CAN'T PUMP GAS
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JayBird1993, Feb 3, 2022.
  1. Feb 3, 2022 at 11:31 AM
    JayBird1993
    JayBird1993 [OP] New Member
    2019 TRD 4x4
    3in Level kit 255-85R16 5% Tint Throttle Controller
    I have a 2019 TRD 4x4 with 45,000mi.
    I am having extreme trouble pumping gas. The pump "clicks" every single time. I can play with it and eventually I can get it to SLOWLY fill without clicking. No codes have been thrown that I have seen. Has anyone else had this issue so early on and if so what could be the issue and how should i go about fixing it? TIA.
  2. Feb 3, 2022 at 11:33 AM
    TRD2010SpeedwayBlue
    TRD2010SpeedwayBlue Well-Known Member
    Brandon
    2010 Speedway Blue TRD Offroad
    sounds like a user error.
  3. Feb 3, 2022 at 11:34 AM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    Did you used to fill it up more after the pump shut itself off automatically?
  4. Feb 3, 2022 at 11:36 AM
    Rezkid
    Rezkid Not a Well Known Member
    TJ
    WTX
    '08 DCSB TRD RT
    Little bit of this and that
    Friday thread on Thursday? :popcorn:
  5. Feb 3, 2022 at 11:38 AM
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    @JayBird1993 Check this article out.
    " The gas pump nozzle shuts off due to the way it is designed. When the nozzle shuts off as you’re trying to use it, this does not necessarily mean that it is malfunctioning. Actually, it has a mechanism that is supposed to shut off the fuel supply for safety reasons. The fuel shutoff sensor is located on the end of the nozzle near the opening. It is not an electronic sensor, despite its somewhat misleading name. Instead, it is a mechanical device. The shutoff mechanism is a small hole near the tip of the nozzle that is connected to a pipe. Air needs to constantly flow into the pump via this hole or the fuel supply will be cut off."
    Edit: there are ways to defeat the mechanical shut off but you need to monitor how much fuel is going into your Taco so you don't overfill, spill gas, and ruin the evaporator canister. Just pull the gas nozzle out of the fill tube a bit so fresh air gets to the nozzle. If you are in CA, in your off hand you will need to pull up on the gas pump vapor sleeve so the pump thinks it is seated to the fill tube.
    bulalo and eurowner like this.
  6. Feb 3, 2022 at 11:40 AM
    networkraptor
    networkraptor Well-Known Member
    2023 NBM ORP
    I had this happen on my STi and it was the evap canister. However, a bad evap canister should throw a code. Might be a place to start.
  7. Feb 3, 2022 at 11:42 AM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Have you tried different gas stations and or pumps? Same results?
    Some here had a faulty valve causing overfill but not your particular issue. https://www.tacomaworld.com/threads/overfilled-gas-twice.738756/
    Edit: Yes, try EVAP as a suggested place to start. Prior to your issue did you always top off your tank once it clicks?
    airmax233 and Gen3TacomaOBX like this.
  8. Feb 3, 2022 at 11:42 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    NJ and OR you can't either
    Duckinatruck, 02Duck and shakerhood like this.
  9. Feb 3, 2022 at 11:44 AM
    SDTaco4x4
    SDTaco4x4 Well-Known Member
    San Diego
    2016 Black TRD Sport 4x4
    Well the obvious question is have you tried different pumps?
  10. Feb 3, 2022 at 11:45 AM
    Carbonjake
    Carbonjake Member
    Jake
    2018 SSM SR5
    Happen to be at a Costco? They have a new nozzle you have to click into place before pumping….
  11. Feb 3, 2022 at 11:53 AM
    Kmart6
    Kmart6 An Average Joe
    MD
    08 2.7 5spd
    If you’re using the same pump, could just be a fast flow rate that’s causing to to fill/shut off. That’s probably why it works when you “slowly fill”.
    #4TOY4ME likes this.
  12. Feb 3, 2022 at 11:55 AM
    JayBird1993
    2019 TRD 4x4
    I have been to several different pumps over the passed two weeks. I just bought the truck from a dealer about a month ago and now this. I have read elsewhere that the cannister could be malfunctioning but as stated before, should be throwing a code if it is but mine is not. I have also read that the purge/vent valve solenoid could be the issue but would also be throwing a code.
    NetworkRaptor, if you dont mind me asking do you recall a price for the cannister you replaced yours with? I am having trouble locating one around here to even get a price. I'm in North Louisiana.
  13. Feb 3, 2022 at 11:59 AM
    networkraptor
    2023 NBM ORP
    I replaced it on my old 2005 STi, not sure what one would cost for our trucks.
  14. Feb 3, 2022 at 12:09 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Mine does it I just don't jam the filler into the neck all the way, just enough that the gas cap threads of the filler neck catch the spring on the pump tube so as stated above the cut off diaphragm can get air flow.
    Still works fine and still automatically shuts off when it's supposed to without being aggrivating while trying to pump.
    mic_sierra likes this.
  15. Feb 3, 2022 at 12:11 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Idk about costco, as there's none locally here. We have plenty of shell and irving gas pumps along with all the other types. All have worked the same for me. If your taco won't accept the fuel, it seems like a venting issue of sorts.
  16. Feb 3, 2022 at 12:12 PM
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    this has only happened to me once and it was the new gas station by my house. went to the one i normally use by my work and could pump fine. sounds like this is happening at a lot of different pumps for you though.
    I think this guy is running into the same issues as you. he hasn't figured out what the problem is, but he will probably post a video about fixing it soon
    https://www.tacomaworld.com/threads...interesting-video-on-a-13-000-3rd-gen.748698/
    Koolbreeze7 and JayBird1993[OP] like this.
  17. Feb 3, 2022 at 12:46 PM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Yep and some trolling too
    Chaosh1 and JayBird1993[OP] like this.
  18. Feb 3, 2022 at 12:57 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Before you go spending blind money on parts, take it to a good mechanic who should be able to test the evap system through the ECU/OBD and do a physical inspection.
    JayBird1993[OP] likes this.
  19. Feb 3, 2022 at 3:07 PM
    Kel Varnsen
    Kel Varnsen Active Member
    PO HO
    2005 DC TRD ...Sold 425k Now 2016DC TRD
    I have had this problem with at least 2 Tundras ... Always 3 step process to solve: 1. Is the filler neck bent or deformed? 2. Change charcoal cannister 3. Anti Siphon valve ? ... In all cases the A-S value was the culprit - A new fuel tank was required
    Canadian Caber likes this.
  20. Feb 3, 2022 at 3:11 PM
    Gen2Tacoma
    Gen2Tacoma A Question Asked is an Answer Learned!
    North East Atlanta
