Cam bolt question.
Discussion in 'Suspension' started by ievko82, May 4, 2017.
  1. May 4, 2017 at 6:46 PM
    ievko82
    ievko82 [OP] Well-Known Member
    WV
    17 sport DCSB quicksand
    I plan to remove my cam bolts for alignment adjustments to put anti seize on them. Is there anything other than the bolt I should do this to?
    I am doing this because my alignment tech warned me about them freezing up and suggested it.
    koditten likes this.
  2. May 5, 2017 at 2:13 AM
    ievko82
    WV
  3. May 5, 2017 at 2:21 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You got a good mechanic.
    Remove the bolts and AS'ing them and replace. The AS keeps the bolts from rusting to the sleeves. Coating the bolts is all you really need to do.
    If you are in preventive maintenance mode, think about AS'ing the pins on the brake calipers. That will really help when time to change pads.
    I'm actually amazed that the mechanic suggested this. Toyota never added any of this lube from the factory on any generation of Tacoma.
    You might be able to tell, but this is a sore subject for me. I've had to cut off and destroy 3 lower control arms over the years because of this issue. The job sucks as well as cost a lot of money that could have been avoided by adding a few cc's of grease.
  4. May 5, 2017 at 2:27 AM
    ievko82
    WV
    Thank you for the reply. My truck only has 5k on it and the one bolt was already creaking and making noise when he turned it to do the alignment. I definitely don't wanna let it go a whole lot longer. Hopefully it's not to late already, it did turn tho.
    If it is frozen in there when I go to take it out I'll be trying to get it covered under warranty before I cut the lca off a new truck.
  5. May 5, 2017 at 2:43 AM
    koditten
    Kirk
    Central Michigan
    If its turning even while squeaking, you have nothing to worry about. Just pull them and lube them and you will be good.
    Make sure and mark the cam positions with some paint so you can replace the bolts and not have to get another alignment.
    Cheers
    Kirk
    Dragons Taco likes this.
  6. May 5, 2017 at 2:45 AM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    "My alignment tech" Are you a professional? I ask because if you remove your cam bolts to apply anti-seize (which I think is an excelent preventive maintenance task), you will need to do an alignment on the truck right away. Why wouldn't the alignment tech say "hmm, I know that these seize, why don't I lube them while I'm doing an alignment" Or am I missing something?
    Then again, with the amount of specialization today, perhaps alignment techs don't touch lube.
    :confused:
  7. May 5, 2017 at 2:47 AM
    Dragons Taco
    Derek
    Cary/Raleigh NC
    Yes, you can do this, but I wouldn't trust it myself. Not only would I worry about getting it back correctly, the damn things are so touchy.
    Besides, I just cleaned and lubed the bolts... where did the paint go? But that's may be just me :)
  8. May 5, 2017 at 3:01 AM
    Clearwater Bill
    Billy
    Largo Florida
    Yep.
    It's really not that hard.
  9. May 5, 2017 at 3:10 AM
    koditten
    Kirk
    Central Michigan
    Alignment techs don't remove the bolts to align, just loosen. They aren't paid to fully remove them and lube. In many cases the Techs are checking the alignment first, if the numbers are good, the bolts won't even be loosened. Out the door the truck goes.
    In just about all cases, the need to do adjustment is because the truck was in a situation where there was trauma to the front end. This could be years down the road. New trucks won't have froze cam bolts.
