Can I tow 5000 to 5500 pounds with 2004 Tacoma SR5, TRD, no tow package.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dadio, Oct 23, 2016.
  1. Oct 23, 2016 at 10:04 PM
    Dadio
    Dadio [OP] New Member
    Larry
    2004 tacoma v6
    Transfer cooler
    Thank-you, Sandman614 for listing a good bumpstop link.
    I have a 2004 Toyota Tacoma SR5 with TRD, v6, automatic trans, some kind of large extra cab and no tow package.
    I have been pulling a large ten trailer (about 1800 lbs dry), with a class III hitch, a connection that runs the lights, charges the battery and operates the trailer's brakes.
    I would like to pull a Lance 1685 (4150 lbs dry with options, 435 hitch weight (dry).
    I called Toyota to find what I lack. They said transmission cooler, some radiator difference,
    and a more powerful alternator. They said there was no difference in the suspension. There was no mention of extra engine oil cooling. The difference in tow rating is 3500 vs 6000 lbs (10% for hitch weight)
    So I had Toyota install the transmission cooler.
    I am looking into what Toyota recommends for an upgraded hitch system (weight distribution plus sway control?). I have only used direct connect with the tent trailer.
    I would certainly enable the "no overdrive" mode and adjust the gear to stay < 3500 RPM especially when going up hills.
    Do you think I can tow the Lance with the above mods? My wife would really like this model rather than a Jayco Hummingbird at 1000 less lbs than the Lance. I hope you all can give me some confidence in towing the Lance.
  2. Oct 24, 2016 at 3:05 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Define your idea of Towing !!
    Is this like once a year to the camp ground in the spring and home before the winter snows.
    Hooking to the camper and hitting every state but Hawaii .
    Funny how the empty weight can easily double or more just for a weekend
    Myself a Tacoma would never be my first choice to tow anything unless I had no other option
    We all do what we have to at times
  3. Oct 24, 2016 at 7:36 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    This is the kind of hitch you need. http://www.ebay.com/itm/EAZ-LIFT-WE...ash=item5d693e2660:g:TsEAAOSwYIxX7U9m&vxp=mtr Learn how to properly use it. Trailer should be level, after accounting for truck sag. So many people use them incorrectly, not transferring any weight to the front wheels, trailer sag, etc etc. Other thing, and maybe most important thing is a brake controller. Going is rarely the problem, stopping in a reasonable distance is. http://www.ebay.com/itm/Tekonsha-90...ash=item3acfea1fc7:g:818AAOSwhcJWKODa&vxp=mtr is a a necessity.
  4. Oct 24, 2016 at 12:56 PM
    Dadio
    Larry
    2004 tacoma v6
    Transfer cooler
    Thanks for the links vasinvictor.
    Wyoming09: I would like to use the RV up to 6 times a year (from 50 to 300 miles one way).
    There would be some grades since I live in southern California.
    There is about a 20 mile long grade the last 25 miles to Mammoth Lakes, CA.
    I am looking to buy an RV, not spend $30k+ for another truck right now.
    If I ever had to replace the current truck in my lifetime, I would buy a truck with a tow package that can
    handle the weight.
  5. Oct 24, 2016 at 4:13 PM
    The Driver
    The Driver Trail Runner/Barefoot Beach Runner/Snow Skier
    Raph
    Lakewood (Green Mountain), CO.
    '02 Extra cab 4X4 TRD SR5 3.4
    Aftermarket tranny cooler, 5100 Series Bilsteins, ToyTec Bilstein front coilovers, SPC UCA's, Alcan leafs, Class 3 Hitch, Tundra Front Brakes,
    Yes you can. Just install a tranny cooler, and voila. Well tranny cooler and then a hitch.
  6. Oct 24, 2016 at 6:07 PM
    Aught2TaCO
    Aught2TaCO Well-Known Member
    Troy
    Wheat Ridge, CO
    '02 Taco TRD, aka Pearly
    Billie 5100's, new leafs, Falken WILDPEAK A/T 3W, 265/75/16E
    Is the frame boxed after the rear axle? If not, look into it. What's the condition of the transmission? These A340F transmissions don't like to work much harder than they have to. The PO for mine put a popup camper in the back of it to explore Colorado, and probably didn't take it out of OD for a fair amount of time, resulting in me inheriting the problem (bad tick in the pump) that popped up last year. The OD gets burned up when activated during towing or hauling, here is an excellent write up on the A340 series by a very informed member, gearcruncher. Look at his pic in his signature. https://www.tacomaworld.com/threads...sions-write-up-your-4-speed-automatic.325531/
