Can you guys splain what the idler pulley sounds like when it's going bad?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by drewskie, Dec 4, 2017.
  1. Dec 4, 2017 at 8:32 PM
    drewskie
    drewskie [OP] Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    08 prerunner with the 2.7 55k miles on it, and about 99% of the time I'm driving, I hear a very annoying chirp at low speeds and at idle,that sounds loudest when I shut off the truck. I have read a few older threads that say the idler pulley is a common cause of this. If it's not the idler pulley, what else? Also, I see what appears to be 2 different idler pulleys on the front of the engine. Which one is the culprit usually?
  2. Dec 4, 2017 at 8:55 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Get a long screwdriver or a stethoscope and listen to each pulley. A useful way to tell if it the belt or pulley is to very carefully take a piece of tire chalk and rub it on the belt with the engine running. If it shuts up it's the belt, if it doesn't you have a bad pulley. Use stethoscope to determine which pulley.
    drewskie[OP] likes this.
  3. Dec 4, 2017 at 8:58 PM
    adriancast
    adriancast Well-Known Member
    Adrian
    Ontario, Ca
    2005 Tacoma 4x4 TRD Off-Road
    -2.5 Donahoe Coilovers -All Pro Standard Leaf Pack -All Pro U Bolt Flip Kit -Front/RearWheeler Super Bumps -Extended rear Bilstein 5100s -Flowmaster 40 Series -All Pro IFS Skid -All Pro Transmission Skid -Bruteforce Hybrid Bumper -30" Double Row LED bar -400 Watt Anytime -TRD Seat Covers -ABS Kill Switch -Locking Center Console Mod -Rear Differential Breather -BHLM -Anytime Fog Light Mod -Toyota Hilux Snorkel
    I had the same noise. Took off the belt, and spun the pulleys. One was slow. Replaced with oem pulley and never heard the noise again.
    Don’t go cheap. Get oem
    toyodajeff likes this.
  4. Dec 4, 2017 at 9:03 PM
    drewskie
    Drew
    Burbank, CA.
    Did yours sort of jingle when you shut the truck off? My mechanic changed the belt a short while ago, but noise was still there. I will try taking it off and spinning them. Thanks
  5. Dec 4, 2017 at 9:27 PM
    adriancast
    Adrian
    Ontario, Ca
    No but that annoying chirp. It’s more than likey the pulley. Let us know what happens.
  6. Dec 7, 2017 at 1:33 PM
    drewskie
    Drew
    Burbank, CA.
    One more question. So I took off the belt, and the pulley attached to the tensioner is very slow, could this be the one causing noise? If I understand correctly, I need to buy the whole tensioner assembly because the pulley itself can't be replaced? Is it a bitch to put in?
  7. Dec 7, 2017 at 9:51 PM
    adriancast
    Adrian
    Ontario, Ca
    That’s the only one that’s slow?
    Idk i never done that one. I just ended up replacing an idler puller because that was the slow one. Check some YouTube videos. Idler was simple. Just take off, put new one and torque it down to specs.
    drewskie[QUOTED][OP] likes this.
  8. Dec 7, 2017 at 9:56 PM
    D-Rose
    D-Rose Well-Known Member
    Devon
    Las Vegas, NV
    2011 dcsb tx pro
    Mine made a whine sound almost like a supercharger. It went away when I replaced the 4(?) idlers and belt.
  9. Dec 8, 2017 at 7:32 AM
    JS760
    JS760 Well-Known Member
    San Diego
    2017 DC Sport
    Best analogy I can give too..sounds like a supercharger whine.
    kalaukoa and drewskie[OP] like this.
  10. Dec 8, 2017 at 10:07 AM
    TOP TACO
    TOP TACO Well-Known Member
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
  11. Dec 8, 2017 at 12:18 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    You CAN replace just the idler pulley. However, you should look into the whole pulley kit on RockAuto. Just do them all at one time.
  12. Dec 8, 2017 at 3:17 PM
    drewskie
    Drew
    Burbank, CA.
    A lil update and of course another question..
    I looked underneath the truck after removing the skid plate and noticed a good amount of calcium which my mechanic friend says is a leaking water pump. So, could the water pump be bad at 55k miles, and if it is bad, would it be causing the chirp, or is the leak a different issue than bearings/ etc?
  13. Dec 8, 2017 at 3:35 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    It could be from the water pump weep hole or another coolant leak. But it's most likely the coolant bypass pipe to the heater. It's a plastic pipe behind the intake manifold, bolts on to the the thermostat housing. They are very prone to leaking on a 2.7 2nd gen
    If you get replacement parts for your low mileage truck get oem Toyota. You paid extra to get Toyota reliability, if your fine with a Ford ranger then get them from Auto zone.
  14. Dec 9, 2017 at 2:45 PM
    drewskie
    Drew
    Burbank, CA.
    Thank you, I will go check that out right now. I looked a bit last night but couldn't see it.
  15. Dec 9, 2017 at 4:17 PM
    mercerc
    mercerc Well-Known Member
    Carl
    Palmyra NY
    2011 D-CAB Black TRD Sport, JBL with Sat
    leveling kit, Cooper 255/80R17 tires on 4Runner rims, Leer cap, Ovtuned (not yet working), K&N filter, TRD catback, Riderite air bags
    This....
    If you hear it, fix it soon. I waited on mine and it ruined 3 pulleys when it went.
    Carl
  16. Dec 10, 2017 at 8:51 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Chirping and squealing can be from a lose belt also. If the belt is even slightly loose - it’ll squeak / chirp everytime it slips on the pulley.
    If you take the belt off - spin the pulley by ‘hand’. If it feels rough or gritty, then the bearing is bad.
    If it spins too easily - there’s probably not enough lubrication left in it. Both situations....need to replace it.
    I didn’t have any issues on my 07, but my 96 had a bad lower idler pulley. It would chirp & squeel initially but once the bearing heated up and the lubrication moved around within it - the squealing stopped. That’s just a first sign of a bad bearing.
    At the time - I worked as a Machine Operator. I pressed the bearing out of the pulley and replaced the bearing only (with a basic bearing from a local shop). That was a bad idea. The bearing I bought wasn’t rated for that type of rpm’s. All the lubrication oozed out of it within a few days. I ended up buying the entire pulley (with bearing) from Toyota.
  17. Dec 10, 2017 at 9:45 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Markcal and drewskie[OP] like this.
  18. Dec 11, 2017 at 3:40 PM
    drewskie
    Drew
    Burbank, CA.
    So, just to update in case anyone cares, my noise had nothing to do with the belt or a pulley. It was caused by a very kinked breather hose that came with my Volant air intake. My mechanic friend that found it said it was a lack of crankcase ventilation that was causing the noise, and that it was really bad for the engine....
    zippo88 and JC15Taco like this.
  19. Mar 18, 2019 at 4:39 PM
    Markcal
    Markcal Well-Known Member
    Thanks for the update, wish more TW members were like you. :thumbsup:
