Can i drive with a leak in my radiator?
Discussion in 'Technical Chat' started by LuvMyTacoma03, Feb 5, 2021.
  1. Feb 5, 2021 at 7:52 PM
    LuvMyTacoma03
    LuvMyTacoma03 [OP] Well-Known Member
    2003 Red Tacoma trd
    I took my truck in today for an tire rotation and oil change. The service rep told me my radiator was dry and there is a leak in the seam. they filled the radiator and told me to keep an eye on it... I should of looked at it then but it seemed like it wasnt an immediate repair so i drove home. I looked at it when i got home and there is a significant amount of antifreeze or water all over the place!! So it clearly needs to be fixed right away!!!
    Am i able to drive to the mechanic while my radiator is not holding pressure as long as i fill the radiator before i go? its a 30 min drive. I really cant afford to get the truck towed so i could possibly get a mobile mechanic to my home but this will be really expensive!! if i can make it to my mechanic that would be ideal.. I definitely don't want any further damage to the truck like a loss of engine. im leaning toward mobile mechanic but its soo expensive!!!
  2. Feb 5, 2021 at 7:55 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I'd pack a bunch of water and stop every few minutes if I had to.
    On the other hand, radiators in these trucks are super easy to replace. You might be able to do it.
    srmanuel and LuvMyTacoma03[OP] like this.
  3. Feb 5, 2021 at 7:57 PM
    GreenYoda
    GreenYoda Well-Known Member
    Talk it over with your mechanic. I would not chance it, or it could cause more damage.
    LuvMyTacoma03[OP] likes this.
  4. Feb 5, 2021 at 8:03 PM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    Not a good idea to take a 30 min drive with a large, visible coolant leak to avoid a tow bill, no.
    Good luck and don’t overheat your truck.
  5. Feb 5, 2021 at 8:05 PM
    0xDEADBEEF
    So I'm suspicious now. How did you make it to the shop today with an empty radiator? Have you seen the actual leak?
    Not calling bs, but worried the shop might be pulling something.
  6. Feb 5, 2021 at 8:32 PM
    LuvMyTacoma03
    2003 Red Tacoma trd
    I agree with you and i'm wondering the same thing!!! i took my truck to wheel works and i refuse to do any repairs there because i don't trust them.. I bought my tires from them so i only use them for free tire rotations.. i decided to get an oil change too because i was planning on taking a long distance trip out of town tomorrow and it needed to be done.. I'm starting to regret my decision and honestly hope they didnt do something to my radiator just to make a profit..
  7. Feb 5, 2021 at 8:37 PM
    0xDEADBEEF
    I'd fill it up, park it somewhere where a leak won't be a problem, start it up and let it idle. You should be able to get an idea of where it's leaking pretty quick, then shut it down. Take some pictures of the spot and post them up here, then we'll go from there.
  8. Feb 5, 2021 at 8:41 PM
    LuvMyTacoma03
    2003 Red Tacoma trd
    ok!!! ill do it in the morning good idea thanks! I just posted a thread in my neighborhood forum so maybe someone can help me out. i live in the mountains so there is not a mechanic right down the street.
    wilcam47 and 0xDEADBEEF[QUOTED] like this.
  9. Feb 5, 2021 at 8:50 PM
    YOTA 4X4
    YOTA 4X4 Well-Known Member
    2017 Double Cab Off-Road
    OME HD Lift all around, SCS SR8 Rims, 255 85 R16 Cooper ST Maxx, Decked Drawers, 30" Rigid Pro Light bar above bumper on Rago Mounts, Rigid Dually Side Shooters on Rago ditch brackets, Hondo Garage Un-Holey Phone Mount X2, Hondo Radio Knobs AR Bolt Face, Garmin InReach SE GPS synch'ed to Iphone for GPS only mapping, Wet Okole Seat Covers, Husky Liner Contour floor mats, 63 QT ARB Fridge on Alu-Cab tilting slide. GoFastCamper (#41), ARB 2500 Awning with Full Room, Mobtown Off-road Sliders and Full Aluminum Skids.
    Yes, for a little while... answer to the question in your title.
  10. Feb 5, 2021 at 9:21 PM
    LuvMyTacoma03
    2003 Red Tacoma trd
    Thank you for all your responses! sounds like i should get a mobile mechanic.. So this i what i will do. :thumbsup:
  11. Feb 5, 2021 at 9:32 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    If the leak is in top part of the radiator, it will be fine to drive, you drove it home right? My toyota had a leak on a seam on top part of the tank. I just top it off till i got my radiator in the mail and changed it out
  12. Feb 5, 2021 at 9:49 PM
    LuvMyTacoma03
    2003 Red Tacoma trd
    i did drive it home. im pretty sure it is on the top part. ill take a look at it tomorow. im still thinking not sure if i should risk it.. 30 min its kinda a long way!!!
    wilcam47[QUOTED] likes this.
  13. Feb 5, 2021 at 9:52 PM
    ahkouchi
    ahkouchi Well-Known Member
    Andrew
    Big Island Hawaii
    2016 Magnetic Gray Metallic Tacoma
    Front Elka 2.5 non resi with 650lb spring Rear Serviceable 5160's with AAL 265/75/r16 BFG KO2
    JB weld... lol but srsly, works in a pinch
  14. Feb 5, 2021 at 10:10 PM
    shift957
    shift957 Well-Known Member
    Cacapon River, WV
    11 AC OR
    Pinch? Ha, that's my preferred method of fixing if the leak isn't some big crack. I've fixed at least 6 radiators without issues. Motorcycles, car and pick up. Just gotta clean the surface real good and let it cure proper. :thumbsup:
    wilcam47 likes this.
  15. Feb 5, 2021 at 10:13 PM
    LuvMyTacoma03
    2003 Red Tacoma trd
    wish i had some... closest store is 10 miles away
  16. Feb 6, 2021 at 8:32 AM
    MR5X5
    MR5X5 Well-Known Member
    Unless it is puking water it is fine to drive. Bring an extra gallon, keep an eye on your thermostat and go get what you need. Not a big deal.
    shift957 and lonedrake like this.
  17. Feb 7, 2021 at 4:23 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Get a friend go buy a radiator gets some clamps in case change it out.
    unless you have a physical limits you can change it yourself.
    Years ago I had a slight leak in the radiator that became a flood ." The boss says just add water " i say it runs out as I pour it in" Tow truck ride was not fun.
  18. Feb 8, 2021 at 2:13 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Here’s what to do. Fill the radiator up then drive around close to where you live, say within a mile or 2 of home. Stop and check the fluid level every 15 minutes or so. Make a decision from that if you can safely make it to town. If after a half hour you’re still good fluid wise you are probably good to head into town.
  19. Feb 8, 2021 at 2:23 PM
    Beerline123
    Beerline123 Well-Known Member
    07 Tacoma access 4x4
    Be careful opening radiator cap
