Cabin air filter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Steadfast, Mar 31, 2020.
  1. Mar 31, 2020 at 1:29 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    WALMART SuperTech 7250
  2. Mar 31, 2020 at 1:35 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    7 year old air filter? Must be a record.
  3. Mar 31, 2020 at 4:02 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    “It’s not the years, it’s the miles.”
    Plain Jane Taco likes this.
  4. Mar 31, 2020 at 4:09 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    IIRC most 05's didn't come with filters but the slot for one is there.
  5. Mar 31, 2020 at 4:26 PM
    Shaggs
    Shaggs Well-Known Member
    NorCal
    2012 DoubleCab Long Bed 4x4 TRD Magnetic Gray
    I got a carbon activated one with arm and hammer baking soda as well... nice for $10 on Amazon
  6. Apr 1, 2020 at 4:52 AM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    Clean? Do not clean it. Replace it. You can never fully clean it.
    TRDSport10 likes this.
  7. Apr 1, 2020 at 4:54 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    You got it wrong :smack:
    "It's not the age, it's the mileage".
    Now go back and watch Raider of the Lost Ark right now. :D
  8. Apr 1, 2020 at 5:12 AM
    Steadfast
    Steadfast [OP] Well-Known Member
    Thane
    S.W. Ontario Canada
    2013 Limited
    I bought the truck used in 2016 after test driving the new 16s. It had 65,000 km (42,000 mi) on it then. I bought it from the dealership but not sure if it was replaced or not. Until I go to town to get a new one, I at least cleaned it for now. Moving forward, I will replace it every year.
  9. Apr 1, 2020 at 5:58 AM
    wags
    wags Well-Known Member
    Walleye Capital of the World, Ohio
    2012 2.7L 5-Speed Manual SR5 4x4
    So many choices for Toyota or any other vehicle manufacturer cabin air filters for that matter! Denso makes for Toyota OEM (original equipment manufacture) cabin filters. About $27-$35 from a dealership. Rockauto sells Denso OE (original equipment) for $4.19ea. Hard to tell the difference from OEM, really. But yes, pick any brand ie. Toyota OEM, Denso, Wix, Fram, Supertech, etc..... I check mine every 5,000mi servicing and change once a year.
    https://www.rockauto.com/en/catalog...heat+&+air+conditioning,cabin+air+filter,6832
    TRDSport10 and Steadfast[OP] like this.
  10. Apr 1, 2020 at 8:51 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    “Yours is the superior intellect.”
  11. Apr 3, 2020 at 6:57 AM
    Plain Jane Taco
    USA
    Yeah....it's a gift
    bagleboy[QUOTED] likes this.
  12. Apr 3, 2020 at 7:57 AM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    Dealer removed my re-usable cabin filter and replaced it with the factory POS - after I told the dufus " service advisor" to leave it alone. Didn't find out until the next cleaning interval.
  13. Apr 3, 2020 at 8:03 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    pfft mine looked like it was original when I replaced it last year
  14. Apr 3, 2020 at 8:15 AM
    mray
    mray Well-Known Member
    Colorado
    2011 4cyl Base Access Cab 4x4
  15. Apr 3, 2020 at 8:17 AM
    #35
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    I belly-laughed when I read that...thank you!
  16. Apr 3, 2020 at 12:28 PM
    #36
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    They didn't have a filter installed but the housing is the same as later years. Just pop the door open and slid one in. The POS plastic nubs that hold the glove box door damper will fail over time though.
    On the rare occasions that I order something from Rock Auto I add a couple of the inexpensive TYC filters to my order and just change them out either at oil changes or when needed- I'm waiting on the pine pollen to quit dropping right now then I'll change it.
  17. Apr 3, 2020 at 12:28 PM
    #37
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
    Contrary to popular belief the OEM filter can be cleaned once or twice before it becomes too nasty. Spring and fall are the worst times for contamination to occur and because it’s easy to service I look at the filter about 4 time’s a year. Depending on where you live and if you park under trees you might be cleaning more often. If you are looking at it that often you can remove light debris like leaves and pollen before it becomes imbedded. It also helps if you have compressed air to blow out and here’s where skill and common sense becomes necessary. Blow hard enough to clean but don’t blow holes in the filter.
    Here’s another trick I do because of allergies. When you got it all clean spray that filter with Lysol, common sense again enough to dampen but not soaking wet then reinstall. You can also feed Lysol directly into air intake cowl to kill mold and viruses and get rid of funk smells. Turn to recirc and give that a shot too. Now it smells better and your allergies might be better controlled not having to breath the crap in the vent and filter. Try it
    buy the filters online to save, usually OEM can be had for less than 20 bucks. The chinese and off brand filters are cheaper for a reason. The fit is iffy and construction is too.
    JLTIMM likes this.
  18. Apr 3, 2020 at 12:43 PM
    #38
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    I tend to open the windows so having the Rolls Royce of cabin filters seems to be a waste of money so unless there's a window air filter I can add to my order, the TYC ones work for me. I need the money to pay for the crush washers when I do an oil change. :cheers:
  19. Apr 3, 2020 at 1:35 PM
    #39
    jon_elc
    jon_elc Well-Known Member
    NorCal
    2011 SR5 4x4 Timberland Mica Snugtop Rebel
    245-70R-17 Revo3 Cut mudflaps 4.5" F / 1.5" R
    i need to change mine
  20. Apr 3, 2020 at 6:27 PM
    #40
    Gen2 Man
    Midwest
    07 Sport DCLB
    yes sir
