Can you adjust Fox 2.0 coilovers on the truck?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sungod, Jan 28, 2020.
  1. Jan 28, 2020 at 8:21 AM
    Sungod
    Sungod [OP] Well-Known Member
    St Augustine
    Installed my 2.0s and seems as they were from the factory they were set at 1" when I was under the impression it would be two so now I need to get another inch. Can these be adjusted on the truck without having to take them off? How many turns would I need to get an extra inch?
  2. Jan 28, 2020 at 8:22 AM
    99GC8
    99GC8 Well-Known Member
    Dwight
    Fort Collins
    2015 Taco supreme
    No you need to compress the spring, if you call fox they can give you the measurements to get to the desired height.
  3. Jan 28, 2020 at 8:26 AM
    Freegolf
    Freegolf Well-Known Member
    Denver
    2016 offroad, manual tran
    FOX 2.0 Performance Coilovers (985-02-002) – Preset for approx. 1” lift over stock
    I think its 2" for 2nd gens and 1" for our 3rd gens.
    Edit: Btw I searched "Fox adjusting" and this immediately came up.
    https://www.tacomaworld.com/threads/adjusting-fox-2-0-performance-series.255857/
    GreyBaldTaco likes this.
  4. Jan 28, 2020 at 8:28 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Isn't it .5 to 1? Half inch spacer would give you one inch lift? Idk how that translates to threads though. When I adjust my I plan on putting a spring compressor on the spring while the weight of the truck is still on the springs. Then jacking the truck up and adjusting. No idea if it'll work.
  5. Jan 28, 2020 at 8:28 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Also, my 2.5's seemed about stock height as well.
  6. Jan 28, 2020 at 8:39 AM
    Sungod
    St Augustine
    Yeah, I saw that, but that is off the truck. I have them installed. I can't believe that you have to take them off and use a spring compressor to adjust. Seems like that defeats the concept of adjustable.
    Freegolf[QUOTED] likes this.
  7. Jan 28, 2020 at 8:40 AM
    Sungod
    St Augustine
    F' me. That is what I get for assuming it would be simple.
    Freegolf likes this.
  8. Jan 28, 2020 at 8:45 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I still plan to do it on the truck.
  9. Jan 28, 2020 at 8:48 AM
    El Chivo Norteño
    El Chivo Norteño Well-Known Member
    Central Oregon
    2020 White DCLB 4X4 Off-Road
    Just know, you run the risk of stripping the threads due to weight / pressure. The 2.0s are made of aluminum and not steel.
    Chew and Skydvrr[QUOTED] like this.
  10. Jan 28, 2020 at 8:50 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Yep! Thanks. I posted my plan a few posts up. If it feels shity I'll just pull the coils and do it off the truck.
  11. Jan 28, 2020 at 8:52 AM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    Spray the threads good with wd40, give it time to penetrate down into the adjustment collar, Jack up the front of the truck so the tires are off the ground, use an adjustment tool or correct punch size and go slow. I’ve adjusted my 2.5 Kings with 700lb springs many times. Just make sure they’re well lubed and go steady, try not to jerk. Remember to loosen the set Allen screw so it doesn’t rip the threads.
  12. Jan 28, 2020 at 9:00 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I was gonna loosen the allen then run it up till the shoulder barley snugs the the lock collar, then adjust. I'm fairly certain my idea will work with the spring compressor
    El Chivo Norteño likes this.
  13. Jan 28, 2020 at 11:09 AM
    Sungod
    St Augustine
    The problem is how much to turn the nut to get the lift you want. While it is a PIA to take the struts off again, I will do it if I can get the adjustments I want if I knew I only had to do it once. Still can't believe that freaking adjustable coilovers have to be removed and compressed. I might as well have saved the cash and just bought 5100s. At least those you know the amount of lift per slot.
  14. Jan 28, 2020 at 11:11 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    At least they're minutely adjustable. As opposed to half inch increments or whatever the 5100's are. Measure the collar as it sits, run it down, remeasure. Sounds easy.
  15. Jan 28, 2020 at 11:28 AM
    Sungod
    St Augustine
    Got off the phone with the guys from Fox. He claims that they are set at the factory to get 2" of lift. He said that the off road and the pro have 1" already which is why I'm only seeing an inch and says that I'm now at 2" of lift over the base model and sport. He also confirmed that the only real way to adjust them is to remove them, compress, and adjust. Obviously I wasn't the first to call since he agreed that this information should be on their website, but they chose not to post it since they figured it would hurt sales. He then went on to say that adjusting them wasn't a good idea because it would compromise ride quality. WTF? Essentially this is pseudo adjustable coil over.
    He did say that for every inch you go up or down in adjustment that you gain double.
  16. Jan 28, 2020 at 11:31 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    That's every single coilover. The more preload the stiffer the ride. There's nothing pseudo about it.
  17. Jan 28, 2020 at 12:20 PM
    Sungod
    St Augustine
    Yes, but Fox is saying not to adjust the 2.0. The 2.5 is ok. That is what is pseudo about this coilover.
  18. Jan 28, 2020 at 12:21 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I thought u said he suggested to, so as not to affect ride quality? Or he said absolutely do not adjust?
  19. Jan 28, 2020 at 12:24 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    He at Fox is wrong there is no height difference in the Off road to the Sport, only the Pro is an 1" higher in front.
  20. Jan 28, 2020 at 12:29 PM
    Sungod
    St Augustine
    He said they don't recommend adjusting because of ride quality, but specifically not to adjust the 2.0s because of that and the fact that it is an aluminum body and collar. Essentially he was saying the 2.0s are for looks.
