Caliper mount bolt size - answered!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by deanosaurus, Apr 27, 2023.
  1. Apr 27, 2023 at 6:34 AM
    deanosaurus
    deanosaurus [OP] Caveman
    Northeast Region
    09 TRD OR AC
    Does anyone know the size for the bolts that mount the calipers to the spindles? Chances are excellent mine are going to break, so I'd rather have them on hand.
    Thanks!
    Edited with answer:
    Toyota P/N: 90080-10213
    Dimensions: JIS M12x1.25x33.25mm flange bolt, grade 10.9 (slightly longer will fit fine)
    McMaster P/N (Pack of 10): 95735A117 (JIS M12x1.25x35mm, Grade 10.9)
    Kolter45 and 6 gearT444E like this.
  2. Apr 27, 2023 at 6:39 AM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
  3. Apr 27, 2023 at 6:42 AM
    deanosaurus
    Northeast Region
    09 TRD OR AC
    PzTank likes this.
  4. Apr 27, 2023 at 6:43 AM
    ToyoTaco25
    North Carolina
  5. Apr 27, 2023 at 11:12 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    But, surely, one bolt will come out so you can measure it.
    Why you think it’s going to break? Don't use a power tool to break the bolt free. Use a 6 point socket on a breaker bar. Maybe throw some penetrating oil the days before attempting.
  6. Apr 27, 2023 at 11:13 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    We tried doing his brakes on Saturday. No luck even with heat.
  7. Apr 27, 2023 at 11:13 AM
    deanosaurus
    Northeast Region
    09 TRD OR AC
    PB Blaster twice a day for a week, propane torch, and tight fitting 6 points failed to even budge a single of the four bolts. I would much rather have replacements on hand before getting any more aggressive. They've been on there for years in salt hell.
  8. Apr 27, 2023 at 11:18 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    :eek:
    I guess the next question is, how will you get it out once it does break??
    AllTacosFloat and ToyoTaco25 like this.
  9. Apr 27, 2023 at 11:18 AM
    deanosaurus
    Northeast Region
    09 TRD OR AC
    "Hello, Main Street Auto?"
    :spending:
    Or possibly cut the caliper body off and get after the threaded end with a center punch and progressive drill bits.
  10. Apr 27, 2023 at 11:19 AM
    Chuy
    Lakeside, CA
    Silver Taco
    Dang. I might be tempted to just get new knuckles. The run about $90 for china-made knuckles. I see the pair on Amazon for one fifty. Good luck.
    b_r_o likes this.
  11. Apr 27, 2023 at 11:21 AM
    deanosaurus
    Northeast Region
    09 TRD OR AC
    Yeah, not a terrible idea, but I would probably want to get OEM. The closest dealer stocks them, at least.
  12. Apr 27, 2023 at 11:32 AM
    SR-71A
    Zack
    Southern Maine
    Can you tell where the bolt is stuck? Out near the threads or up by the head? Maybe try more concentrated heat (hotter than propane) and maybe some work with a well placed chisel & hammer
    Chuy likes this.
  13. Apr 27, 2023 at 11:37 AM
    deanosaurus
    Northeast Region
    09 TRD OR AC
    I'm almost certain it's in the knuckle. I've been banging/PB Blasting for a couple days. Gonna make the attempt again in another day or two.
  14. Apr 27, 2023 at 12:17 PM
    SR-71A
    Zack
    Southern Maine
    Im curious to see a pic of what the underside of this truck looks like :D
  15. Apr 27, 2023 at 12:43 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  16. Apr 27, 2023 at 12:44 PM
    deanosaurus
    Northeast Region
    09 TRD OR AC
    The 2nd sarcastic link above leads to a dealer page that lists it in the notes as 29.5mm. I think I can get 30mm easy enough, and I'm just gonna suck it up and get 10.9s because they tend to hold up better here.
    TnShooter[QUOTED] likes this.
  17. Apr 27, 2023 at 12:48 PM
    TnShooter
    Deogee
    STOCK
    I didn’t click the link.
    I just remember seeing that post.
    Toyota uses JIS bolts. Which puts that bolt at about a 7T. I have no idea what that equates to. But 10.9 should be plenty sufficient. :thumbsup:
  18. Apr 27, 2023 at 12:53 PM
    deaps
    deaps Well-Known Member
    2023 TRD OR
    I was a tech for a number of years - I couldn't count the number of brake jobs I have done. I've never broken a caliper bracket bolt...ever. I've had 4 foot breaker bars on them to get them out. I've broken a lot of bolts on purpose too...but never a caliper bracket bolt. I'm not saying it's impossible but I mean you should just apply force until it comes out or breaks. If I were a betting man, I'd bet on it coming out.
    SR-71A and TireFire like this.
  19. Apr 27, 2023 at 1:04 PM
    TnShooter
    Deogee
    STOCK
    Me either. I’ve broken the slide pin bolts on a floating caliper. But never on a fixed caliper. That said, I trust the word of @HAVOC if he says they won’t budge, they probably won’t.
    Personally, I’d do just as you. 6-point and crank on them. Something will break loose eventually. Either way, the caliper has to come off to deal with the situation. I feel for OP, he has my luck. Simple jobs that aren’t so simple.
    SR-71A likes this.
  20. Apr 27, 2023 at 1:06 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    I don’t think it’s gonna break. You just need more leverage. My impact wouldn’t take mine off. I slid a 3’ pipe over a 2’ breaker bar and got em all off no problem.
    SR-71A and super_white like this.
