HERETIC 20" LIGHT BAR ATH REAR BUMPER - STANDARD RIGID FLUSH MOUNT REVERSE LIGHTS Weathertech floor mats Rear Diff Breather Mod Wheeler's Super Bumps + Ubolt Flip Kit ABS Kill Switch Mod Northstar AGM Battery Pedal Commander Desert Does It Seat Spacers
    10 lbs won't make a difference.....
    I added RAAMmat sound deadening material to the doors on my Taco.... aside from getting rid of the road noise, the stereo sounding better, the sound when closing the doors don't have that cheap tinny sound.....
