Cabin air filter...arrow up or down?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by IEsurfer, Sep 24, 2019.
  1. Sep 24, 2019 at 12:48 PM
    IEsurfer
    IEsurfer [OP] Well-Known Member
    Socal
    Dumb question, I replaced my Cabin air filter (oem) and the arrow points up saying to install that way but on YouTube a lot of guys are saying that's incorrect and arrow should be pointing down...so which is it lol
  2. Sep 24, 2019 at 12:50 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Pull your filter out, turn the system on and feel which way the air is moving.
    Anton338 and 20tacoma17 like this.
  3. Sep 24, 2019 at 12:54 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    so you took it out and the arrow was up, well then theres your answer. Or you could trust youtube joeys
    SR-71A likes this.
  4. Sep 24, 2019 at 1:02 PM
    mlr69
    mlr69 I had a savings account before I joined TW
    South Carolina
    2018 TRD Sport 4x4 DCSB
    2" ToyTec/Eibach Pro Sport Lift Kit -SparksParts.com 3/4" ToyTec Front Top Plate Spacer Kit -SparksParts.com SPC Performance Upper Control Arms -SparksParts.com Nitto Ridge Grapplers 285/75/17 (34") -SparksParts.com 1.25" Spidertrax Wheel Spacers -SparksParts.com Hypertech Speedometer Calibrator -hypertech.com Predator Tube Steps -SparksParts.com BAKFlip G2 Tonneau -SparksParts.com OEM Rubber Bed Mat -SparksParts.com OEM All-weather Floor Liners -SparksParts.com Gentex Frameless Mirror with Homelink @RJP869 Subaru/Kicker Tweeters -amazon.com Kicker Door Speakers (x4) -crutchfield.com Radio Knobs @Tacowiede Vehicle OCD Glove Box Organizer -amazon.com ‎JoyTutus Center Console Tray -amazon.com FormulaOne Pinnacle Window Tint -SparksParts.com ACDF Horn Kit @BartMaster1234 Total Tail Light S1 Kit @MESO ECT Button Relocation Kit @Tacowiede Minimalist Key Fobs @MESO Ultimate Map & Dome Lights @MESO Fortin EVO-ALL Remote Start w/Cell Module @jmeitz Coin Bucket with Lid @MESO GermesLab Camera Control System @FreshMexicanTaco Natika Front View Camera -amazon.com VLEDS LP Reverse Light System -vleds.com LIFTd Customs Fuel Cap Cradle @JIMMEISTER OEM Power Tailgate Lock -SparksParts.com OEM 2022 Limited Grille -SparksParts.com OEM 2022 Limited LED Headlamps -SparksParts.com LED Headlight Conversion Harness @daveeasa Headlight Trim Plates @MESO OEM Door Sill Protectors -SparksParts.com Diode Dynamics Elite Fog Lights @memario1214 Fog Light Backlighting PNP Harness @daveeasa TacomaTime Dash Cubby Drawer -etsy.com FPE Fogs + High-Beam Module @memario1214
  5. Sep 24, 2019 at 1:13 PM
    TacoTruck808
    TacoTruck808 Well-Known Member
    Oahu in the Aloha State!
    2016 Tacoma TRD Sport DCSB, Prem & Tech Pkg, MGM
    It seems like it all depends on what is printed on the filter. If OEM or Aftermarket. If it says like the OEM pic above this side up, then it should be up but if it says airflow with the arrow, like a Aftermarket one then it should be pointed down??? The outside air intake is above the airfilter box and the air pulls downward toward the blower motor fan. At least this is how i have it. I have sprayed Lysol directly into the air filter area and the spray goes downward. It may be a bit confusing........i need to check this out again.
    Gunshot-6A likes this.
  6. Sep 24, 2019 at 1:15 PM
    HyTrojan
    HyTrojan Well-Known Member
    Jared
    South Louisiana
    2020 MGM Sport AT DCSB
    Nfab running boards, PapaRee Tune, T4R Pro SEMA rims
    The arrow is signifying installation orientation, not airflow direction.
  7. Sep 24, 2019 at 1:17 PM
    ICU1
    ICU1 Well-Known Member
    When all else fails...
  8. Sep 24, 2019 at 1:19 PM
    TacoTruck808
    I have to check but if i remember correctly, my filter said airflow direction. Or shit, i have been putting it in wrong all this time!
  9. Sep 24, 2019 at 1:24 PM
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
  10. Sep 24, 2019 at 1:28 PM
    Trucknorris
    Trucknorris Well-Known Member
    2017 sr5 double cab 4x4
    Several
  11. Sep 24, 2019 at 1:44 PM
    bludweiaer
    pa
  12. Sep 24, 2019 at 1:46 PM
    TacoTruck808
  13. Sep 24, 2019 at 1:49 PM
    mlr69
    South Carolina
    For a cabin air filter, does it really make that much of a difference?
    As long as you're not taking a dirty one out, flipping it over and putting it back in, i don't think there will be a problem. It's going to catch leaves, dirt, dust, etc, regardless of which way it's put in.
  14. Sep 24, 2019 at 1:51 PM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    Air flows down. Wouldn’t make much sense to have dirt falling off the bottom instead of sitting on the top where you can remove it .
  15. Sep 24, 2019 at 1:58 PM
    Ulfr
    Ulfr Well-Known Member
    Tampa, FL
    2019 DCSB 4x4 Manual
    Knowing Toyota they will probably say some bullshit about you not putting the cabin filter in correctly so they can't warranty your blown engine from low oil pressure due to diesel being put into the blinker fluid tank computer exhaust gas manifold.
    igno1tus, JonBoy13, Austinguy and 3 others like this.
  16. Nov 18, 2019 at 10:01 AM
    Slats1
    Slats1 Member
    Kentucky
    2014 Tacoma Prerunner 2x4
    None Yet...
    I think RUPP1 has the answer. It is confusing. I better turn the fan on with the filter out and see for sure.
    Too many after market filters with bogus info. I got a FramFreshbreeze and it says down and all my vents are above the blower motor.
    The old one I took out pointed up. Good Luck folks.
  17. Nov 18, 2019 at 10:19 AM
    Admiral_Akbar
    Admiral_Akbar Well-Known Member
    '17
    Are you applying that same common sense knowledge to the engine air filter too?
  18. Nov 18, 2019 at 10:29 AM
    Slats1
    Slats1 Member
    Kentucky
    None Yet...
    Just checked and air flow is down on 2014 Tacoma and 2015 RAV4. It probably doesn't matter, both sides of the filter
    look the same.
  19. Nov 18, 2019 at 10:33 AM
    madsand
    madsand wanderer
    sandz
    Costa Mesa, CA
    2012 DBLCB LB sports 4x4 SC
    Icon 2.5" Remote Reservoir Extended Travel CDCV Icon tubular UCA Icon add a leaf Method NV wheels Nitto trail grappler MT 285/70/17 Weather Tech floor mat All Pro rock slider
    its down, and does matter coz one side of filter is darker compare. I used fram freezebreze filter
  20. Nov 18, 2019 at 10:33 AM
    Slats1
    Slats1 Member
    Kentucky
    None Yet...
    Good question Akbar,,,I'd say Yes, dirts on top side,plus my air filters would only fit one way with the gaskets.
