Calipers under warranty?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacomaNiner, Jul 25, 2020.
  1. Jul 25, 2020 at 11:14 AM
    TacomaNiner
    TacomaNiner [OP] Member
    Marc
    2019 Tacoma SR5
    Took my 2019 Tacoma in for 20k service. They told me left front brake is worn and it would be $270 to replace, turn rotor and adjust caliper. I spoke to a couple mechanic friends and they suggested it should be covered under warranty because sounds like caliper is faulty. I know some basic car stuff but this is more than I know. What is your take on this. Thank in advance.
  2. Jul 25, 2020 at 11:32 AM
    Claudiomartinof
    Claudiomartinof Well-Known Member
    2019 TRD OFF ROAD 6MT
    Not mechanically inclined but I would say it should be under warranty... unless you modified the calipers or did something to them...I will insist on warranty..
  3. Jul 25, 2020 at 11:33 AM
    ICU1
    ICU1 Well-Known Member
  4. Jul 25, 2020 at 11:36 AM
    Xplosiv
    Xplosiv Well-Known Member
    Jeff
    Lewisville, TX
    2021 OR DCSB Black 99 Corvette FRC
    265/75/16 AT's, Cali Raised Sliders, BAMF RTT Rack
    Normally if only one side is worn that indicates a faulty caliper, which should be a warrantable item. They may make you buy a set of brake pads as they are a wear item but it depends on exactly what Toyota says.
    The off the hip answer is no, brakes are wear items and not generally covered. But if there is a specific faulty piece in the system, then at minimum that part should be covered.
    4x4spiegel and t0nyvalenzuela like this.
  5. Jul 25, 2020 at 11:44 AM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    What does adjust the caliper mean ? If they are just pushing it back in WTF . This sounds like bs . It sounds like it needs a new caliper , rotor and brakes at their expense . Is it just one side ? If yes then that caliper is messed up . How many miles on the truck ? They say we can get 70K miles on a front set of of shoes on these third gens if not more .
  6. Jul 25, 2020 at 11:59 AM
    St0rm-Tr00per
    St0rm-Tr00per Well-Known Member
    SoCal
    2018 TRD OR 4X4 DCLB - Super White
    “Semi-Pro”/“PrOff-Road”
    Sounds like a warranty situation to me ... one side should not be wearing out before the other especially at only 20K. How much wear did the other side have? What about the rears?
    Modesto Tacoma and Big tall dave like this.
  7. Jul 25, 2020 at 12:45 PM
    TacomaNiner
    Marc
    2019 Tacoma SR5
    I got to dealership to pick it and turns out its the right front brake and its at 3mm while left is at 5mm. I think the service writer was making it out to be worse over the phone so I would dump the $270. Definently gonna seek a second opinion. Thanks for the advice guys.
    Jason TRD OR and Chew like this.
  8. Jul 25, 2020 at 12:59 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Trusting the dealership with your truck is like handing your wallet to the average stripper.
    And on that note, I'd take a few lap dances over eating popcorn for 4 hours while someone pretends to work on my truck..
    tcjacado likes this.
  9. Jul 25, 2020 at 2:15 PM
    The_Devil
    The_Devil Well-Known Member
    E
    2018 Tacoma TRD Off-Road
    DIY Tonneau, Toolbox, Lift, TRD Wheels, TRD Grill
    If one side is completely warn, and the other has 1/2 life left, then it seems like a failure, and not wear.
    The damage to the wearable items would properly be referred to as consequential damage.
    Example......batteries are wearable items, but a faulty alternator can damage electrical items like stereos, and batteries.
    If the alternator were covered by warranty, the damage to the stereo and battery would be covered by consequential damage if argued correctly.
    Ask me how I know.
    Big tall dave likes this.
  10. Jul 25, 2020 at 2:25 PM
    BrianTaco75
    BrianTaco75 Well-Known Member
    Brian
    1995 Taco / 2019 Taco
    If one side if worn excessively then it is for sure an issue, I would contact Toyota Corp. if another dealer gives the same grief.
  11. Jul 25, 2020 at 2:58 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Definitely sounds like it would be warranty related for sure, unless something you did to the truck damaged it in some way.
    Jeff
    Skydvrr and Big tall dave like this.
  12. Jul 25, 2020 at 3:33 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    You getting booshitted, definitely get another opinion.
  13. Jul 25, 2020 at 3:59 PM
    t0nyvalenzuela
    t0nyvalenzuela Well-Known Member
    2019 Tacoma TRD OR DCLB
    Puck level
    Good luck having the warranty cover it. Toyota service dept will argue about doing the “required maintenance” if it isn’t just a tire rotation and oil change.
  14. Jul 25, 2020 at 4:11 PM
    Bishop84
    Bishop84 Well-Known Member
    Brakes are limited warranty on any manufacturer vehicle.
    They are subjected to environment, and driving habits, both of which the manufacturer cannot control.
    So unless its deemed defective, it can't be warrantied.
    Likely the caliper is fine, the pins or pads are likely just sticking from lack of servicing.
    I'd push the caliper back, let the fluid out, service the pins and move on.
  15. Jul 25, 2020 at 4:16 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    I'm not anti dealer like many here, but I smell a turd, unless OP is experiencing pull, smells brakes, fade, etc...I think someone in the office wasn't hitting his numbers for the week......
  16. Jul 25, 2020 at 5:04 PM
    Señor
    Señor Well-Known Member
    CA Central Coast
    '18 TRD OR DCSB Magnetic Gray Metallic
    A 1 year old truck shouldn't have faulty brake calipers yet. Call corporate and open a case. IMO a faulty factory part or installation. And why wasn't this caught in the other previous services? The stealership is trying to get one over on you. I caught my dealer stating work was performed on the invoice when it wasn't. They were just checking the boxes and not the vehicle.
  17. Jul 26, 2020 at 12:25 AM
    Modesto Tacoma
    Modesto Tacoma Well-Known Member
    central california
    LIMITED 4X4
    I would get them to put in writing what do they mean by adjusting the caliper? It’s bolt on. Simple as that. To put new pads you have to push the caliper pistons in anyway. And for Tacoma’s you don’t have to remove the caliper at all to install pads. Only if you remove the rotor then you remove the caliper but can keep the pads all installed .
  18. Jul 26, 2020 at 9:29 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Yeah sounds like they were trying to scam you over the phone.
    Bleep100 likes this.
  19. Jul 26, 2020 at 9:34 AM
    Naszero
    Naszero Well-Known Member
    2021 Cement DCSB TRD OR 4x4
    Instead of a faulty caliper, I'm more inclined to believe the OP's pad's were sticking, causing premature wear on one side. The "adjustment" to the caliper was probably cleaning and lubing the caliper guide pins.
  20. Jul 26, 2020 at 9:04 PM
    The_Devil
    E
    I am asking this because I don't know. Do sticking pads stick because of environmental issues that count as wear, or because of a defect that would point to a warranty issue for OP?
