Camper shell boot?
Discussion in 'Tonneau Covers, Caps and Shells' started by Gabassman, Apr 22, 2014.
  1. Apr 22, 2014 at 8:20 PM
    Gabassman
    Gabassman [OP] Drive it like a 4WD
    Tyler
    Georgia
    I found I pretty good deal on a camper shell. It's a are mx. Practically brand new. Be trading my tool box plus some cash. The only thing I don't like is the fact that there is no front window it had the compression boot. Is there anything that can be done to prevent rubbing paint off? What would it cost to add a window?
  2. Apr 22, 2014 at 8:24 PM
    luvium
    luvium Well-Known Member
    San Diego
    13 DCSB 4x4 TRD Offroad M.G
    Trimmed front flaps Extra D rings
    You can get a fixed, slider or fold down window for 125-200$. The boot will rub the paint off down to the primer like it did on my 96 taco. I have the boot turned in so it wont rub and the dogs get air. Not too much rain here so its not a issue unlike you where it rains often.
  3. Apr 22, 2014 at 8:27 PM
    Gabassman
    Tyler
    Georgia
    The rain wouldn't be an issue till it's time to camp. Is it easy just to push the boot into place if it starts raining while camping?
  4. Apr 22, 2014 at 8:27 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Call your local ARE dealer. If you give them the serial number of the top they can tell you how much it will be to put a window in. I had mine switched from solid front glass to a slider and I think it was around $200.
  5. Apr 22, 2014 at 8:29 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    I guess you could install it without the boot. You'd get some moisture and dirt in the bed from the open gap between the shell and cab, and if anyone was riding back there it would be pretty load and potentially uncomfortable?
    But it might work out good if you just use the back for hauling things that don't need to be 100% dry and clean.
    -- OR --
    Maybe you could apply some decal material onto the cab areas where the boot will rub. That might protect the paint? They sell bulk clear decal material used to cover paint surfaces to protect from rock chip damage, that sounds like it should be tough enough for this. Here is a 3M product Autozone carries.
  6. Apr 22, 2014 at 8:31 PM
    Gabassman
    Tyler
    Georgia
    That's not horrible. I don't know if I should just wait it out and see if one pops up with the window for the same price.
  7. Apr 22, 2014 at 8:38 PM
    Gabassman
    Tyler
    Georgia
    The decal material looks promising. As well as getting a replacement window.
  8. Apr 23, 2014 at 5:35 AM
    luvium
    San Diego
    I like the clear decal idea.
  9. Apr 23, 2014 at 6:46 AM
    Gabassman
    Tyler
    Georgia
    I think that's what I will do. Either the 3m spray or vinyl. Vinyl would probably last longer. Now I just go to sell a kayak and make the drive to get it.
  10. Apr 23, 2014 at 10:10 AM
    TAC1
    TAC1 Well-Known Member
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Hello, this compression boot that you mentioned, does it surround the entire window of the truck or only the center portion that opens? I sometimes contemplate buying a camper shell for my DCSB & want it to be light, with screens for camping, & possibly have the compression boot.
    Thanks!
    Great idea on the clear decal material!
  11. Apr 23, 2014 at 11:40 AM
    Gabassman
    Tyler
    Georgia
    From the picture I received from the guy it looks as though it surrounds the whole window. Not sure if it seals to the window or the body.
  12. May 1, 2014 at 10:13 AM
    Gabassman
    Tyler
    Georgia
    Good news is that the rubber boot on the ARE does not touch the paint. It seals against the window and the window trim. 8u6ydu8a_e2cdb7028f04802053837e6a34356e13d34c24fd.jpg
  13. May 1, 2014 at 11:45 AM
    mountainwolfpup
    Vancouver, WA
    Excellent! Good to hear that, smart design. So many are just an inflatable donut.
    Anyway, thanks for the folow-up. Always good to hear how these things sort out in the end.
    Cheers!
  14. May 1, 2014 at 11:53 AM
    TacomaJack09
    TacomaJack09 Well-Known Member
    Jackson
    Montana!
    06 Access Cab 4x4
    Billie 5100's, Ride Rite Airbags, Tech Deck
    Nice! I need a boot for my camper! and great idea with the 3M product, didn;t even think about that, thanks!
  15. May 1, 2014 at 11:55 AM
    mountainwolfpup
    Vancouver, WA
    You bet TacomaJack09. Glad the idea was helpful. If you wouldn't mind floating me some reputation points I'd be obliged. Some haters lately have dragged down my otherwise stellar rep.
  16. May 1, 2014 at 1:37 PM
    TacomaJack09
    Jackson
    Montana!
    06 Access Cab 4x4
    you got it!
  17. May 1, 2014 at 1:41 PM
    Gabassman
    Tyler
    Georgia
    hu2y9ume_ec3cb4504948816d1b4e118aaa56d269e495464d.jpg side view
    But yea I took the chance and it worked out where it only hits the window.
  18. May 2, 2014 at 7:25 AM
    TacomaJack09
    Jackson
    Montana!
    06 Access Cab 4x4
    Looks great OP! I've been looking for a mid rise shell like that for camping. My cab height gets a little cramped at times.
  19. May 3, 2014 at 4:21 AM
    Gabassman
    Tyler
    Georgia
    Thanks I like the look as well as functionality. I originally wanted a cab high but this one showed up on Craigslist and was affordable.
    I feel I was pretty lucky. I decided I wanted a shell for camping a few weeks back. I looked for probably 3 days. I expanded my search by 50 miles and found this one. He was asking 750. I shot the guy a text with an offer of 350 plus my toolbox. He accepted and told me that he would hold it for me. I sold off a couple of things at the flea market and on Craigslist. I went and got it on a Sunday. Within a week I had a had a shell. Seems like it takes most people months to find a good deal.
  20. May 3, 2014 at 5:47 AM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    Looks great!
    I just picked up an ARE cx series shell and really like it.
    You got a killer deal on that shell! These things aren't cheap to buy new :)
