Can’t remove bolts from tailgate handle
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mokane, Mar 3, 2021.
  1. Mar 3, 2021 at 4:08 PM
    Mokane
    Mokane [OP] Member
    2002 Tacoma. Tailgate latch needs to be replaced. Bought replacement. Bolts that secure the handle to the latch machinery are self-tapping into brass inserts in the plastic. When I try to turn the bolts, the female brass inserts just spin in the plastic. Am I doing it wrong? Is there a trick I don’t know about? At this point it looks like I’m going to have to try to cut it out, but there isn’t much room for a saw. Help!
  2. Mar 3, 2021 at 4:23 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Can you get a good paid of dikes in there and crack off the handle.
    Mokane[OP] likes this.
  3. Mar 3, 2021 at 4:29 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Drill the hardware out if you can hold the brass inserts .
    Steel and brass do not play well long term .
    Grinder and Cutoff wheel??
  4. Mar 3, 2021 at 9:50 PM
    Mokane
    Mokane [OP] Member
    Thanks for the replies. Those are the sorts of solutions I was coming up with. Just wondered if anyone else had run into it and figured out something slick.
    I love this site. I’ve learned a lot and saved a lot because of it.
  5. Mar 3, 2021 at 10:47 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    In this video it looks like the guy has a similar problem and he seems to pull on the handle piece away from the bolt to prevent the inserts from spinning as he loosens the bolts. I guess if the bolts are corroded bad this wouldn't work.
    https://www.youtube.com/watch?v=YmAgUoTdgIw
  6. Mar 4, 2021 at 10:12 AM
    Mokane
    Mokane [OP] Member
    Used a Dremel cutter bit to cut the plastic.
    Wyoming09 likes this.
  7. Mar 4, 2021 at 6:54 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    What ever gets the job done!!
