Can warped rotors cause traction control activation?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Stompson, Dec 28, 2023.
  1. Dec 28, 2023 at 6:05 PM
    Stompson
    Stompson [OP] Well-Known Member
    VA
    2017 TRD Sport Short Bed MT
    OME Lift > Stage 3 ICON, KDMax Pro Tune Leitner ACS, Decked Box
    So I borrowed my son's 2010 to go snowboarding in WV this week since my RAM is in the shop (yes, I know), and I had some failry significant steering wheel shake on my way back down the mountain this morning. I hadn't noticed it on the way there. It was only happening when the brake was applied. Decceleration by downshifting didn't produce any shake whatsoever, so I assume it isnt' a steering or suspension issue...I would guess warped brake rotors.
    We bought the truck with aftermarket brakes put on by the previous owner because he lived on a mountain and wanted an upgrade. I think they're the powerstops with the red calipers, but I havent' bothered to look yet.
    Anyway...has anyone experienced traction control activation or ABS activiation as a result of warped rotors? I had two alarming instances during braking in a faily tight turn coming down the mountain that caused the truck to damn near lock up. Steering became unmageable and the truck pulled me into the oncoming lane without warning. It felt similar to ABS activation, but the roads were fairly dry, and I wasn't driving agggressively. The lock up was followed by 4-5 quick beeps...then everything was peachy again. I tried to recreate the issue several times but was unable to do so.
    Anyone have similar experience? Insight? I'm going to pull the wheels off tomorrow and look at the brakes, but would like to get some other ideas before getting started.
  2. Dec 28, 2023 at 6:37 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  3. Dec 28, 2023 at 7:12 PM
    Stompson
    VA
    I think the previous owner put some take offs from a 3rd gen on it. Looks like its about 1-2" taller than stock. I did just put a slightly larger tire on the truck about 2 months ago.
    So...this VSC is supposed to modulate the brakes to keep the truck from spinning out of control in hard corners? That's crazy...because it basically caused me to be out of control. I'm not trying to get too deep in the weeds on this, but how does installing larger tires and/or a lift cause this to malfunction?
    Thanks for the info regardless. That's a much better solution than the one I was imagining...
  4. Dec 28, 2023 at 7:36 PM
    Stompson
    VA
    After reading through that thread I'm convinced that I'm experiencing the same thing. The first time it happened I didn't notice any dash light activiation, but it was a rather abrupt experience and I was pretty much in survival mode. The second time it happend I made a point to look at the dash since it felt like an ABS activation...didnt see any lights. Either way, I'll try the VSC thing tomorrow and hope for the best. Thanks again.
  5. Dec 28, 2023 at 7:42 PM
    TnShooter
    Deogee
    STOCK
    In short, it screws with the yaw rate sensor.
    The sensor is calibrated for the stock height and suspension.
    When you switch to deferent suspension components, it reacts diffrent than the stock components.
    The Yaw rate sensor and ABS module see "unexpected" data and activate the ABS to "save itself".
    It is much more technical than that. But that is basically what it does.
    I've said it for years, The ABS in the 2nd Gen is rudimentary at best. I needs works.
    2005-2008 seem to be worse as far as "stopping" when using the abs.
    Most 2005-2008 trucks didn't have VSC, and are better suited for lifting.
    But the ABS SUCKS.......Pulling the ABS fuse is a better option in some case, in my opinion. (on the 2002008 trucks)
  6. Dec 28, 2023 at 7:44 PM
    lr172
    lr172 Well-Known Member
    ‘11 DCLB 4.0 Auto
    Yes, warped rotors can cause steering wheel shake. It grabs harder in one spot vs the rest and this creates a harmonic that will change with wheel speed. This excessive braking in the high spot creates a very mild turning effect and this causes the steering wheel shake. It is basically regular friction followed by excessive friction and repeated at a high frequency. This will not, however, create the stability issues that you mentioned during the turns.
  7. Dec 28, 2023 at 7:45 PM
    TacoTuesday1
    FL
    Stock brakes warp.
    Traction control is not the same as ABS. Older 2nd gens don't have traction control.
    ABS is vehicle detecting loss of tire traction, resulting in application of ABS unit pulsing. Likely through ABS sensors at the hub monitoring wheel rotation.
    ABS is activation is not the same as pulsation from warp.
  8. Dec 28, 2023 at 8:50 PM
    TnShooter
    Deogee
    STOCK
    I’ve never yet warped a set of rotors. And never had pad transfer build up.
    Not even on my 1st Gen running a 70 lbs+ wheel tire setup and towing a trailer.
    My father is a truck driver, he taught us to use our gears and not ride the brake unnecessarily.
    Or maybe I’m lucky?
    I won’t say how much weight I’ve towed with my 2nd. And my trailer doesn’t have brakes.
    I think a lot of warped rotors (if they warp) are due to driving style.
    Now, I will agree that up until about 2017 or so, the Honda SUV and Trucks did have rotor issues.
  9. Dec 28, 2023 at 8:56 PM
    50Buck
    50Buck Living rent free Timmy the Tool's head
    Ideally, braking should be done before entering the turn, not in the middle of it.
    TnShooter likes this.
  10. Dec 28, 2023 at 9:30 PM
    TacoTuesday1
    FL
    Not relevant
    doesn’t matter
  11. Dec 28, 2023 at 9:32 PM
    50Buck
    Moot.
    BKinzey likes this.
  12. Dec 28, 2023 at 9:49 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Brake rotors don't warp in practical non-racetrack use. Could be pad deposits burned onto the rotor surface, could be seized caliper (where 1 or 2 out of the 4 pistons are stuck) due to rust.
    You were probably just experiencing the outdated ABS algorithm on 2nd gens. Hard to say whether you would've stopped sooner with the ABS fuse pulled. Were you in 4hi at the time? 4WD helps to reduce braking distances due to absence of a center diff.
    Stompson[QUOTED][OP] likes this.
  13. Dec 28, 2023 at 9:50 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Sounds like you have a brake pulsation and the VSC needs calibrating.
    Time for rotors and possibly pads, and check the caliper pistons for any sticking
    It doesn't matter if the pulsation is caused by pad material transfer or warping, the fix is the same. Either replace or resurface, I like to replace
    Stompson[OP] and winkel like this.
  14. Dec 30, 2023 at 2:36 PM
    Stompson
    VA
    I was taught this as well. I was downshifting through turns. I've taught my children as well. This wasn't a drving style issue. The steering wheel shake and the ABS/VSC issue were both inconsistent, leaving me to beleive that both issues are stemming from the VSC.
    TnShooter[QUOTED] likes this.
