Camper shell window conversion.
Discussion in '1st Gen. Tacomas (1995-2004)' started by bodhi armor, Oct 9, 2020.
  1. Oct 9, 2020 at 9:31 PM
    bodhi armor
    bodhi armor [OP] 02’ Dbl Cab- "The Luck Dragon"
    Joshua
    East TX
    2002 4x4 Dbl Cab Jade Green
    Hey TW world!
    I currently have a camper shell for my truck with sliding windows on the side, however I would love to convert it to using utility panels that flip up.
    below is a pic of my green shell, and a picture from google of what I want it to be.8B149F6B-767E-430A-97F2-279BB2FFE0A3.jpg8840A086-BCC6-4F03-9152-A51402072C50.jpg
    Has anyone done this type of conversion? Or know of any “how to” info I could use as a guide?
    I’ve been wanting to try this for a while but don’t want to ruin my shell if I dick it up.
    thanks!!
  2. Oct 10, 2020 at 6:21 AM
    Kleenax
    Kleenax Well-Known Member
    Ray
    Michigan
    2001 SR5 4WD V6 Auto - Mica Green
    New frame & stuff CBI bolt-on Sliders
    I would think that you would have to have a custom-made aluminum frame with hinges (for the solid panel) since the glass is surrounded only by the rubber seal. You certainly could do it, but to build your doors, you would have to be well-versed at fiberglass work. Note that every-single-corner on your side windows has a unique radius too, so you would need to make a rather exact template to match them. Not an impossible task, but it would be a long process if you wanted it to look professional.
  3. Oct 10, 2020 at 6:45 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    contact the manufacturer of the shell and see if they have the utility doors already, could be an easier swap
    Wyoming09 likes this.
  4. Oct 10, 2020 at 8:03 AM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    I ordered the flip up windows as an option on my topper, many years ago. They are held in by the metal frame of the window on the outside, and a metal band that is screwed into that outside frame, from the inside. Basically, it sandwiches the fiberglass between two pieces of metal. Adding them after the fact might only involve cutting the opening to fit the window. BUT, if the present opening is larger, it would be nearly impossible. I have the feeling that mine are not as long as the slider window that would have come on mine, but not sure about height. You might make a template of your present window or at least take comprehensive measurements to look for ones out of a salvage/craigslist one. By the way, to buy them from the manufacturer, is about $300 per window.
  5. Oct 10, 2020 at 1:15 PM
    Akkording
    Akkording Well-Known Member
    Pete
    Houston
    03 +300k Still Truckin, 2012 4Runner
  6. Oct 10, 2020 at 1:16 PM
    Akkording
    Pete
    Houston
  7. Oct 10, 2020 at 1:26 PM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    I bought my camper and wished I had ordered them like that. So much more convenient when your on the trail to just open the Windoors vs climbing in the truck.
    Seagull233 and lemon177 like this.
