Canopy window replacement
Discussion in 'Tonneau Covers, Caps and Shells' started by constar, May 2, 2018.
  1. May 2, 2018 at 6:48 PM
    constar
    constar [OP] Member
    Conor
    Stock Stick Shifter '14
    Dog, stickers.
    Hey folks,
    First time posting on here!
    I'm shopping around for a used cap, and I'm seeing a fair few for sale with missing windows.
    Pricing for a shop to replace them seems to be around $200 per window, but I'm willing to bet its a fairly DIY possible job. Anyone have any experience doing this, or can point me to any good threads on the subject?
    Thanks!
  2. May 2, 2018 at 7:15 PM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Depends on the window type and size- and there are a lot of variations out there. Buying new windoors for example can be around $400/each.
    If you get the right size it's pretty easy, just undo the screws, pull the trim ring out while someone holds the window from the outside so it doesn't fall, then remove the window/frame. Clean up around the opening and install is reverse of removal. There are videos on youtube.
  3. May 2, 2018 at 8:21 PM
    constar
    constar [OP] Member
    Conor
    Dog, stickers.
    Alright, thanks for the info!
    I've seen some stuff about people cutting the replacement windows from Lexan, I might look into that as well.
  4. May 3, 2018 at 4:14 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    I looked into doing this to put windoors in mine and they are just too expensive individually to make it worth it. Your best bet is to find a cheap used shell to steal the windows from.
  5. May 3, 2018 at 11:19 AM
    constar
    constar [OP] Member
    Conor
    Dog, stickers.
    Ah, copy. Maybe i'll pass then.
  6. May 4, 2018 at 6:57 PM
    Bajatacoma
    SC
