Can techstream do zero point calibration?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sean73T, Nov 3, 2018.
  1. Nov 3, 2018 at 9:54 PM
    Sean73T
    Sean73T [OP] Well-Known Member
    Sean
    SoCal
    17 Pro
    Does Toyota use techstream to preform a zero point calibration or some other device?
    Interesting tidbit, the TC goes off all the time on my 18 Sport going in and out of driveways and U turns, but never did on my 17 PRO. Same exact aftermarket lift and tire setup. Maybe theyret running different TC calibrations?
  2. Nov 3, 2018 at 9:58 PM
    Bishop84
    Bishop84 Well-Known Member
    Yes, its an ABS function, normal only an issue if the steering angle has changed, I've never had to do it unless an error was committed.
    Is it possible an ABS line is stretched on the front upper control arms?
  3. Nov 3, 2018 at 10:01 PM
    Sean73T
    Sean
    SoCal
    17 Pro
    Anything is possible. I don't know what to look for, but would pictures be worth a thousand words? Not sure what to take pictures of lol.
  4. Nov 3, 2018 at 11:07 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    If your ABS line was stretched you would get lights. ZPC is needed when the truck is "confused" on it's true zero point, or when it needs to use the vehicle stability control. There is a procedure for zero point from Toyota and there is a procedure for weekend warriors.
  5. Nov 3, 2018 at 11:12 PM
    Sean73T
    Sean
    SoCal
    17 Pro
    It's not the ABS it's stability control.
  6. Mar 5, 2019 at 10:53 AM
    JPatzig
    JPatzig Active Member
  7. Mar 5, 2019 at 10:57 AM
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
  8. Mar 5, 2019 at 10:59 AM
    JPatzig
    Paul631[QUOTED] likes this.
  9. Mar 5, 2019 at 11:10 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    3rd gen...
    xxTacocaTxx likes this.
  10. Mar 5, 2019 at 11:45 AM
    JPatzig
    Did this work for you personally on your 3rd gen? Not trying to call you out, I just tried this method probably a dozen times, different days, with every trick I could think of...I never got it to work.
  11. Mar 5, 2019 at 11:52 AM
    splitbolt
    NW Arkansas
    Yes.
    Here's the Techstream version...
  12. Mar 5, 2019 at 11:56 AM
    JPatzig
    Awesome, thank you. I'll give the wire short method one more shot. Then I'll try out techstream.
  13. Mar 13, 2019 at 6:15 PM
    Hookedup
    Hookedup Well-Known Member
    SOFLO
    2012 DCSB SPORT/ 2019 OR DCSB
    FOX 2.5 DSC/ICON RXT/SPC UCA
    @Sean73T any updates if techstream worked? Currently have VSC light and pre collision lights on after 2.5” lift..
  14. Mar 14, 2019 at 6:58 AM
    JPatzig
    You can use techstream to reset codes and/or do the VSC re-calibrate. All I had to do was clear my codes, and a week later, my VSC and pre collision errors have not come back up. But I did see the re-calibrate VSC option in techstream.
  15. Mar 14, 2019 at 8:03 AM
    Hookedup
    SOFLO
    Ok.. dealer didn’t charge me to do zero point calibration.. although my pre collision light came back up 5 min down the road.. different message this time.. ‘clean sensor’ i do have aftermarket garnish and grill.. i have to go to work now.. will remove garnish and see if it comes back up..
  16. Mar 14, 2019 at 8:06 AM
    JPatzig
    Well that's a nice dealership. I was told $130 to even look at my truck, and as soon as I rolled in "we can do the calibration, but won't on a lifted truck".
    I'm sure it just needs to be cleaned, I have a stock grille, and I've had that error pop up 2 or 3 times.
