Can you recommend a gas can?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NetMonkey, Mar 29, 2014.
  1. Mar 29, 2014 at 12:02 PM
    NetMonkey
    NetMonkey [OP] Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    hey guys,
    I am going to be making a 2000 mile trip while towing a 5000 pound trailer. I already get crappy mpg on the highway as it is, and, with the trailer, I will get 10-12 mpg. so I wanted to give myself a little insurance by bringing along a couple of 5-gallon gas cans. I tried searching on Amazon for an inexpensive gas can, but I cant seem to find one that has good reviews.
    can anyone recommend a good 5-gallon gas can for filling our trucks?
    thanks,
  2. Mar 29, 2014 at 12:08 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Metal for sure! Sure they cost more, but I've never had one leak or release vapor. I've also never had a plastic one that didn't leak. I have 2 5 gallon Just rite cans that I use on trips up in northern Maine and they are awesome...and they don't tip over like the plastic cans. I think Eagle is also another good manufacturer of good metal cans. The metal cans also have longer flexible spouts that fit easily into the gas fill tube opening.
    Just my 2 cents.
  3. Mar 29, 2014 at 12:49 PM
    NetMonkey
    Geogetown, TX
  4. Mar 29, 2014 at 12:51 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Scepter MFC
    Best can you can get if you can find them Stateside
  5. Mar 29, 2014 at 12:56 PM
    OZ-T
    Peter North
    British Columbia
    Scepter MFC plastic cans have none of the issues you mentioned above
  6. Mar 29, 2014 at 1:01 PM
    Anzy
    Anzy Well-Known Member
    Eric
    Pennsylvania
    Did you look into the VP Racing Jugs? I sell them constantly at the shop I manage, nobody ever has any problems with them.
  7. Mar 29, 2014 at 1:07 PM
    Sig45
    Mark
    Maine
  8. Mar 29, 2014 at 1:08 PM
    OZ-T
    Peter North
    British Columbia
  9. Mar 29, 2014 at 1:13 PM
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
    I've had the opposite problem w/ the metal cans. I have('d) the 5 gallon "Jerry" cans that I would use on a rack on my Jeep. It had the metal spout that was flexible and would screw into the can after removing the metal cap. I always leaked using the metal spout and there was always some seepage from the metal cap when the gas would heat up and expand.
    I've been using a plastic 2.5 gallon tank w/ a built in spout and a trigger/lever in the handle to open the spout. I've been very happy with it. The spout is always connected and pours well w/ the extended snout. Easy to control and you can stop the flow quickly by releasing the trigger/lever. And so far have held up fine. Not going to outlast the metal ones but the metal flexible spout begins to break at the flex joints and was always difficult to manipulate.
    I also purchased a plastic tray that would hold two of the plastic tanks w/ a storage tray between the two. It keeps the tanks upright and in place when in my trunk and there was room for a roll of paper towels, additives, etc.
    It's just like this one. You can turn the spout over the can eliminating it's need to be over the edge which helps with space.
    Although it was difficult to find in a Google search for this thread.
    There's been some new laws or regs regarding gas cans that really seem to have upset some frequent users. This can my not be 'legal' anymore. Not sure, but I like mine.
    This is a youtube video review.
    https://www.youtube.com/watch?v=6BswXnS6nmg
    The tray is just like this one except it will hold two cans. One on each side.
  10. Mar 29, 2014 at 1:14 PM
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    I have this one.
    http://www.amazon.com/Eagle-U2-51-S-Galvanized-Capacity-Diameter/dp/B000BQO15I/ref=sr_1_2?ie=UTF8&qid=1396123429&sr=8-2&keywords=eagle+safety+can
    Eagle is made in USA, JustRite is made in China (if that matters to you). I can confirm that the flex nozzle end will fit into my '05 fill hole. The brass end is tight, but I can see if one isn't careful it getting jammed in there by accident.
    I can also confirm that unless you are actively rolling your truck over, this can stays where you put it. The wide base and lower center of gravity help. Also contains fumes (hence the safety), when you pull the handle back to open the spout, it also vents the can. Pricey, but I was getting pissed with the ones you can buy at Wally World or Home Depot breaking, or worse yet, spilling the gas when you pour.
    Chuy and OnHartung'sRoad like this.
  11. Mar 29, 2014 at 1:24 PM
    NetMonkey
    Geogetown, TX
  12. Mar 29, 2014 at 2:40 PM
    Anzy
    Eric
    Pennsylvania
  13. Mar 29, 2014 at 2:54 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    I I've ever used are the normal plastic gas cans you find at Wal Mart. Never had one leak before.
    I plan to get a couple Rotopax gas cans for my truck. They're expensive, but nice.
  14. Mar 29, 2014 at 4:59 PM
    josh0351
    josh0351 Californication
    Josh
    VA
    Supercharged '13 TRD OR | '96 4X4 Reg Cab (RIP)
    Some stuff...
  15. Mar 29, 2014 at 5:37 PM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    Rotopax makes some cool stuff. Not any more expensive than jerry cans. Plus they make locking mounts that hook to the bed rails in our Tacomas. They are perfect for travel/offroading trips. Not a cheap walmart can though.
  16. Mar 29, 2014 at 5:41 PM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    Agreed. I've never seen an issue with these "jerry" cans.
    Frank
  17. Mar 29, 2014 at 6:26 PM
    Daveo
    Daveo Well-Known Member
    MN
    2013 DCSB TRD OR
    So are you guys somehow finding the Specter MFC, or are you taking the ones marked "water" and repurposing them for fuel?
  18. Mar 29, 2014 at 6:35 PM
    MagnumTaco
    MagnumTaco Well-Known Member
    Tony
    New Mexico
    Supercharger, Baja Suspension, TRD exhuast, Stealth pulley.
  19. Mar 29, 2014 at 6:58 PM
    NetMonkey
    Geogetown, TX
    doh :facepalm:
  20. Jul 30, 2018 at 12:36 AM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Do you still sell them?
