Can Bed Outlet charge a Bluetti AC180
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lag7, Sep 10, 2023.
  1. Sep 10, 2023 at 10:35 AM
    lag7
    lag7 [OP] Well-Known Member
    Central Arkansas
    2019 Tacoma TRD Pro Super White
    I am looking to upgrade my 500 watt hour portable power station. I currently plug in my 12v fridge into the power supply and then plug the power supply into the bed outlet and charge while driving. My current power station has the "brick" included in the power cable. Can anyone confirm that the AC180 will charge from the bed outlet in a '19 Tacoma? Thanks.
  2. Sep 10, 2023 at 10:52 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I would not recommend it, purely from an efficiency issue. To charge your power station you are going from a dc system to an AC inverter to a DC converter to a DC battery bank. That's two spots where you're losing electricity to the heat of conversion. It can be done, it's just not efficient.
    If you're powering off the truck, try to keep it in DC mode all the way, if you can. I would personally install a DC outlet in the bed for such things. It would eliminate the worry of overloading the relatively weak 400w inverter.
    soundman98 likes this.
  3. Sep 10, 2023 at 11:19 AM
    aarcarr
    aarcarr Well-Known Member
    Arizona
    23 Tacoma TE | 18 4Runner SR5
    08 4Runner SR5 sold 03 Tacoma TRD sold
    What power station do you use currently?
    I have an eco flow river max that runs my fridge. I tried charging the EcoFlow with my bed outlet while traveling to our site and realized the battery was not charging at all. Seems like the EcoFlow doesn’t like the AC inverter on the Tacoma. My EcoFlow charges at 100w by DC and will charge up to 600w by AC.
  4. Sep 10, 2023 at 1:10 PM
    dietcokefiend
    dietcokefiend Well-Known Member
    Look into the 24v DC converter for charging portable power stations. Most cap out like 120-150W with 12V, but you can double the watts getting up to 24V for much faster Dc charging in a car or truck.
    The onboard inverter sucks for multiple reasons. Even if you do the 400W all the time mod, it's a modified square wave output that most portable power stations will reject for incoming AC charging.
