cap/ shell to truck sealing
Discussion in 'Tonneau Covers, Caps and Shells' started by s.e.charles, Feb 25, 2019.
  1. Feb 25, 2019 at 4:01 AM
    s.e.charles
    s.e.charles [OP] Well-Known Member
    other than the dealer supplied adhesive foam strip (instead of), is there a better gasket material around?
    thanks
  2. Feb 25, 2019 at 8:11 PM
    Mtn Mike
    Mtn Mike Well-Known Member
    Spokane, WA
    2017 TRD OR AC
  3. Feb 26, 2019 at 3:06 AM
    s.e.charles
    thanks. I thought that style & material would be superior to the thin, flat, foam.
    2019 long bed access cab w/ ARE commercial cap on order.
    i'll bash the cap dealer after it's installed (4 weeks). remind me never to work retail!
  4. Feb 26, 2019 at 3:09 AM
    s.e.charles
    I had read this.
    Q: use a thinner bulb style?
    I like EPDM products. got a bunch of Marvin big-buck windows to stop leaking with HD epdm self adhesive weatherstripping (to thin for bed rail seal).
    Mtn Mike[QUOTED] likes this.
  5. Feb 26, 2019 at 5:41 AM
    Mtn Mike
    Spokane, WA
    2017 TRD OR AC
    I don't know what size. Isn't your dealer doing the install?
    For underneath the bedrail, use sealer from a tube. I used Geocel Proflex.
  6. Feb 26, 2019 at 6:35 AM
    s.e.charles
    cap dealer. since when did "dealers" do anything but price-point service 'n' sales?
  7. Feb 26, 2019 at 6:40 AM
    Mtn Mike
    Spokane, WA
    2017 TRD OR AC
    dunno. The ones I've worked with always did the install. Also, don't AREs come with a bulb seal, factory installed? The only thing you would have to do is seal under the bedrail caps, if you wanted.
  8. Feb 26, 2019 at 9:11 AM
    s.e.charles
    I hope they prove my concern unfounded.
    Q: do we seal the bed rail side plastic cap in place or remove it?
    thx
  9. Feb 27, 2019 at 2:24 AM
    Mtn Mike
    Spokane, WA
    2017 TRD OR AC
    Remove it to seal it. There are about 8 clips per side holding them in place. It's good to have a trim removal tool or maybe a butter knife to pry it off without breaking the clips. There are good instructions on a thread around here somewhere.
