California Legal Catalytic Converter? (Aftermarket)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OC Duner, May 24, 2016.
  1. May 24, 2016 at 12:44 PM
    OC Duner
    OC Duner [OP] Member
    Hi Everyone,
    I am brand new to the forum, so forgive me if this topic has already been covered. I am limited in time, so I'm just gonna through this out there. I have a 2006, V6 Tacoma, 4.0, 4x4. I need a new catalytic converter to pass California's hideous smog test. I have been looking on line for an aftermarket one as Toyota charges over $2000! The one's I'm coming up with say they are not CA or NY legal. Can anyone direct me in the right direction, hopefully not back to the dealer?
    Thanks in advance!
  2. May 24, 2016 at 10:44 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Sorry to inform you, but as far as I can tell the only "legal" catalytic converters in Californication are dealer OEM catalytic converters.
    It sucks, but there ya go.
  3. May 24, 2016 at 10:49 PM
    Thomas Jefferson
    Thomas Jefferson Keyboard Warrior
    Sacramento,CA
    '13 SR5 DCSB 4x4
    One can never have too many light bars.
    Pick and pulls would be your best bet.
  4. May 24, 2016 at 10:52 PM
    LeftCoastNerd
    LeftCoastNerd Old 'nuff to know betta
    Santa Cruz, California
    08 AC 4x4 OR 6sp
    for my european cars (mercedes, volvos), Magnaflow has replacement cats that meet the Calif. BAR specs. you might see if they have tacoma cats too.
    wow, 10 years is a short time to burn through a cat, I've only ever had to replace them on cars with way over 250000 miles. O2 sensors typically need replacing every 60-100k miles.
  5. May 24, 2016 at 11:05 PM
    Thomas Jefferson
    Sacramento,CA
    '13 SR5 DCSB 4x4
    The cat on my old 05 frontier stopped working at about 80K. Luckily the emissions system warranties last much longer. Not sure if it was bad luck or typical first model year problems.
  6. May 24, 2016 at 11:43 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    From the Magnaflow Web Site:
    2006 Toyota Tacoma Pre Runner V6 4.0L GAS
    0 results
    We're sorry, none of these products fit your vehicle.
    Magnaflow is constantly developing products to exacting vehicle specs. If you'd like to be notified when new parts are available, you can join our Consumer Development Program.
  7. May 24, 2016 at 11:55 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    California sucks for the most part, but some of it's perks help to balance the scales just a tad (i.e. off-road parks and environmental diversity.....shit, that's really about it).
    It's a shame because geographically speaking, California's a very beautiful and uniquely diverse state. But it's politics shit all over that.
    To answer your question OP, I agree with the above poster in that your best bet is to head to your local salvage yard or pick-a-part and see if you can find an OEM cat there.
    NAAC3TACO likes this.
  8. May 25, 2016 at 12:30 AM
    imom
    imom Well-Known Member
    CAL
    2014 Regular Cab
    Have you tried their development program. I was going to help them out, but they are far away from me and they want your truck for a week or more and doing all kinds of dyno testing. It wasn't worth it to me given you giving them your vehicle for a week or more and all you get is a freebie item. The time without a truck and the stress they do with dyno testing day in and out is not worth it for me. I thought they would do some development and they require a test fit and data point for a day. 1 week+ is a lot to ask.
  9. May 25, 2016 at 2:10 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    I spent a few years there back in the early 1970's around San Francisco, Vallejo area. Nice weather and things to do, but the politics just screwed that up. They can keep it.
    eon_blue[QUOTED] likes this.
  10. May 25, 2016 at 9:24 AM
    OC Duner
    My cat actually went out on me over 4 years ago. The last two smog tests, I had my mechanic reset the check engine light, I drove around for 50 miles, the light stayed off and I drove straight to the smog check without turning the engine off and it passed both times. I might try my luck at that again before throwing a bunch of $ at it.
    Thanks for the comments guy's
  11. May 25, 2016 at 9:53 AM
    eon_blue
    Azusa, CA
    Wow, I'm surprised it passed right after having a CEL light...I thought smog stations could tell if a code was recently thrown and it would cause an automatic fail if it was reset without resolving the issue? Anyway if it worked once maybe it'll work again, let us know how it goes
  12. May 25, 2016 at 9:57 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Can't have an active CEL. That's all.
  13. Jun 1, 2016 at 1:36 AM
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    yeah, if your car threw a code that lit the CEL, and you fix the problem (for instance, the classic gas cap leaking vacuum, or there's a bad coil, or temp sensor or whatever), you clear the error, and drive enough to clear the buffers, it will pass. they won't pass it right after you've cleared a CEL, you have to drive it a dozen or two miles so it can record some engine emissions data.
  14. Jun 1, 2016 at 7:05 AM
    OC Duner
    Thanks, I'm trying that tonight. Will let everyone know what happens. Fingers crossed
  15. Jun 1, 2016 at 7:25 AM
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    Many muffler shops will carry CA approved cats for this very reason. I can recommend a really good shop in the bay area if you're from there.
  16. Jun 1, 2016 at 7:29 AM
    OC Duner
    So Cal. Thanks though!
  17. Jun 1, 2016 at 7:33 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I have a magnaflow and it passes smog fine. They don't check numbers or anything. They just see if you have one
  18. Jun 1, 2016 at 7:35 AM
    Revelations
    2014 MGM DCSB
    Go on yelp and find a good local muffler shop. If they don't have any, they can probably point you to a shop that does. I'd be surprised if you could find a shop that didn't carry catalytic converters.
  19. Jun 1, 2016 at 10:40 AM
    weendoggy
    weendoggy Well-Known Member
    Aptos, CA
    2014 TRD ACOR 4x4
    Access Original Tonneau Cover; Toyota Side Tube Steps; Focal ISS690 front speakers; Clarion XC1410 mini amp; Gentex 453 rearview mirror with Homelink, Compass, Temp and Autodim; Prodigy P2 trailer brake controller, Heated Seats from www.cobraheat.com, BriteAss Fogs, Phillips Extreme LED H/L. Heated mirrors from @Up2NoGood. 5100 Bilstein all four corners.
    Depending on your ARB district, it just has to have one and pass emissions and a visual. Also, some ARB districts are just doing OBDII plug in and the computer will tell if all is well. No need to sniff, new to CA testing. Also note: dealers/manufacturers are suppose to warranty smog related equipment for 10yr/100,000mi so you may want to look at that as well.
  20. Jun 1, 2016 at 10:47 AM
    T4RFTMFW
    I thought it was 8 yr/80k miles.
