CAD model for front/rear bumper mounts, open source maybe?
Discussion in '1st Gen. Tacomas (1995-2004)' started by mermalady, Feb 26, 2018.
  1. Feb 26, 2018 at 10:12 AM
    mermalady
    mermalady [OP] Well-Known Member
    I've looked a lot for diagrams/schematics for tacoma front/rear bumpers. Ive seen 1 or 2 DIY kits, but no schematics.
    Here's the thing.
    I'm good at CAD. I'm good at design. I'm good at Solidworks and Solidworks:sheet metal extension. I have access to build bumpers myself but I don't have any interest in doing that as a career.
    What I need to do this is have a good, ideally CAD model of the proper mounting points on the tacoma for this model. Distances and locations and angles of those mounts. I imagine most of the ones built are done off of measurements of the truck actual and not off of a CAD model, but I'm thinking *maybe* somewhere out there is a cad model of the truck frame.
    If I could get this I would build the model and make it open source or take donations for the schematics/ paper diagrams. For, you know, the community, or whatever.
  2. Feb 26, 2018 at 10:18 AM
    frenchee
    frenchee Favorite Member
    Oceanside CA Area
    2003 Tacoma TRD Double Cab 4x4
    Converted to 4WD DD VW MK6 TDI
    Once you get the mounting locations you still need to make sure that the top plate will fit. That takes trial and error with cardboard. Hard to take an overall dimension for that. Same with fitting a winch under the bumper.
    I haven't released my bumper yet because someone will end up doing it for money. It's actually all in SW.
    I wouldn't mind writing out the mounting locations. That's also up to interpretation on how you want to mount it although there's not 1000 ways.
    https://twstatic.net/attachments/img_8975-jpg.2509975/
  3. Feb 26, 2018 at 10:37 AM
    mermalady
    I figure if I put it out under CC and then someone builds it and sells it, they're selling their labor and material cost. The margins are pretty slim on that; VS if I sell CAD model or paper models for say, $50, that's way less back breaking labor for me, as much as I like welding.
    frenchee likes this.
  4. Feb 26, 2018 at 10:43 AM
    frenchee
    Oceanside CA Area
    So are you going to have it as an open source or are you selling the models.
    Not sure someone would want to give out the time it took for them to do the work of making sure the bumper fits for someone else to sell their model haha.
  5. Feb 26, 2018 at 10:44 AM
    mermalady
    Open source model, sell paper plans. In my experience people are too lazy to find a large format printer and print something out when they can buy paper plans for $50 or something.
  6. Feb 26, 2018 at 12:23 PM
    lukester78
    lukester78 Well-Known Member
    Luke
    97 Tacoma Single Cab 4x4
    I've been looking for a suitable first gen CAD model to mock up a rear bumper, but haven't had any luck. Mostly pre-Tacomas out there.
  7. Feb 26, 2018 at 1:07 PM
    frenchee
    Oceanside CA Area
    Have you tried making a mock up?
    Rear is easy compared to front. Take off old bumper and take the frame measurement for mounting.
  8. Feb 26, 2018 at 1:13 PM
    Skell
    Skell KORE
    Tony
    NE PA
    2015 DCSB, grey
    custom car grill, KORE sliders, light bar, KORE bed bars w/ tire and high lift mount. MOBTOWN front IFS skid.
    The rear bumper mounting on the second gen threw me for a loop the first rear bumper I fabricated! It's not complicated but the little details are ....tricksy.
  9. Feb 26, 2018 at 1:27 PM
    lukester78
    Luke
    I won't be ready to build for a while, still need to learn to weld and buy equipment etc. But I'll have a garage space to work in starting in March so that might happen at some point.
    Really just want the CAD model to tide me over till then :D
    crashnburn likes this.
  10. Feb 26, 2018 at 1:54 PM
    nemesis17592
    nemesis17592 Well-Known Member
    Nate
    Comstock Park, MI
    2010 Tacoma DC LB SR5 4x4
    Have you ever thought about using a Laser scanner? You can rent them for a couple hundred dollars. You would have decent tolerance results (1-3mm) And you can have models of any truck you please. I use 3d point cloud drawings at work, to create detailed large scale 3D models of production plants. In my opinion, its the most efficient tool for retrofitting.
  11. Feb 26, 2018 at 5:06 PM
    BlackPearl
    BlackPearl Well-Known Member
    Alex
    Toyota Tacoma TRD
    3” lift. Sway a ways 2.5 on 285 75 16 and much more
    Not a CAD but 1st get frame measurements. Hope this helps some.
    Fuergrissa, frenchee and lukester78 like this.
  12. Feb 26, 2018 at 5:14 PM
    Glamisman
    Glamisman Well-Known Member
    The flatland kit I bought was close but not spot on. I had to extend the mounting holes on the side rails about 1/4" to get it to fit right. The real pain in the rear were the large bolts that go into the end of the frame. Lots of elongation there to get it to sit with all of the distances to be the same. I ended up welding a chain on it so that I could use the engine hoist to put it on, take it off, elongate, repeat. No way in hell one man could put the bumper up empty... and the winch and forget it.
  13. Feb 26, 2018 at 6:14 PM
    frenchee
    Oceanside CA Area
    There you go, buy the flatland kit and make whatever you want @mermalady
    You might have had it move when you welded it all @Glamisman
  14. Feb 26, 2018 at 10:16 PM
    frenchee
    Oceanside CA Area
    I have stuff for the back.
    Do you own cad software though?
  15. Feb 26, 2018 at 11:20 PM
    CheFigata
    CheFigata Member
    Victor
    Grass Valley, CA
    2012 TRD Sport,White DCLB
    4.5" RCD Suspension lift: Bilstein 5100 Shocks with Toytec/Eibach Coils, Toytec Add-A-Leaf and U-bolt flip kit in rear, SPC "Light Racing" Upper Control Arms, 34 x 12.5 BFG KO2, 18" Method NV Wheels, SnugTop, AFE Pro Dry intake, Bushwacker Fender Flares
    3D scanners can be great, but not for all applications. For one, they don't like black/dark colored objects. You'd have to paint/color anything dark. Point cloud data (faceted models) aren't very fun to work with either if you don't know what you are doing. All that said, it may be worth a try. I would also recommend 3D printing important interfaces to check you design. My 2 cents.
  16. Feb 27, 2018 at 2:48 AM
    Fuergrissa
    Fuergrissa If you build it, trails will come.
    Devin
    San Jose
    2000 T4R Limited
    cardboard aided designs the way to go.
  17. Feb 27, 2018 at 4:20 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    I'm pretty sure that's not a first gen frame. The file is even called 85 frame...
    This is the diagram for an extended cab frame. It's still not really enough info to work from.
    BlackPearl[QUOTED] likes this.
  18. Feb 27, 2018 at 5:44 AM
    nemesis17592
    Nate
    Comstock Park, MI
  19. Feb 27, 2018 at 7:44 AM
    lukester78
    Luke
    Have access to Solidworks through work.
    This is exactly my plan.
  20. Mar 26, 2019 at 7:14 PM
    Heyst
    Heyst Active Member
    This Guy
    '13 Taco SR5
    Not to kick a dead horse here but how are we doing on this front? I'm yea close *pinches a cunthair width of air* to surveying the bumpers plan view and then section/details of bumper mounts. Just waiting on snow to melt.
