Cabin and Engine air Filter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JohnWJ, Sep 10, 2022.
  1. Sep 10, 2022 at 10:33 AM
    JohnWJ
    JohnWJ [OP] Well-Known Member
    New Mexico
    2013 Dark Grey 4x4 access cab
    Goo Morning Everyone
    Quick question what brands of filter do you recommend something that will not require me to sell a kidney LOL
    davidstacoma likes this.
  2. Sep 10, 2022 at 10:34 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Wix for engine, K&N cleanable for cabin.
    Do not put a K&N oiled filter in your engine.
  3. Sep 10, 2022 at 10:34 AM
    JohnWJ
    New Mexico
    Thank you
  4. Sep 10, 2022 at 1:24 PM
    huyner
    huyner CoCKaSiAn
    Huy
    Orlando
    2007 Tacoma TRD Prerunner Sport 4x4
    a lotta money spent, lotta scars made
    i just got the k&n cabin air filter with the 20% off at advance...a lil bit more then the regular one, but reusable...so no more buying. i went with a afe dry filter for my trd intake
    JohnWJ[OP] likes this.
  5. Sep 10, 2022 at 1:27 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I use Wix for both.
  6. Sep 10, 2022 at 1:29 PM
    Ponch1776
    Ponch1776 Well-Known Member
    Jay
    Sacramento
    2017 Quicksand Tacoma TRD OR
    What is the issue with the K&N oiled filter?
  7. Sep 10, 2022 at 4:37 PM
    SWPA Tacoma
    SWPA Tacoma Well-Known Member
    Stevo
    2006 White Tacoma DCLB
    If you incorrectly clean and over-oil, it can effect your MAF and/or O2 sensors. I ran one for about 90 thousand miles with no issue. When I cleaned and oiled it for the 3rd time, since I was no longer towing, I sealed it in plastic and put it back on the shelf in my garage. I now use the Wix. I really dont see much difference.
  8. Sep 10, 2022 at 4:44 PM
    Key-Rei
    Key
    Florida
    For a cabin filter it doesn't matter as much and they use a different wetting agent that's safe for breathing.
    However...
    For the Engine air filter; the oil that's used to pull some of the contaminants out of the passing the air (as the filter media itself is just 5 layers of cheese cloth you can see day light straight through the pin holes all over it where the holes line up which is it's own issue) but the oil wicks off the cheese cloth and is carried by the air surge past the very hot fine wire Mass Air Flow Sensor or MAF, where the oil almost instantly burns and turns to caked on carbon deposits on the fine wire which can itself become exothermic and break the wire destroying the rather expensive ($170) MAF or it can just accumulate on the wire used to measure oxygen content in the incoming air and greatly throw off the accuracy of the reading resulting in poor performance, poor mileage, poor response, and increased heat and wear on the engine.
    The MAF is possibly the most critical single component in your engine's management, screwing with it's accuracy albeit accidentally, (or incidentally) by having an oiled K&N filter depositing oil onto it is not a good thing.
    Yes they flow more air, but so would a screen door which is effectively all it does so it flows more grit too, directly into your engine damaging your management system in the process.
    But K&N only has to make their 5hp claims! (Which have been independently bunked) and sell filters, the rest is on you. Many claim they can feel the difference (but for the butt dyno to truly notice an improvement 10% power increase is required and 5hp is not 10%) but that's largely due to going from a clogged old filter to a new filter, not the K&N specifically, I wager the same improvement vould be felt by a new WIX or OE paper filter.
    Even if there was an improvement it will slowly drop off as the MAF dirtys up and it will happen so slow you'll not notice the issue till the Check Engine Light comes on for P0171 MAF code.
    Yes they run K&N oiled filters in desert race trucks which is a huge claim of theirs, sounds great, except a desert truck only has to work for a day before the huge company behind it does a full million dollar rebuild.
    Can you afford a monthly replacement of your MAF and an engine rebuild every 30k miles?
    If you can fantastic, you're doing better than I, but either way I'd avoid a K&N engine air filter like the plague.
    -Former K&N air filter user.
    God I wish this was a sticky, it's going to be a copyposta of mine now though.
    /End rant.
  9. Sep 10, 2022 at 4:50 PM
    JohnWJ
    New Mexico
  10. Sep 10, 2022 at 5:34 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Auto stores are all about $20+ each for any brand.
    Have used many Fram, Puralator, and Carquest (Advance) and all OK
    Cabin I use cheap plain type as the fancy carbon ones got clogged faster and mess up the AC flow into the cabin.
    Last time I got the Walmart Super Tech ones about $10-13 each even American made.
  11. Sep 10, 2022 at 5:38 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    I use a afe dry cleanable air filter for the engine and cabin air filter i dont care what ever is in stock
  12. Sep 10, 2022 at 6:05 PM
    JohnWJ
    New Mexico
    Awesome thanks
  13. Sep 10, 2022 at 6:07 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    For the cabin air filter, use the cheapest piece of crap you can find. I had one of those activated charcoal, fancy schmancy ones for a couple of years and the main thing it manages to do, is restrict your air flow.
    You just want to keep crap out of your blower motor.
    This is just my opinion, but it's a good one.
    SR-71A and JohnWJ[OP] like this.
  14. Sep 10, 2022 at 6:08 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Anything in the 20-30$ range. Don't overthink it, it's just paper
    goforbroke123 and JohnWJ[OP] like this.
  15. Sep 10, 2022 at 6:10 PM
    tcjacado
    tcjacado Well-Known Member
    I usually just put a couple of dryer sheets on top of the cabin air filter. My truck smells like fresh laundry.
    hoffengineering and JohnWJ[OP] like this.
  16. Sep 10, 2022 at 8:52 PM
    Nordberge
    Nordberge Well-Known Member
    2011 TRD Off-Road PreRunner
    I like the Bosch cabin and intake air filters.
  17. Sep 12, 2022 at 1:45 AM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    I use OEM for the engine you can find them on Amazon pretty responsible and the cabin i go with breeze brand also cheap
    Genuine Toyota Air Filter Tacoma 2005-2008 4.0L V6 Genuine Toyota OEM New https://www.amazon.com/dp/B004C63ERO
    FRAM Fresh Breeze Cabin Air Filter with Arm & Hammer Baking Soda, CF10374 for Dodge/Toyota Vehicles https://www.amazon.com/dp/B001CEJH0W
    Kolter45 and O'DubhGhaill like this.
  18. Sep 12, 2022 at 1:06 PM
    c212
    c212 Well-Known Member
    I can tell you which brand I'll never buy again: Denso. It was sized about 1 mm too large for the airbox cover to go back on. Yes, I did double-check it was the correct part. Next time I'm at Auto Zone I'll just grab whatever generic they have.
  19. Sep 12, 2022 at 3:52 PM
    JohnWJ
    New Mexico
    Thanks everyone
  20. Sep 12, 2022 at 9:21 PM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Toyota air filter, cheap TYC cabin filters from Rock Auto (although the '05s didn't even come with cabin filters installed). I get enough pine stray and pine pollen in them that it's not worth spending more, especially when I have the windows down when possible anyways.
