Can someone explain tire offset
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bronson2017, Mar 16, 2020.
  1. Mar 16, 2020 at 4:23 AM
    Bronson2017
    Bronson2017 [OP] Active Member
    Alabama
    2019 TRD OR MGM
    I have noticed in the Ray 10 thread people making the comment of their off set after putting new wheels and tires on. Are you referring to how far out the tires are from the sides of the truck?
    Do the wheels or tires cause this? Or is it a combination of both?
    Also why does it cause this? Thanks!
  2. Mar 16, 2020 at 4:30 AM
    HTeeAre
    HTeeAre Well-Known Member
    2016 Quicksand TRD OR 4x4
    Offset is how far the mounting point on the wheels is in comparison to the actual center of the wheel. Positive offset means the mounting point on the wheels is between the actual center of the wheel and the "outer" (away from your vehicle) portion of the wheel. While negative offset is the opposite. For the Tacoma generally lower offset is good (not too low) to prevent the big tires that some will run from rubbing. Plus most generally agree it looks better than a sunken in wheel.
    Norsemanvike likes this.
  3. Mar 16, 2020 at 4:34 AM
    lynyrd3
    Bill
    East Central Upstate NY
  4. Mar 16, 2020 at 4:37 AM
    HelloMyNameIs
    HelloMyNameIs I know words, I have the best words.
    2018 TRD Off Road in Cement
    OME 2885, Billie 5100s, HS Prog AAL, 255/85r16 Cooper ST Maxxs
  5. Mar 16, 2020 at 4:38 AM
    lynyrd3
    Bill
  6. Mar 16, 2020 at 5:23 AM
    Bronson2017
    Alabama
    2019 TRD OR MGM
  7. Mar 16, 2020 at 11:24 AM
    evdog
    evdog Well-Known Member
    San Diego
    2019 DCLB TRD OR
    Do a youtube search. There are some great vids that will show examples of each type and explain applications
