Can the radio volume nob be replaced?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jross20, Jul 16, 2018.
  1. Jul 16, 2018 at 9:13 AM
    jross20
    jross20 [OP] Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    Since I bought my new to me taco, the volume nob has always been... Odd, it doesn't go up or down it just figits like crazy no matter how you turn it. (As in, you turn it up or down and the volume randomly jumps up and down 1-5 unit's)
    POT switch gone bad I assume, can this be replaced? Or cleaned?
    Didn't see any threads talking about it so here I am :p
    theolee likes this.
  2. Jul 16, 2018 at 11:05 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Nock it around a little bit and it might work.
  3. Jul 16, 2018 at 3:53 PM
    jross20
    Georgia
    Tried, makes no difference at all... Does it come off? I have some POT cleaner I could try.
  4. Jul 16, 2018 at 4:25 PM
    Twitch81
    Twitch81 Well-Known Member
    2019 Double cab Taco 4x4
    Sub'd for ideas. Mine does the same friggin thing!
  5. Jul 16, 2018 at 4:44 PM
    NepaTaco
    NepaTaco Well-Known Member
    Rich
    Pennsylvania (NEPA)
    Black 2006 Taco
    U can pop the knob off just pulls off and try electronic/contact cleaner. It probably won't help much at all. Mine acts the same as yours. It's a fairly common issue with our Taco radios.
    Either use the steering wheel controls or upgrade to an aftermarket head unit. I wouldn't bother trying to fix it beyond trying to clean contacts. Even if that works it's temporary.
    See https://www.tacomaworld.com/threads/volume-knob-quirk.285113/
  6. Jul 16, 2018 at 5:04 PM
    jross20
    Georgia
    Well what I do not understand is that the frequency tuner knob works just fine. Do both of them typically go out? Or just the volume one?
  7. Jul 16, 2018 at 5:51 PM
    NepaTaco
    Rich
    Pennsylvania (NEPA)
    Black 2006 Taco
    Only my volume knob acts up. I haven't seen or heard of the tuner knob doing it. I guess volume gets used more maybe. No idea.
  8. Jul 16, 2018 at 6:59 PM
    Mr. Noun
    Mr. Noun Member
    Oklahoma
    09 DCSB 4X4 Base
    I had this same problem, and pulling the volume knob off and shooting some electronic contact cleaner in the hole worked well for me. I made sure to rotate the knob a bunch after putting it back on and it's held up well for about a year and a half.
    jross20[OP] likes this.
  9. Jul 16, 2018 at 7:09 PM
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    There are replacement knobs available. Can’t find the link but search the forum for “Hondo garage”.
  10. Jul 16, 2018 at 9:40 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The Knob isn't the problem. The problem is the pot inside the stereo. The only good way to clean it is to remove the stereo then open it up to get at the pot windings. Spray them off with contact cleaner along with the wiper arm.
    Or go here: https://www.crutchfield.com/S-Jd9lJr8jFd6/car/carselector.aspx
    And replace it with a good stereo.
  11. Jul 17, 2018 at 7:01 AM
    jross20
    Georgia
    I actually like the stock radio's look. Nice and simple!
    I will try to repair it and post my results when I do. :)
  12. Jul 17, 2018 at 8:09 AM
    NepaTaco
    Rich
    Pennsylvania (NEPA)
    Black 2006 Taco
    Good luck give it a shot and let us know how ya make out .
  13. Jul 17, 2018 at 9:25 AM
    jross20
    Georgia
    Will do.
    Do you or anyone else know of a disassembly guide for the radio?
  14. Jul 17, 2018 at 9:37 AM
    NepaTaco
    Rich
    Pennsylvania (NEPA)
    Black 2006 Taco
  15. Jul 17, 2018 at 9:44 AM
    Mike714
    Mike714 Well-Known Member
    Cypress, CA
    2013 DCSB Prerunner Super White
  16. Jul 17, 2018 at 11:58 AM
    NepaTaco
    Rich
    Pennsylvania (NEPA)
    Black 2006 Taco
    Listen to this man and try swapping. :) Then go get these knobs anyway they look pretty slick. I wasnt willing to buy them. I just use my steering wheel controls until I pony up and buy a new head unit.
  17. Jul 17, 2018 at 9:05 PM
    jross20
    Georgia
    Well it isn't the plastic but the POT , right?
  18. Jul 17, 2018 at 9:06 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    You do realize that the Knob has nothing to do with the volume control right? It is only a piece of molded plastic.
    The little post that the knob goes on and is connected to a variable potentiometer inside the stereo is what actually controls the volume.
    Here: https://www.google.com/search?clien...y-ab..0.15.2360...0i13k1j0i67k1.0.OXpdQvb4hLo
    JdevTac likes this.
  19. Jul 17, 2018 at 9:07 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    No, this is wrong.
  20. Jul 17, 2018 at 9:08 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Yes the pot. Don't listen to the two nonsense post about knob swapping. :rolleyes:
    CurtB likes this.
