can someone explain how cold weather kills MPG?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by xGRIMEYx, Nov 16, 2019.
  1. Nov 16, 2019 at 8:09 AM
    xGRIMEYx
    xGRIMEYx [OP] Go follow #RheaTheGray on IG!
    RheaTheGray
    fort worth, tx
    17’ TRD PRO
    Fox 2.5s w/resi SSO slimline front bumper OVTune 1.05 SCS ray10s 285/75/17 KO2s JL Audio C5s Rigid Industries ditch lights & light bar Warn VR8-S gen II RCI rear bumper 5.29 nitro gears UpTopOverland roof rack TJM sliders ARB twin compressor bed mounted
    this is crazy to me! all conditions were the same, i make the same drive every day for work! one day it was 20s and 30s and i got 14.5 mpg. A few days later it’s in the 50s and 60s and i’m back to getting 17mpg on the commute
    am i missing something or is this normal and i’ve never noticed it before?
  2. Nov 16, 2019 at 8:21 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    From fueleconomy.gov
  3. Nov 16, 2019 at 8:22 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Big drop in tire pressures.
    hiPSI, Chew, jmneill and 4 others like this.
  4. Nov 16, 2019 at 8:24 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    How long do you sit idled in the coffee line when its cold?
  5. Nov 16, 2019 at 8:25 AM
    Mopar Mussel
    Mopar Mussel Well-Known Member
    Jurgis
    2018 TRD Sport, 2006 SAAB 9-5 Aero
    Cold air is denser than warm air. More air molecules are being sucked in by the engine for the same volume of air, so maybe more gasoline is needed to burn optimally.
    That's what I would guess, but math and science are not my strong suit.
    EDIT: I forgot that everything has electronic throttle bodies these days. Do electronic throttle bodies adjust at all based on temperature, I wonder? If so, this might be more of an issue for cable-controlled throttle body vehicles.
    jowybyo likes this.
  6. Nov 16, 2019 at 8:26 AM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    ^^This for sure I know as fact^^ :rofl::rofl:
    hiPSI likes this.
  7. Nov 16, 2019 at 8:27 AM
    Bishop84
    Bishop84 Well-Known Member
    This is the only answer.
    Painter99 likes this.
  8. Nov 16, 2019 at 8:29 AM
    calebc
    calebc Well-Known Member
    Everything being correct and equal from the list posted above (i.e. tire pressures are correct, your vehicle is at operating temperature, etc) then the biggest factor is the gasoline. Cold air is more dense so you get more air in to the engine, so that helps offset any additional drag that extra density is causing. The thing about making your alternator work harder because of the electronics, I don't buy. The alternator puts so little drag on the system that I doubt it makes any difference. On the flip side, your AC compressor in the summer puts way more drag on the system than the alternator. So the biggest difference is the fuel, winter blends vs. summer blends.
  9. Nov 16, 2019 at 8:30 AM
    Bishop84
    Alternators make a huge difference, the recharge of the battery after cold start is a huge draw. Also just using more current with heaters uses fuel.
    Have you ever used a battery charger on 60 amps? The lights dim when you turn that sucker on.
    The hammer likes this.
  10. Nov 16, 2019 at 8:33 AM
    OzarksAGD
    OzarksAGD Well-Known Member
    Andrew
    Fayetteville, Arkansas
    2017 Tacoma TRD OR
    The .gov post above mentions it, but winter gas is usually less efficient than summer gas.
    BlackMetalSteve likes this.
  11. Nov 16, 2019 at 8:33 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    I'm not riding my bike in the cold weather
    idataco97, Spare Parts and The hammer like this.
  12. Nov 16, 2019 at 8:34 AM
    calebc
    It's not the draw that makes a difference. It's the amount of resistance the alternator put on the engine that makes it have an impact and if you've ever spun an alternator by hand and generated power, you would know there's almost no resistance. No go spin an AC compressor that has the clutch engaged pumping freon through the system and you'll quickly see how big of a difference it is.
  13. Nov 16, 2019 at 8:34 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    In TX, essentially the same impact as western WA: Winter fuel is #1 killer.
    "Winter grades of gasoline can have slightly less energy per gallon than summer blends."
    I absolutely now know this as fact.
    Given: Refinery blenders say winter fuel is being delivered. Step A.
    Step B: Temperature is the same or actually goes UP.
    MPG drops............across multiple vehicles.
    That is NOT some weather induced MPG loss. Period.
    PS there are multiple exact threads on this.
    cruxofthebisquit likes this.
  14. Nov 16, 2019 at 8:36 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
  15. Nov 16, 2019 at 8:38 AM
    The hammer
  16. Nov 16, 2019 at 8:43 AM
    Bishop84
    They can use from 3-4 hp, not as much as an ac compressor, but thats a lot when you consider how little power is made under 2000 rpm.
    Modern cars have current sensors to help reduce load from the alternator simply for fuel economy.
    Saying alternators don't cause fuel loss is like saying 285's don't rub.
    hiPSI and The hammer like this.
  17. Nov 16, 2019 at 9:04 AM
    ABA180
    East Bridgewater MA
    Too cold in New England winters for this, plus I'd rather not ruin it..
  18. Nov 16, 2019 at 9:22 AM
    xGRIMEYx
    RheaTheGray
    fort worth, tx
    17’ TRD PRO
    thanks for all the good info guys, i was thinking tire pressure at first too but then i raised them to what they were when it was warmer and still low mpg... also i don’t let my truck idle or warm up, i get in a go. but sounds like fuel may be a key factor here which i had no idea
  19. Nov 16, 2019 at 9:35 AM
    [KD]
    [KD] Used Import
    Dan
    Halifax, NS
    06 DCSB 6MT
    Does anyone here have URD's O2 sensor simulator? I know the computer runs a rich tune to get the cats up to temp but if it thinks they are already running optimal will it lean out?
  20. Nov 16, 2019 at 12:15 PM
    WOTaco
    WOTaco Well-Known Member
    NY near the old capital
    2016 MGM DCSB TRD OR MT
    I can get 91 octane non ethanol fuel all year round, I maintain my tire pressure. I commute 50 miles a day, don't warm up my truck. It makes no difference. I chalk it up to the dense air as stated above. It does seem more drastic with this vehicle than any other I've had, and I've had many.
