Cam bolts maxed out. Can't get the camber right. What could be the issue?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AbdullaJaafari, Jul 8, 2021.
  1. Jul 8, 2021 at 6:15 PM
    Clearwater Bill
    Billy
    Largo Florida
    He was doing the work himself. Most don't get lazy on their own stuff. ;)
  2. Jul 8, 2021 at 7:47 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Unequal caster not allowing equal camber? Take away some caster to gain camber.
    Then, check the SAI and included angle; along with camber, it can point you in the right direction.
    RH007 and G8R_Taco like this.
  3. Jul 9, 2021 at 5:52 AM
    AbdullaJaafari
    AbdullaJaafari [OP] Dubai Taco
    Abdulla
    Dubai, UAE
    2018 Tacoma TRD Off-road
    Turns out my left spindle is indeed bent and is causing the issue as once I mess around with the caster, all the other readings can't get to the right number.
    I just looked up ready-cut gusset options and seems like the Total Chaos ones are a solid option, but as per their site, I won't be able to use the factory wheels because of their offset .. Hmm..
  4. Jul 9, 2021 at 8:57 AM
    splitbolt
    NW Arkansas
    I think Camburg makes a set that works with stock wheels and tires.
  5. Jul 9, 2021 at 9:14 AM
    TacoSupremo19
    TacoSupremo19 Well-Known Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
    Brushed Copper Blaze 10 Rims | 265 70 17 Toyo Open Country A/T III tires | Bilstein 5100 w/ Eibach Coils 2.5" lift | Blackhawk UCAs | ICON Rear 3 AAL |TRD Skid Plate | TRD CAI | OEM Rear Bed Lighting | OEM rear Tailgate lock | RC Bed Molle Racks | Custom Blacked out OEM LED Headlights | MESO V4 Mirror Turnsignals | MESO Interior trim blackout | TG DMM dash mount | TRD Shift Knob | OEM SR5 interior door handles | Upgraded Stereo including Alpine 700W Amp Alpine Type R Components & Hertz speakers 12" Sub | Custom Clazzio Seat covers | Mobtown Sliders | Front Camera
    If your stock just replace the spindle. Might even find a set on here. Also when you adjust camber/caster it will change toe so adjust those first, lock it in, then adjust toe one side at a time, making sure the first finished toe adjustment stays the same, when you move to the other side to make that adjustment.
  6. Jul 9, 2021 at 11:47 AM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    What other way then one at a time is there?
    whatstcp likes this.
  7. Jul 9, 2021 at 11:50 AM
    TacoSupremo19
    NJ
    I used to see techs go back and forth from one tie rod end to other, adjusting the tie rod end if it changed it's reading, instead of just moving the wheel on the turnplate to get it back to the original, dialed in, adjustment. Saw that a lot and sometimes would cause crooked steering wheels.
  8. Jul 9, 2021 at 3:06 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    I don't know; I'm not an alignment/body/suspension guy. Give me a labscope and a DVOM and I fill figure out what's wrong; suspension/driveline? That's voodoo shit! Seriously though, it may well NOT matter, probably doesn't, but maybe it sets a parameter in the machine that isn't achievable based on the actual tires... just making an observation.
  9. Jul 9, 2021 at 8:17 PM
    splitbolt
    NW Arkansas
    Aside from the fact that ride height is supposed to be checked prior to alignment as it is the reference for alignment measurements...
    If you increase tire diameter, positive scrub decreases, affecting dynamic toe... Basically, changing how the geometry interacts with the road through the tire.
  10. Jul 9, 2021 at 11:17 PM
    Hatfieco05
    Hatfieco05 Well-Known Member
    Portland, OR
    2020 DCLB TRD Off-Road Premium
    Clunking and good caster but bad camber have you checked the lca bushings?
    b_r_o likes this.
