Can I Fit 255/85/R16 mud tires on a stock Sr5 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Guitarrocks, Jun 17, 2022.
  1. Jun 17, 2022 at 1:44 AM
    Guitarrocks
    Guitarrocks [OP] Active Member
    2020 Sr5 Tacoma
    None
    I have a 2020 Tacoma I put it through more mud holes stock than I see most people with nice builds, I am currently on 30” tires and they’ve finally gone out so I was curious cause I’ve seen around that you can fit 255/85/R16 on a stock Tacoma but all threads I find are Trd off roads and pros. Curious if this is true for Sr5? Any help appreciated!
  2. Jun 17, 2022 at 4:32 AM
    SnuggleTruck
    SnuggleTruck Well-Known Member
    Alex
    Fort Myers
    2020 DCLB TRD OR
    TRD 2" lift shocks Icon AAL (gave me 1" lift with OL leaf out) 17x8.5" -12mm Trail Edition OEM replica wheels by FSW BF Goodrich KO2s (285 70 17) ECGS bushing OME carrier bearing drop kit TRD Pro skid plate Truxedo roll up Tonneau cover MESO - led interior light kit, blackout kit and gashole Toyota door sill protectors and bed mat
  3. Jun 17, 2022 at 4:33 AM
    SnuggleTruck
    Alex
    Fort Myers
    2020 DCLB TRD OR
  4. Jun 19, 2022 at 6:55 AM
    herrindude
    herrindude 1996 2.4 extra cab auto
    Fairhope al
    2021 dclb sr5
    ARE camper shell
    No 265/75r16 is the largest tire for stock taco. They are 31.6 tall. The 255/85's are 33 inches tall. They will not fit stock setup.
  5. Jun 19, 2022 at 9:05 AM
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    Except for all the people who are running 255s on stock suspension without rubbing. It takes the stock OR wheels (or other wheels with the same +25mm offset) to make it work. I believe the SR5 wheels are also 25mm, but someone with an SR5 should confirm that.
    HighCountryTacoma likes this.
  6. Jun 19, 2022 at 9:45 AM
    Guitarrocks
    2020 Sr5 Tacoma
    None
    Can confirm +25 mm
  7. Jun 19, 2022 at 9:46 AM
    Guitarrocks
    2020 Sr5 Tacoma
    None
    Too late but I appreciate it! I’m putting them on Tuesday I’ll let you know if they fit or not.
    boston23 and Tocamo like this.
  8. Jun 19, 2022 at 10:49 AM
    calzonical
    calzonical Without the 2nd, there is no 1st.
    2018 Taco TRD OR DCSB A/T
  9. Jun 19, 2022 at 11:26 AM
    herrindude
    Fairhope al
    2021 dclb sr5
    ARE camper shell
    So the post "largest tires on a stock taco " is wrong?
  10. Jun 19, 2022 at 11:32 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    The stock tires are 30.5”-30.6” which is typically rounded up to 31”. All the 3rd gens are the same as far as tire fitment (and many other things) go.
    tcjacado likes this.
  11. Jun 19, 2022 at 12:09 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    You have to take into account "special" circumstances. The 255 tires are entry level skinnies so "special".
    The height is not the only factor. There is the width. The 255's are ~1/2 inch skinnier than the 265's. Thus do not rub while turning.
    255/80 17's
  12. Jun 19, 2022 at 3:01 PM
    brian2sun
    California
    There are 100s of “biggest tire” threads on the web, and many of them are wrong. There are a few long running threads on here with tons of people confirming 255s do fit perfectly as long as they’re on 25mm offset wheels (what the factory OR and SR5s are).
  13. Jun 19, 2022 at 3:53 PM
    runandgun18
    runandgun18 Well-Known Member
    Nate
    Arizona
    20 MGM SR 4X4
    Try again bub. Only speak on things you know.
  14. Jun 19, 2022 at 3:54 PM
    runandgun18
    Nate
    Arizona
    20 MGM SR 4X4
    255 85 16
    Junkhead likes this.
  15. Jun 19, 2022 at 4:00 PM
    HellRazur
    HellRazur Well-Known Member
    Stafford Va
    2018 Inferno Off Road 255/85r16 Yokohama Geolandar MT
    Sport bar, air horn, 255/85r16 Yokohama Geolandar MT
    255/85r16 Yokohama Geolandar MT stock suspension and wheels. All I had to do was remove my front mud flaps. 20220618_203140.jpg
  16. Jun 19, 2022 at 4:04 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Nope, 255/80/17s or 255/85/16 will fit on a stock setup.
    Tocamo likes this.
  17. Jun 19, 2022 at 4:05 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    255/80/17 over here, love it!
    Tocamo likes this.
  18. Jun 19, 2022 at 4:17 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Are those E rated?
    Junkhead[QUOTED] likes this.
  19. Jun 19, 2022 at 4:24 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Yessir, only 52 pounds each.
  20. Jun 19, 2022 at 4:33 PM
    Vlady
    Issy, WA
    I'd love to get that size.. Only the weight stops me...
