Can’t roll passenger window down after battery died
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cameron172, May 14, 2021.
  1. May 14, 2021 at 5:20 AM
    cameron172
    cameron172 [OP] Well-Known Member
    VA
    2017 Super White TRD Sport MT
    Yesterday I couldn’t start my truck due to a dead battery (it’s a separate parasitic drain issue with my anytime camera install I’m trying to figure out).
    I got the jump but now I cannot roll the front passenger window up or down from the driver side. The passenger side switch works but the auto mode doesn’t work. The two rear windows go up and down just fine from the driver control.
    Before you ask, it’s not locked.
    Is there a fuse that could have blown while trying to start with a dead battery? Or a relay that could have been fried when trying to start with a dead battery and fluctuating voltage?
  2. May 14, 2021 at 5:22 AM
    littlefish
    littlefish Buzz, your girlfriend...
    Hudson Valley NY
    2016 TRD Off-Road DCSB
    The one who dies with the most stuff wins.
    Same thing happened to me once but on the driver's side. No blown fuses or anything else out of sorts. Went out the next day and it fixed itself. That was over two years ago and it never happened again. I'll never know what happened.
    wilcam47 and ORtoCOTaco like this.
  3. May 14, 2021 at 5:25 AM
    TX BAJA1
    TX BAJA1 Well-Known Member
    2021 LUNAR ROCK TRD PRO
    reinitialize right front window. From right front door put window all the way down and keep holding switch down an extra few seconds. Then go all the way up and keep switch held an extra few seconds. Then try from driver's side.
  4. May 14, 2021 at 5:38 AM
    xMaverickx
    xMaverickx Well-Known Member
    Jeremy
    New Brunswick, Canada
    2016 MGM Limited V6 4X4 DCLB
    If this doesn’t work, didn’t for me, then try this.
    With the truck turned off get in the cab and hold both front window switches down from the drivers switch, put foot on brake pedal and start the truck while still holding the switches down. Windows should both go down right after start.
    wilcam47 and tonered like this.
  5. May 14, 2021 at 5:39 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Is that the only issue? Radio works? AC works and isn't stuck on Defrost?
  6. May 14, 2021 at 8:06 AM
    Omar RVA
    Omar RVA Well-Known Member
    Omar
    OR
    2020 Ram 2500 Power Wagon; 2019 Land Cruiser
    This. Every vehicle I’ve had with auto up/down windows has needed to be “reset” after changing batteries or a jump. Should be back to normal after this or some similar initialization procedure.
    OA
  7. May 14, 2021 at 8:09 AM
    mhornco
    mhornco Well-Known Member
    Have not dealt with this with Taco yet, but my wife's Subaru has this issue and I had to follow steps listed on the internet to reinitialize
  8. May 14, 2021 at 10:59 AM
    Nick1999
    Nick1999 Well-Known Member
    Arizona
    2004 Red Tacoma S Runner
    No
    From what you described, for me the problem is with small electrical motor for the front passenger's window (dead).
  9. May 14, 2021 at 12:52 PM
    xMaverickx
    Jeremy
    You read the part where the window rolls down from the passenger side switch right?
    RIX TUX, DeeKay20 and Skydvrr like this.
  10. May 16, 2021 at 3:44 AM
    cameron172
    VA
    This was the solution. Such a simple fix for a problem I have literally never heard of. "The window needs to be rebooted" was never something I thought I'd say about a Tacoma.
  11. May 16, 2021 at 9:28 AM
    SatlyPartiot408
    SatlyPartiot408 TintGuy
    Bay Area
    2017 Tacoma Limited 4x4 sb
    Icon stage 3, Method NV305, 33 Ko2,Llumar IRX tint, OV performance 87 tune, Focal k2 and polyglass rears. Jl audio amp and sub. Dasaita PX6, remote X starter, bakflip cover, train horns, trd pro grill and front camera, AMP research power steps and Magnuson supercharger on order!
    Every vehicle with auto windows is like this. This includes auto sunroofs. Most vehicles will take a 3 second hold in each direction with the exception of Tesla its 10 seconds.
    CrispyTacoLover likes this.
  12. Sep 28, 2022 at 4:17 PM
    turbotaylor
    turbotaylor New Member
    taylor
    2006 Toyota Tacoma TRD Prerunner Access Cab
    none
    Note: I now have a 2018 4Runner
    Which is what it happened on. Thank you TX BAJA1. Every time my battery dies my R windows won’t work from L control panel. Last year when it happened a few months when by and they just happened to start working. Battery died this year (both times I did a jump but have a new battery since last year) and same thing- passenger windows wouldn’t work w driver control. Did the few seconds on hold down and up and worked like a charm!
  13. Sep 28, 2022 at 4:30 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Wow, learned something new today. Thanks guys!
  14. Sep 28, 2022 at 5:15 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    pay the man
  15. Sep 29, 2022 at 3:19 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Welcome!
