Cant get into Programming Mode (keyless entry)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bosshog1, Aug 4, 2014.
  1. Aug 4, 2014 at 11:55 AM
    bosshog1
    bosshog1 [OP] Well-Known Member
    micah
    West monroe, la
    '05 DCSB TRD Off-Road
    OME lift w/ 886's and Dakar AAL, Cooper Discoverer ST Maxx 285/75/16, Cruisin Off-road front bumper, custom Toyota grille
    2005 TRD Off-Road
    Trying to program a new keyless entry remote. I used the following procedure, but my truck will not go into Programming Mode. Any ideas? Thanks.
    The vehicle should meet the following conditions before proceeding:
    *The key is NOT in the ignition
    *Driver’s door is OPEN (The others are CLOSED)
    *Drivers door UNLOCKED (Not necessary for Echo)
    1) INSERT and REMOVE the key from the ignition cylinder, TWICE within 5 seconds 2) CLOSE and OPEN the driver’s door TWICE within 40 seconds
    3) INSERT and REMOVE the key into the ignition cylinder
    4) CLOSE and OPEN the driver’s door TWICE within 40 seconds
    5) INSERT the key in the ignition and CLOSE the driver’s door
    6) Turn the ignition switch from LOCK to ON and back to LOCK at approx. 1 sec. Intervals “ 2” times to enter REWRITE MODE
    7) REMOVE the key from the ignition (The door locks are cycled LOCK-UNLOCK within 3 seconds TWICE to let you know that you have selected REWRITE MODE)
    8) Within 40 seconds press BOTH the LOCK & UNLOCK buttons on the transmitter simultaneously for 1 second (Press and release).
    9) Within 3 seconds press and release the LOCK button on the same transmitter (The door locks will cycle ONCE if the transmitter was recognized and TWICE if it was not recognized {if you get two cycles start over}).
    10) Within 40 seconds repeat step 8 and 9 with any other transmitters you wish to program
    11) One of the following will END the Rewrite mode; *40 seconds elapses *Drivers door is opened *Key inserted into the ignition cylinder *4 transmitters are registered
    Step #6 Options:
    *1 time it's for add mode
    *2 times for rewrite mode
    *3 times for confirmation mode
    Chadley22 and Surfr6 like this.
  2. Aug 6, 2014 at 6:38 AM
    bosshog1
    micah
    West monroe, la
    For anyone who is interested, I finally got this to work. I located the wireless receiver under the dash (little white box), unplugged it and then plugged it back in, and then the programming instructions worked!
    Mr. Excitement, Chadley22 and Lt_Dan like this.
  3. Aug 6, 2014 at 7:08 AM
    1eyedjack
    1eyedjack Old Pirate
    Southeast USA
    2014 MGM DCSB TRD Sport Tow
    Interesting. My Sister's 2006 Camry keyless entry has stopped working and I can't get the re-program sequence to work. May have to try locating and unplugging the wireless receiver as you did. Thanks for the follow up.
  4. Nov 23, 2015 at 11:15 PM
    SCRTCH
    SCRTCH Member
    Rich
    SLC, UTAH
    2005 SR5
    2.5 inch leveling kit and a SAWEET stubby $8 antenna from Amazon. NO CHROME PLEASE
    I've been digging around this thread and other threads like it - wanted to share some feedback incase it helps a future person. I found a number of threads with good info, but none included that you CANNOT get your truck into programming mode with the grey "valet" key. My trucks keys and fobs were both lost, and I ended up buying a replacement key from a locksmith, that was chipped to match the valet key. Later I bought some new internet fobs and keys, but could never get my truck into programming mode to add them. -It never occurred to me that both my OEM valet key and it's mirrored chipped key wouldn't work!
    Finally took my new fobs and keys to the dealer and got them all flashed and working.
  5. Dec 10, 2015 at 5:39 AM
    Lt_Dan
    Lt_Dan Well-Known Member
    Daniel
    Cincinnati OH
    2017 TRD OR 4x4 DCSB A/T Super White
    Can you describe better the location of this box please? Or maybe take a picture? I'm having the same problem. Thanks in advance.
  6. Dec 14, 2015 at 9:38 AM
    bosshog1
    micah
    West monroe, la
    Looks like this
  7. Dec 14, 2015 at 9:39 AM
    big_jarv
    big_jarv Well-Known Member
    2020 TRD Pro
    These can be kind of tricky.
    I worked at a hardware store and this was a service offered there.
    Sometimes we really struggled getting them.
  8. Dec 14, 2015 at 9:44 AM
    Lt_Dan
    Daniel
    Cincinnati OH
    Thanks, I called the company that sold me the remote and they realized they sent me the wrong remote. They sent a remote with a button for a trunk, obviously our trucks don't have trunks.
  9. Jul 27, 2016 at 6:44 PM
    thegman
    thegman New Member
    2004 Tacoma Dbl Cab
    I'm struggling to even locate the above-pictured box under the dash on my '04 Tacoma (4d PreRunner.)
    I'm relatively sure it needs unplugged and plugged in, again. The keyless hasn't been used in a couple of years and I can't get into programming mode for new fob. Help!
  10. Jul 28, 2016 at 5:09 AM
    bosshog1
    micah
    West monroe, la
    You have a Gen 1, so I can't be sure that your setup is the same. When I get some time, I will go down to my truck and see if I can remember where it is exactly.
  11. Jan 4, 2017 at 4:50 AM
    bosshog1
    micah
    West monroe, la
    It looks like this
    I will try to get a pic of it on my truck when I get a chance.
    Chadley22, jjhitchen and Biloxiibm like this.
  12. Jan 5, 2017 at 6:47 AM
    Biloxiibm
    Biloxiibm Member
    Boss has been trying to help but in the meantime, does anyone know the location of the white box and bracket shown above?
  13. Jan 5, 2017 at 6:59 AM
    bosshog1
    micah
    West monroe, la
  14. Jan 5, 2017 at 7:21 AM
    Biloxiibm
    Biloxiibm Member
    Thanks Boss! This is the diagram for its location from the above thread.
  15. Jan 5, 2017 at 7:27 AM
    bosshog1
    micah
    West monroe, la
    Were you able to find it using that diagram?
  16. Jan 5, 2017 at 8:24 AM
    Biloxiibm
    Biloxiibm Member
    Yes, when pulling the tabs on the glove box you can get your hand in to unplug the box and plug it back in. Unfortunately for me that didn't work so my guess is that mine has gone bad. My next step is to go to the local junk yard and try one of theirs. Nice part is that once you unplug the box you can plug another one in without actually having to mount it and try the programming sequence to see if the locks cycle in I think step 5. Lucky for me I know a few people in the used car parts so if it is the problem I should be able to get one at a decent price. Another unfortunate thing is that while I have tried to locate and resolve this problem I have learned that my truck has some other issues due to an accident that I was not made aware of and didn't show up on carfax. A big problem when getting a truck from a 2 cent dealer and not an individual. Nothing I can't take care of on my own but still a pain in the butt.
    Boss, thanks for the help, much appreciated!
  17. Feb 19, 2017 at 11:18 AM
    rhetto
    rhetto Well-Known Member
    Rhett
    Austin, TX
    2010 TRD Off Road
    What does the box do? I'm trying to find it under my dash and it doesn't look like I have one. I can see the bracket, but there's nothing there. Unless I'm looking in the wrong spot. But if yours was malfunctioning before, I'm curious to know what it does and why you didn't know it was malfunctioning previously. Part listing just says "Receiver, Door Control". Well, my key works to lock/unlock my doors. I'm trying to program a new secondary fob but can't get into programming mode.
  18. Feb 19, 2017 at 11:37 AM
    rhetto
    Rhett
    Austin, TX
    2010 TRD Off Road
    Never mind. I'm an idiot. I didn't read anywhere anyone saying that after removing the glove compartment, you need to also remove the black plastic piece above it by unscrewing the 10mm bolt behind the latch and popping it out. Found the unit there, unplugged, re-plugged and followed the directions in post #1 and got it to work.
    Chadley22 likes this.
  19. Feb 19, 2017 at 11:39 PM
    MDB Taco
    MDB Taco Well-Known Member
    GA
    ‘05 TRDOR DC
    Does this box also control the headlights turning on when you lock/unlock the truck? I've been wondering where the control for that comes from, as I've been kicking around the idea of tying in my rear flood lights so I have 360 degree arrival/departure lights or whatever they're called. My parents' cars do this and I wish my truck did too.
  20. Apr 8, 2017 at 7:39 AM
    adolphe
    adolphe Member
    Ontario, Canada
    06 Access Cab TRD
    I just wanted to add in my experience. One day the fob stopped working, thought it was the battery so changed it with no luck. Found threads saying to reprogram it but couldn't get it into program mode. Found this thread with info about unplugging the module and that did the trick. For those having trouble finding it, it's easiest to pull the glove box out, and then grab a 10mm socket at remove the plastic cover plate that is attached at the glove box latch. Then if you lay on your back on the floor of the passenger seat, you will see the white module that needs unplugging.
