Caliber won’t compress enough to get the pad in
Discussion in '3rd Gen. Tacomas (2016-2023)' started by My Truck, Mar 17, 2022.
Thread Status:
Not open for further replies.
  1. Mar 17, 2022 at 6:02 PM
    My Truck
    My Truck [OP] Well-Known Member
    Bay Area, CA
    2016 SR DCSB 4x4 Super White`
    Doing a brake job on my Tacoma, first time, and the caliber won’t compress enough to get the pad in. Any suggestions?
  2. Mar 17, 2022 at 6:04 PM
    TacoSupremo19
    TacoSupremo19 Well-Known Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
    Brushed Copper Blaze 10 Rims | 265 70 17 Toyo Open Country A/T III tires | Bilstein 5100 w/ Eibach Coils 2.5" lift | Blackhawk UCAs | ICON Rear 3 AAL |TRD Skid Plate | TRD CAI | OEM Rear Bed Lighting | OEM rear Tailgate lock | RC Bed Molle Racks | Custom Blacked out OEM LED Headlights | MESO V4 Mirror Turnsignals | MESO Interior trim blackout | TG DMM dash mount | TRD Shift Knob | OEM SR5 interior door handles | Upgraded Stereo including Alpine 700W Amp Alpine Type R Components & Hertz speakers 12" Sub | Custom Clazzio Seat covers | Mobtown Sliders | Front Camera
    How are you compressing the pistons?
    Tacospike and shakerhood like this.
  3. Mar 17, 2022 at 6:09 PM
    My Truck
    Bay Area, CA
    Tried everything, channel locks, pry bar, brake caliber tool. It won’t budge. I can push in the other piston to push it out and push it back a little, but then it’s a hard stop
  4. Mar 17, 2022 at 6:13 PM
    My Truck
    Bay Area, CA
    I could really use someone help
  5. Mar 17, 2022 at 6:14 PM
    kent50
    kent50 Well-Known Member
    Kent
    Gold River California
    2017 Tacoma Sport DCSB MGM
    3" Lift XD Wheels 33" K02s Predator Steps TRD Oil Cap Backflip Bed Cover Factory All Weather Mats WeatherTech Bed Mat TRD Pro Shift Knob Vinyl Air Bag Decal Covers Vinyl TRD and Tacoma Inserts Factory Mud Flaps Factory Remote Start Factory Door Sill Protectors Console Organizer and Tray Pro Fogs Grill Mounted LED Light Bar TRD Faux Grill DeBadged TRD Sport Door Emblems Factory Bed Lights Pop Lock Tailgate Lock Rear USB Ports DIY Power Panel
    Make sure that the master cylinder is open. Might be too much brake fluid to compress enough.
  6. Mar 17, 2022 at 6:15 PM
    OmahTako
    OmahTako Well-Known Member
    SoCal
    Tacoma-1ea. Tundra-1ea.
    C-clamp. Works perfect.
    OZ TRD, Otterstuff, FishnTx and 3 others like this.
  7. Mar 17, 2022 at 6:16 PM
    VXEric
    VXEric Well-Known Member
    Eric
    Worcester, PA
    07 ACS V6 6 Spd TRD Sport
    265/70/17 ATs on 17x8"wheels and 0 offset Morimoto XB LED Fogs Reinforced tailgate 2011 Honeycomb grille URD Short Shifter and cue- ball style knob
    Did you loosen the cap on the brake fluid reservoir? If that doesn't help try reassembling with the old pads, hit the brakes to build pressure (move the piston out a bit) and try again with a caliper compressing tool.
    Don't try to move the piston out without reassembling or it will come out too far!
  8. Mar 17, 2022 at 6:17 PM
    TacomaUSA
    TacomaUSA Cross Country Tacoma
    PA
    2007 Tacoma TRD Sport 4x4 Access Cab- 6 speed
    Can you compress the calipers one at a time?
  9. Mar 17, 2022 at 6:22 PM
    OmahTako
    SoCal
    C-CLAMP
    You have to be patient and compress slowly. The top off the master cylinder doesn't matter it's vented.
    Chew, Travlr and Otterstuff like this.
  10. Mar 17, 2022 at 6:27 PM
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    Crack the bleeder and push the piston in with a C-clamp or Channellocks.....
    My Truck[OP] and OmahTako like this.
  11. Mar 17, 2022 at 6:30 PM
    OmahTako
    SoCal
    A welders Vise grip clamp works too.
    Big tall dave likes this.
  12. Mar 17, 2022 at 6:31 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Are you using the old pad as a tool to help compress it?
  13. Mar 17, 2022 at 6:32 PM
    OmahTako
    SoCal
    You don't need that if you have a C clamp
  14. Mar 17, 2022 at 6:34 PM
    My Truck
    Bay Area, CA
    Thank you all. Got it figured out. Just had to crack the bleeder. Love this forum!!
    Big tall dave and skeletron like this.
  15. Mar 17, 2022 at 6:37 PM
    Otterstuff
    Otterstuff Well-Known Member
    2022 White SR5 Access Cab 4WD V-6
    Tube steps, Vision Turbine wheels, bug deflector, seat covers, and tonneau cover
    I have never had a problem using a large C-clamp compressing the pistons against the rotor before removing the caliper. The usual problem is breaking the caliper bolts loose without an impact gun. I usually need a breaker bar.
Thread Status:
