Can you siphon gas out of a taco?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sig Taco, Sep 6, 2021.
  1. Sep 6, 2021 at 10:30 PM
    Sig Taco
    Sig Taco [OP] Well-Known Member
    2021 Taco DCSB
    Icon Rebounds 17x8.5 Toyo 35/12.5/17 JBA UCA, Bilstein 6112/5160, KDMax
    In South Louisiana and was out of power for 6 days. Gas was very hard to come by for my generator and I had a full tank of gas. Got power now though.
    Is it possible to siphon gas out of a Tacoma? I have read on a lot of newer vehicles, its not possible.
  2. Sep 6, 2021 at 10:33 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Not out of the filler neck. There is a ball that stops it. But if you can remove the filler neck from the tank then you could siphon directly from the tank.
    If you’re going to disconnect a line and use the fuel pump just be careful. Lots of pressure.
    Skydvrr likes this.
  3. Sep 6, 2021 at 10:34 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Correct, on the Tacoma there is a screen in the filler neck. You may need to disconnect the fuel line under the hood, and have the fuel pump, pump it out for you.
    JustJon likes this.
  4. Sep 6, 2021 at 10:40 PM
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    This
    Or rummaging from other wrecked Tacos in a survival situation?
    Put a large Tupperware box (20 gallon) under the tank and hand drill the tank. Transfer gas to a correct storage container quickly in case it breaks down the Tupperware, spills out, and creates an insane flash fire hazard.
    JustJon likes this.
  5. Sep 6, 2021 at 10:57 PM
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    Good idea, though I would probably disconnect a line under the truck
    I don't think it's possible on a Taco. As someone else has said, your best bet would be to disconnect a line under the hood or possibly along the frame rail.
    FWIW I ran into a similar situation when I worked in Houston immediately following the passage of Hurricane Ike back in '08. I was there for work and everything we had required the use of generators. Gas and Diesel was in very short supply so for the first few days we had to get real creative and thrifty to make what we could get last. When I got back to So.Cal. I decided to get a dual-fuel generator (gas and Propane), my thought being that just about everyone has a backyard BBQ with a Propane tank, so in theory you could stay running even if you couldn't get gas or Diesel. Might be something to look into for next time. Good luck!
    oconnor likes this.
  6. Sep 7, 2021 at 4:00 AM
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    I needed some gas for my lawnmower so go the hose out and stuck it in the taco tank and no way it would go in more than 4 inches so definately a screen stopping it.
    boston23 likes this.
  7. Sep 7, 2021 at 5:54 AM
    ernscott
    ernscott Well-Known Member
    2021 Tacoma
    Will the fuel pump work that way ? I thought it cuts off for safety when it doesn't see some back pressure, in the event that a line would get severed if the vehicle was in an accident.
    There are kits for most generators to convert to propane or Nat. gas. They work great, as I have done a few and set them up on a quick connect. It has been a while but Richard @ Propane Carbs is very versed in the subject. 1-877-425-8383.
  8. Sep 7, 2021 at 6:29 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    While you won't be able to siphon has from the tacoma, its still possible for someone to pour nasty chit in your tank. A locking gas cap helps. Stant makes a good one.
  9. Sep 7, 2021 at 6:50 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I can siphon gas from my taco. I just have to use brake clean straws that're glued together. Takes a while but I filled up 5gals the other day.
    hiPSI and JustJon like this.
  10. Sep 7, 2021 at 8:30 AM
    MinesBroken
    MinesBroken Well-Known Member
    2016 BBP Tacoma Limited DCSB
    Be careful with the locking caps = tried the Stant off Amazon and CEL came on right away. Had to disconnect battery for 10 min to clear it. PITA
    I'd love to find a working lock cap without this issue.
    06Tacooo likes this.
  11. Sep 7, 2021 at 8:44 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Dude. Ike suuuuucked.
    My house was without power for 23 days on that one. Had two cars and decided that we were going to use one at a time. Ran the first car down to 1/4 tank then switched to the other. By the time the second car reached 1/4 tank some stations were starting to open back up.
    Fortunately we had cool neighbors though. Everyone cooked for everyone. A tray of cookies made two laps around our cul de sac. One guy ran extension cords to his welding truck so that those of us without generators could at least keep the freezers from spoiling. I vowed that would be the last storm to be without my own generator.
  12. Sep 7, 2021 at 9:04 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I've been using a Rebranded Stant 10504 for 5 years with no CEL light. Have to make sure it clicks 3 times when putting it on. Other TW members say the 10504 works for them too. I did buy mine at Carquest. I tried a Duralast cap that fit but made the CEL light come on so I believe finding the right cap is hit or miss.
    https://www.tacomaworld.com/threads/gas-cap-lock.716568/
  13. Sep 7, 2021 at 9:08 AM
    zoo truck
    None
    Maybe you got a bad one. I've had mine since i pick up the truck new from the dealer 1 1/2 years ago. Its been fine.
  14. Sep 7, 2021 at 9:13 AM
    MinesBroken
    I took a look at my past Amazon order = mine is a 10504 as well. I might give it another try with 3 clicks. Thanks for listing where you got yours. It's a non expensive item might try one from Carquest as well.
  15. Sep 7, 2021 at 9:39 AM
    Dustin.K96
    Dustin.K96 Well-Known Member
    Dustin
    2019 White Tacoma TRD OR
    A lot of newer vehicles can't have their fuel siphoned out, ours included. But, there's nothing stopping them from making a hole in your tank ¯\_(ツ)_/¯
  16. Sep 7, 2021 at 9:55 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    This is how we used to get gas out of my old BMWs. We just pulled a line from the fuel rail, hooked up a hose and jumped the pump.
  17. Sep 7, 2021 at 10:21 AM
    Kev250R
    Kevin
    Orange, So.Cal.
    Yes, Ike was a heck of a storm! It’s funny you mentioned cookies, working in Houston someone brought my crew and I cookies LOL! We also got invited to a lot of homes for dinners on the weekend. It really showed me how people can come together when they need to.
    RA77 and Rock Lobster[QUOTED] like this.
  18. Sep 7, 2021 at 11:18 AM
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    I hate siphoning gas. It all’s goes back to a moment when we (my friends and I) deemed it neccassary. My friend said “fuck, I really didn’t want to get gas in my mouth today”. Lol.
