Camshaft can end cap seal
Discussion in '1st Gen. Tacomas (1995-2004)' started by havoc5788, Mar 12, 2021.
  1. Mar 12, 2021 at 12:41 PM
    havoc5788
    havoc5788 [OP] Well-Known Member
    Daniel
    2000 Toyota Tacoma pk
    K&N
    What torque does the cam bearing mount go on after you install new rear caps?
  2. Mar 12, 2021 at 11:37 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    What engine? Here’s torque specs for the 3.4
    havoc5788[OP] likes this.
  3. Mar 13, 2021 at 12:17 PM
    havoc5788
    Daniel
    K&N
    Yes it's A 3.4 extended cab
  4. Mar 13, 2021 at 12:24 PM
    havoc5788
    Daniel
    K&N
    Ty I read 71 lb.I will check my wrench for lb torque.Is the torque right that seems lowe then how much is to take off.I saw A guy on A video try with A impact wrench till hestripped the bolt.
  5. Mar 13, 2021 at 12:34 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Sounds too high for aluminum. in-lb probably - don’t use ft-lb
  6. Mar 13, 2021 at 4:22 PM
    havoc5788
    Daniel
    K&N
    Ok ty I just read in the forum someone went 90 in lb.They say factory.sometimes over torque there's and they strip there bolts.now I'm nervous about doing the job.
    Dalandser[QUOTED] likes this.
  7. Mar 13, 2021 at 4:41 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Basically it’s just over snug - do you have an in-lb torque wrench? 91 in-lb would be about 7.5 ft - lb
    What job are you doing?
  8. Mar 13, 2021 at 6:46 PM
    havoc5788
    Daniel
    K&N
    Yes I have both wrenches just no specs thanks again.
  9. Mar 13, 2021 at 6:50 PM
    havoc5788
    Daniel
    K&N
    This is my 4th time replacing valve cover gaskets and it seems I kept peeking again from the back left side.I saw A video of A guy same thing and he showed the plug I ever new about.
  10. Mar 13, 2021 at 6:54 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Was this the video you’re talking about?
    https://youtu.be/N5fAXAuGozI
    havoc5788[QUOTED][OP] likes this.
  11. Mar 13, 2021 at 10:11 PM
    havoc5788
    Daniel
    K&N
  12. Mar 13, 2021 at 10:28 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Follow Timmy's video, it usually has FSM info
  13. Mar 13, 2021 at 11:35 PM
    havoc5788
    Daniel
    K&N
    Just finished Tims video was A great help.He shows the book spec at 12ft-lb is that over torque?7.5 feels safer IDK 12 would be to the last tread no?
  14. Mar 14, 2021 at 12:39 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    12 is what the link I posted puts
    upload_2021-3-14_12-39-12.jpg All the bearing caps are the same size bolts.
  15. Mar 14, 2021 at 12:51 PM
    havoc5788
    Daniel
    K&N
    Ok Ty
