Can someone tell me what this little tab is above the P on shift display?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTakeover, Mar 27, 2015.
  1. Mar 27, 2015 at 2:25 PM
    TacoTakeover
    TacoTakeover [OP] Well-Known Member
    Can it simply be lifted up to open?
  2. Mar 27, 2015 at 2:28 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    Manually unlocks the transmission or something to that nature. I've seen it mentioned in a few threads where people were stuck in park.
  3. Mar 27, 2015 at 2:29 PM
    FooBird
    FooBird Well-Known Member
    Kirkland, WA
    '14 DCSB 4x4 TRD Off Road
    Undoes the P lockout. If you need to be towed, pull that cover off, push in the button and you can take the truck out of Park without the truck running.
    TRDSport10, wi_taco and t.hornstra like this.
  4. Mar 27, 2015 at 2:30 PM
    TacoTakeover
    Do you know if it can simply and safely just be opened without messing up anything? I have a lot of dirt/debris I wanted to clean out of it.
  5. Mar 27, 2015 at 2:31 PM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    ^^^^yup you popthat thing off and you can manually depress the switch so you can get out of park with out depressing the brake pedal. I think you also use it to take off the center console because you have to more the shifter down iirc
  6. Mar 27, 2015 at 2:32 PM
    FooBird
    Kirkland, WA
    Stick a plastic trim tool or a flat head screw driver with some tape/towel around it in the gap and pry it up. It moves quite easily.
  7. Mar 27, 2015 at 2:34 PM
    JdevTac
    Josh
    GA/WA
    2nd gen
    Just pull up the latch and go at it with a vacuum or something and you should be fine cleaning it out.
    If you mean remove the center console plastic around the shifter, you don't need to mess with that latch. Just pull up at all 4 corners. The PRND portion just snaps in place as well.
  8. Mar 27, 2015 at 2:34 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    there's a self destruct button under that tab.
    stun gun likes this.
  9. Mar 27, 2015 at 2:38 PM
    FooBird
    Kirkland, WA
    The dealer tried to deliver my truck without it. While signing off paperwork to buy the truck I mentioned that this was missing and that they should fix that. Two days later when I took delivery of the truck, I asked if they fixed it - nope. Got the cover in the mail a week later.
  10. Mar 6, 2020 at 4:54 PM
    TheDirtyCurty
    TheDirtyCurty Member
    Curty
    WA
    2021 TRD OR Long Bed
    Is there anyway to replace this tab? It’s stuck in the up position and have to manually depress it when I need to get into drive. Any suggestions besides cramming something in there?
  11. Mar 6, 2020 at 9:41 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It is supposed to be UP.
    You should not have to press it Down if your foot is on the brake pedal while trying to shift.
    Are your brake lights working?
    ImMrCrash and Muddinfun like this.
  12. Mar 7, 2020 at 11:44 AM
    TheDirtyCurty
    Curty
    WA
    I will check when I get back. Thanks for the tip. It just seems backwards to me
  13. Mar 7, 2020 at 11:54 AM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Shift lock override button. It is to allow you to shift out of P with a dead battery or faulty shift lock solenoid. The cover does not come installed from the factory but in a little bag tied around the shifter. It is installed during PDI but can often be misplaced especially during dealer trades.
    It’s really cheap if it’s missing and can be had from any Toyota dealer.
    33554-04060 - Cover, Shift Lock (2005-2015)
    Jeff
    TRDSport10 likes this.
  14. Mar 8, 2020 at 6:57 PM
    TheDirtyCurty
    Curty
    WA
    It was a 10 amp fuse under the hood labeled as STOP if anybody runs into the same issue
  15. Mar 8, 2020 at 8:49 PM
    Muddinfun
    Muddinfun Well-Known Member
    So, your brake lights weren’t working. Do you have any idea when and why the fuse blew? Towed a trailer lately? Janky wiring on a topper 3rd brake light?
  16. Mar 9, 2020 at 7:40 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    That's the ejector seat.
  17. Mar 9, 2020 at 7:45 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
  18. Feb 4, 2022 at 8:08 PM
    TheDirtyCurty
    Curty
    WA
    LATE late reply but yes the brake lights were not working and it was from a leaky topper into the 3rd brake light. Ended up driving home for 2 hours and thankfully didn’t cause any wrecks. Hand signals the whole way.
    IF you have the same issue… PLEASE CARRY FUSES IN YOUR TRUCK. I was blessed to make it home on snowy roads but not having brake lights without knowing is noooo good. Hopefully some 2nd gen people see this.
    OffroadToy likes this.
