Can you get a flat from a missing valve stem cap?
Discussion in 'Wheels & Tires' started by guruboy, Jun 23, 2011.
  1. Jun 23, 2011 at 8:35 PM
    guruboy
    guruboy [OP] New Member
    Gabriel
    Amherst NH
    02 Regular Cab
    Hi everybody. I was visiting my brother today and I realized I had a flat on my '02 Tacoma right as I pulled into his parking lot. We successfully changed it which was surprising because we are both real dopes.
    The weird thing is, I looked over the tire pretty thoroughly and I couldn't find any damage at all. That's when I noticed that the valve stem cap was missing from the tire. So my simple question is: is this the likely cause of the flat? It is of course possible that I just can't find the damage. I plan on bringing the tire in to see if it can be repaired tomorrow but I was wondering if maybe I just need a new cap and a trip to the air pump.
  2. Jun 23, 2011 at 8:38 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    I seriously doubt there is any way possible air could leak out without the cap.
  3. Jun 23, 2011 at 8:38 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    negative. a missing valve stem cap will not cause a flat. try spraying the bead of the tire or any of the tread with a soap/water combo and see if any bubbles form. if air is escaping from the tire, the bubbles will show where.
  4. Jun 23, 2011 at 8:45 PM
    BLKTRD6SP
    BLKTRD6SP Well-Known Member
    Tim
    Crane Lake Alberta
    09 Black TRD 6 Speed
    2 way remote start,3M rockguard
    Maybe someone took the cap off and deflated your tire!?!
  5. Jun 23, 2011 at 8:49 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    This. Not so much maybe as in definitely.
  6. Jun 23, 2011 at 8:57 PM
    jeckel7234
    jeckel7234 Well-Known Member
    Drew
    VA
    05 Tacoma
    Add-a-Leaf, Leveling Kit, 31.5 Nitto Grapplers, Mag-Lite Mod, Anit-Key in the ignition beep mod, Tail gate theft mod, Trifecta tonneau cover, washable cabin air filter,
    That or if u take ur truck off road much, mud and debri can unseat your bead and deflate ur tire, but if its holding air now somebody loosened ur valve stem
  7. Jun 23, 2011 at 9:01 PM
    guruboy
    Gabriel
    Amherst NH
    02 Regular Cab
    Wow really? The trip I took that ended in the flat was about 20 miles, from a public parking lot where it was unattended for about 45 minutes. It was pretty darn flat when I got to my brother's and as I said I didn't hear or feel anything until right at the end of the drive, which was mostly highway and some terrible Boston roads. Maybe I pissed somebody off on the road and they followed me to the arts and crafts store!
    I guess we'll know the answer when I take it to a mechanic tomorrow. I would love to try something like the soap+water but I don't have the time in the next couple days all things considered.
    Also you guys rock thanks for the replies.
  8. Jun 23, 2011 at 9:02 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
  9. Jun 23, 2011 at 10:51 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    The valve cap does not hold pressure, it's just there to keep the valve stem clean (the little nip that you press down to let air out). It is possible that somehow a tiny rock impacted the valve stem just right, then stuck and let the air out... but that's like a 1:1,000,000 shot, and would probably be the first time in history that has ever happened.
    Maybe your valve stem is loose for some reason... vandal only got it 1/2 way out before you got close and he snuck off?
    There is probably a hole in the tire.
  10. Jun 23, 2011 at 11:00 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    i'd say its more likely than that. i have found dirt in the valve stem on a flat atv tire. BUT on a truck it maybe less likely idk. i found one of mine loos yesterday.
  11. Jun 24, 2011 at 9:27 AM
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    The packing on the shrader valve can deteriorate over time, but usually that sort of leak is extremely slow.
  12. Jun 24, 2011 at 9:51 AM
    guruboy
    Gabriel
    Amherst NH
    02 Regular Cab
    I just got the tire back from the mechanic and turns out it needed to be plugged so it was not (or was very good) sabotage. Thanks again for the info and advice everybody.
