Camper shell brake light wiring help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Junetaco03, Feb 12, 2018.
  1. Feb 12, 2018 at 7:46 PM
    Junetaco03
    Junetaco03 [OP] Well-Known Member
    Bay Area, California
    2019 TRD OFF ROAD 4x4 DCSB
    Hello. I just bought a camper shell for my 2003 double cab. I need to connect the third brake light from the camper. I see the two wires that are in my camper. Anyone know how do I connect these to my truck break light wiring? Also does anyone have any pictures of a camper that’s hooked up wire wise? Thanks
  2. Feb 12, 2018 at 8:02 PM
    Jackstraw13
    Jackstraw13 Well-Known Member
    2003 Tacoma Doublecab 4X4 TRD
    Hey. You'll find it behind your drivers side tailight I can send you a picture tomorrow.
  3. Feb 12, 2018 at 8:06 PM
    MikeWH
    MikeWH Well-Known Member
    Colfax, CA
    1999 TRD 4x4 (x2)
    Easiest way is to get the kit which has connectors on it so you won't have to cut your wires. Then you run the wire back from the tail light housing to your camper shell.
  4. Feb 12, 2018 at 9:01 PM
    Junetaco03
    Yes that will help if you can send the pics of the wire connected so I can get a idea. I rather do it myself then pay 60 to have someone do it
  5. Feb 12, 2018 at 9:02 PM
    Junetaco03
    Where can I get the connectors ?
  6. Feb 12, 2018 at 9:09 PM
    MikeWH
    Colfax, CA
    1999 TRD 4x4 (x2)
  7. Feb 12, 2018 at 10:09 PM
    Krazyoakes
    Krazyoakes Well-Known Member
    Isaac
    Eugene, OR
    01 Tacoma 4x4
  8. Feb 12, 2018 at 10:40 PM
    Junetaco03
    Hello. Yes the The camper does have the standard interior dome light. I plan on leaving the camper on long term. Do you have any pics for me that will help me out? I plan on completing this tomorrow thanks.
  9. Feb 12, 2018 at 11:05 PM
    Krazyoakes
    Isaac
    Eugene, OR
    01 Tacoma 4x4
    Do you plan on taking the canopy off ever?
  10. Feb 12, 2018 at 11:13 PM
    Junetaco03
    No I don’t plan on taking it off anytime soon
  11. Feb 12, 2018 at 11:22 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Then easiest way is to splice into brake light Harness directly at the tail lights. Dome light can be spliced into a constant 12v power source under the bed like your fuel pump or something like that.
  12. Feb 12, 2018 at 11:29 PM
    Junetaco03
    It looks like the dome light is already sliced into the break light of the camper. I’ll take a picture of the wires that I have tomorrow.
  13. Feb 12, 2018 at 11:30 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I don't think the brake lights have constant 12v - if they were hooked up like that it would only work at night when the headlights are on.
  14. Feb 13, 2018 at 3:42 AM
    tony2018
    tony2018 Well-Known Member
    i plan to put quick disconnects
  15. Feb 13, 2018 at 8:15 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    it was probably wired from the "running" lights instead of a constant 12v source. common when a shop installs it.
    @Krazyoakes nice find on the wiring thread
    one thing I will point out is do not tap into the wires next to the sockets. if you ever need to change the light housing you will have to pull off the taps and redo them.
    find the wire on the opposite side of the plug connector and tap there, much easier. also all the white wires are the grounds :)
    I ran a dedicated 12V 14awg wire and used a fused connector to the battery + terminal. bought a spool of 100ft for cheap so I would have plenty for extras. ran the wire along the frame and tied it to the factory wire loom along the way.
    Krazyoakes likes this.
  16. Feb 13, 2018 at 9:01 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Daytime running lights? Some trucks didn't come with that stock from the factory.
  17. Feb 13, 2018 at 9:08 AM
    tony2018
    01-04 came with it. I just disconnect mine.
  18. Feb 13, 2018 at 9:08 AM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    I also pulled a dedicated constant 12v from battery. I also pulled the barely a light dome, and replaced with these LED's
    https://www.amazon.com/gp/product/B016KNZQ0E/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
    Since it might be possible to leave them on accidentally, I figure it will take a long time for LED's to pull down the battery. I cut them into segments and added wire between to allow them to go on three sides of the camper top. No problem finding stuff in there now!!!
  19. Feb 13, 2018 at 9:10 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Oh yeah that's they way to go then for 01-04. DRL circuit for the dome light and stop light circuit for the 3rd brake light.
    You can wire a trailer four pin harness to the truck and create a quick disconnect.
  20. Feb 13, 2018 at 9:10 AM
    Seagull233
    Tom
    Upstate New York
    2004 DC 4x4 V6
    Think he probably means the tail lights.
    frizzman likes this.
