CAN A MAF SENSOR BE CHECKED AT HOME
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacotruck 2.7, Feb 2, 2017.
  1. Feb 2, 2017 at 5:21 PM
    tacotruck 2.7
    tacotruck 2.7 [OP] Well-Known Member
    Katy TX
    09 cab and a half 2.7
    Idealy with a electrical multi meter that checks ohms/ resistance ?
  2. Feb 2, 2017 at 5:25 PM
    will.carroll7
    will.carroll7 Well-Known Member
    2023 DCSB TRD OR 4x4 LR
  3. Feb 2, 2017 at 5:50 PM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    There is no simple multimeter test to validate or even quick check a MAF, however overall they are one of the more reliable components of a modern EFI control system--why do you suspect it to be an issue?
  4. Feb 2, 2017 at 10:05 PM
    tacotruck 2.7
    Katy TX
    acording to the code menu the truck has all the symptoms, 147k miles & the check engine light code points to a fault in the maf sensor. 120$ for one at Oreilys and id shure hate to buy one if unnessary. some sensors / relays in general can be checked with a electrical meter.
  5. Feb 2, 2017 at 10:18 PM
    road2cycle
    road2cycle Well-Known Member
    Sonoma County, CA
    2014 Tacoma DCLB 4x4 Limited
    I'm not sure if the 2nd gen MAF sensor is similar to 1st gen's but on the 1st gens you could clean them off with electrical spray cleaner. Just don't touch the sensor with the straw since it's fragile. It might be worth a try before you buy a new one.
    MTopp and Blockhead like this.
  6. Feb 2, 2017 at 10:40 PM
    cliffyk
    Cliff
    Saint Augustine, FL
    What is the DTC?
  7. Feb 3, 2017 at 3:45 AM
    06Tacooo
    06Tacooo Earth Czar
    Mark
    39° 14' N / 83° 13' W
    06 Off Road Access Cab Indigo Ink Pearl
    Michelin Defender LTX M/S2, ABS kill switch, Tech Deck, Mirror riser, Ride-Rites, BF Garmin GPS
    You would have to clean it before you could test it, even if you had the stuff to do the test. They rarely go bad. I would just clean it. Get a 2-pack MAF spray cleaner and throttle body cleaner at Walmart, $12 or so, small cans, just enough. If the MAF is dirty, so is the TB. If cleaning doesn't work, at least you cleaned the TB and now it's ready for a new MAF sensor. Get an OEM. They're competitively priced. You don't want any Chinese junk.
  8. Feb 3, 2017 at 5:30 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    As already stated, buy some MAF cleaner and get after it. Blast it good and let air dry for at least half an hour. This is not a part you would want to source from a mass-marketer like O'Reilley's - cheap made in China junk. Buy OE if necessary. You should be able to find an OE part on ebay. Toyota dealers sell parts there.
  9. Feb 3, 2017 at 5:41 AM
    BrennMan
    BrennMan Well-Known Member
    01 TRD Access Cab (current) 07 PreRunner TRD (sold)
    5100s, Weather Tech, Wet Okole, 1.25" spidertrax, pop-lock, Bestopper
    Mine was throwing a code and after I cleaned it the code went away. I used similar products/procedures as described above.
    I was more than happy.
    All of this happened at rough 120,000 miles. If you have a lifetime air filter the oil from the filter can cause this.
  10. Feb 3, 2017 at 5:47 AM
    cliffyk
    Cliff
    Saint Augustine, FL
    100% FUD...
    Where do you think the "OEM" unit is made? No one tools up to specifically manufacture cheap MAF units for Toyota Tacomas at O'Reilly's or any other FLAPS--they are either OEM suppliers, or bought the tooling from Toyota when the models changed. Also O'Reilly's, an aftermarket auto parts supplier that has been in business since 1957, has no motivation to purposely sell cheap junk that would damage their reputation.
    I have used gobs and gobs of aftermarket parts over they years and have never had a problem--IF you buy from one of the "brand name" auto parts stores...
  11. Feb 3, 2017 at 6:00 AM
    will.carroll7
    Clean MAF and throttle body. If the code doesn't go away, maybe try swapping with a friend who has a 2nd gen to narrow it down?
  12. Feb 3, 2017 at 7:03 AM
    glk21c
    glk21c Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
  13. Feb 3, 2017 at 8:47 AM
    tacotruck 2.7
    Katy TX
    p0102 p0113 p2433 codes if i remember corectly. and i do have a KN filter i cleaned and reoiled two weeks ago. reinstalled the original paper unit and removed the maf sensor sprayed some maf cleaner on it. it was visualy dirty. let it dry and reinstalled.
    im tired of foolin with it i drive too far to get stranded 70miles one way. Oreilys has one for 89$ exchange. im starting to think it got oil from the filter on it.
  14. Feb 4, 2017 at 10:03 PM
    tacotruck 2.7
    Katy TX
    replaced the maf sensor today all is well. the hesitating has gone away.
  15. Feb 5, 2017 at 2:02 AM
    cliffyk
    Cliff
    Saint Augustine, FL
    That's what I would have done. I am generally the last to suggest throwing parts at a problem but at times it's easier, and less costly in the long haul, to just replace the suspect part. Now ditch the K&N filter (all it does is increase intake noise) and you'll be all set...
  16. Feb 5, 2017 at 4:42 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    I agree...the K&N phenomenon is an overpriced myth.
  17. Feb 5, 2017 at 5:10 AM
    cliffyk
    Cliff
    Saint Augustine, FL
    will.carroll7 and 06Tacooo like this.
