Can you fix a ball joint boot
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aerose91, Aug 8, 2018.
  1. Aug 8, 2018 at 3:20 PM
    Aerose91
    Aerose91 [OP] Well-Known Member
    Connecticut
    07 TRD Sport 4x4
    Just found a pair of genuine toyota LCA's from a guy who took them off after the frame swap. They have 3,000 miles on them. At quick inspection they were good but upon closer i notice there is a small tear in one of the boots. Do you think I'm SOL here? If i pump the joint full of new grease is there anything that can sufficiently patch this? I couldn't find just boots for sale...
  2. Aug 8, 2018 at 3:24 PM
    Clearwater Bill
    Billy
    Largo Florida
    IMHO not patchable.
    And that booger on the threads would need dressing up before installing too.
  3. Aug 8, 2018 at 3:31 PM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    I noticed that, too but was hoping that part would be above the nut. Not sure, though
  4. Aug 8, 2018 at 3:32 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    The boots go through tremendous flex when installed, so any kind of adhesive, liquid rubber, etc. will crack. If the LCA is off the truck, it's relatively easy to replace the ball joint with OEM or $30 Moog (which has the low-profile boots I like). Remove the circlip and press it out with a big vise, hydraulic press, ball joint press, or air hammer.
    Clearwater Bill likes this.
  5. Aug 8, 2018 at 4:13 PM
    Clearwater Bill
    Billy
    Largo Florida
    Could likely be dressed with a die and work fine.
    However, the better plan is to replace the ball joint, as @KenLyns suggests.
    Examine the other one closely too. Better to have 2 new ones than having one fail after installation.
  6. Aug 8, 2018 at 4:24 PM
    Sprockethead
    Sprockethead Member
    Travis
    San Diego
    2006 Tacoma TRD 4x4
    King Performance RR Shocks, Total Chaos upper control arms, OME Dakar Leafs, 2.5 Degree axle shim, carrier bearing drop
    KenLyns likes this.
  7. Aug 8, 2018 at 4:56 PM
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    That's a very bad idea
