Can a stone or something get lodged between the disc and the pad? Funny noise.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by glennv, Jan 15, 2010.
  1. Jan 15, 2010 at 6:34 PM
    glennv
    glennv [OP] Well-Known Member
    Was driving home today and got this screeching sound that came from the right front wheel. The only sound I can compare it to is like I was dragging a wire coat hanger or something. Pulled over and checked after about 50 ft. Saw nothing wrong. Drove another 20 ft and it still did it. I hit the brakes a few times, and the sound went away. It was pretty loud. The truck only has 13k.
    I drove it about 40 miles and it hasn't happened again. Is there any way a stone or something could have been caught in there? Maybe between the disc and the dust shield? (If there is a dust shield.) Any thoughts?
  2. Jan 15, 2010 at 6:37 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    its very possible a small stone got lodged in there til it kicked back out.
  3. Jan 15, 2010 at 6:53 PM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    If a stone made that kind of sound, you'll see a nasty witness mark on your disk. That being said, maybe something was rubbing on the disk, but there is no clearance between it and the pad.
  4. Jan 15, 2010 at 6:58 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    ive had it happen..Stones can get stuck between the pad and disk. Best bet would be to pull the wheel off and check for peace of mind.
  5. Jan 15, 2010 at 7:05 PM
    Blacoma
    Blacoma Well-Known Member
    Broken Arrow, Oklahoma
    09 Black PreRunner w/SR5 TRD Sport Pack.
    Westin Bull bar and skid plate, leveling kit, chrome tailpipe tip, window vent visors, dark tint, scangauge2, shorty antenna.
    Right after I got my leveling kit put on I heard a noise coming from the front end somewhere, sounded like i was dragging something that came loose on the suspension somewhere. Got out and looked and found nothing. Had my wife slowly drive while I walked along. It then sounded like something loose inside the wheel. Come to find out a rock got stuck INSIDE the wheel drum. Had to take the wheel off, brake caliper off and drum to get it out. How it got in there I have no idea!
  6. Jan 15, 2010 at 7:46 PM
    akwagon
    akwagon Alaska Dude
    chris
    alaska
    08 Access 5spd 4x4
    5100, kazktin leather, truxedo
    Yes, I used to work at a Subaru dealership and chronic problem on the Outbacks and legacys. Stones would get stuck in the brake caliper. At slow speeds its a really high pitch sequel. Fix was to remove wheel and brake caliper and stone would fall out.
  7. Jan 15, 2010 at 8:20 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    90% of the time if you stop and drive in reverse for a few feet while turning your wheels left to right it'll fall right out.
  8. Jan 15, 2010 at 10:23 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Or driving in reverse and using your brakes....should dislodge it also.
  9. Jan 16, 2010 at 4:58 AM
    chrisman8995
    chrisman8995 Well-Known Member
    Newnan, GA
    05 PreRunner Double Cab
    yeah ive seen this before. my sis had a brand new honda civic with 200 miles on it she hit a stick and a piece managed to lodge itself between the pad and rotor. not only was it a loud noise you could smell it burn...scared the shit out of her
  10. Jan 16, 2010 at 8:18 AM
    saf023
    saf023 Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    I guess anything is possible but how likely is this to happen?
  11. Jan 16, 2010 at 10:28 AM
    johnny12345
    johnny12345 Well-Known Member
    vancouver island, canada
    09 tacoma SR5
    I bent the dust shield on the inside of the front wheels and was rubbing on the rotor. Sounded like something was stuck in there. Just bent it back and there was no problems. The dust shield is kinda like tin, bends very easily.
  12. Jan 16, 2010 at 11:45 AM
    Fortech
    CANADA
    More often than not the pebble gets lodged between the dust shield and the rotor - not much clearance between the pad and rotor for anything, maybe a particle of dust or some mud.
    I drive allot of dirt roads and usually have it happen several times a week. Backing up a few feet will clear it out 90% of the time. The other 10%, it will usually wear itself out within a couple of miles if you can tolerate the noise. Never ever had one damage the rotor in the dozens/hundreds of times this has happened, not even a scratch.
