Cab rust - Options.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BluberryBCtaco, Aug 8, 2023.
  1. Aug 8, 2023 at 3:58 PM
    BluberryBCtaco
    BluberryBCtaco [OP] Making the magic happen
    BC Canada
    2007 Tacoma Sport DCLB
    3in lift, Tow package, Any time 400w inverter, in cab outlet, vinyl floor, roof rack
    Rust has taken a hold of the cab.
    Seems to be the only aggravated spot. (Yes I inspect and clean the undercarriage once every 2 months)
    I did the tap a screw driver to see if it’s truly damaged test.
    What is my options?
    What is the cab made out of?
    Cut a rectangle and weld a piece of sheet steel to it?
  2. Aug 8, 2023 at 4:09 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Your cab - and most of the rest of the truck - is made of steel. Your options depend on how much you want to spend and how complete of a job you want to do. I can tell you (based on a lifetime living in the salt belt) that what you are seeing is the tip of the iceberg. That rust is coming from the inside and there is much more than just hasn't popped through yet. To truly fix it means cutting all of the rusted sections out and replacing them with new metal, then properly prepping, priming and painting the outside surface as well as rustproofing the uncoated inside. Hint: It isn't going to be cheap to do it right.
    If you have that kind of rust on your cab, personally, I'd be much more interested in what you frame looks like. After all, the frame is a much more common area of corrosion than the cab.
  3. Aug 8, 2023 at 4:17 PM
    Chromag
    Chromag Member
    Joe
    06 dc 4x4 base
    Intermittent wipers
    I am interested in a proper and or cheap fix. Newish frame on my 07 but rockers are gone. Cab corners too.20230808_191503.jpg
  4. Aug 8, 2023 at 4:28 PM
    Too Stroked
    Tom
    No such thing as "proper and cheap" for that kind of rust issue. You can have one or the other, but not both.
    vtown, SR-71A and shmn like this.
  5. Aug 8, 2023 at 4:32 PM
    Steves55
    Steves55 Well-Known Member
    Palm Desert, Ca
    2023 TRD Off Road
    Welder, wrecking yard & cut off wheel.
    91859706, ARCHIVE and racerX969 like this.
  6. Aug 8, 2023 at 7:15 PM
    BluberryBCtaco
    BC Canada
    Please elaborate, “coming from the inside”. The spot on the photo is above the driver seat area.
    Is there a drain hole or something in this area?
    The frame is in good, it got replaced a ways back, not even the rear axel has any rust. I’ll share photos later.
  7. Aug 8, 2023 at 7:15 PM
    BluberryBCtaco
    BC Canada
    That’s gnarly
  8. Aug 9, 2023 at 4:28 AM
    Too Stroked
    Tom
    Generally speaking, rust in the automotive world comes in two forms. First - and easier to repair - is surface rust. This is corrosion that starts on the outer surface of the base metal. (And yes, this can start under the paint.) Simply sanding off the paint, primer and corrosion, then properly treating the surface, priming and painting will take care of the problem.
    What you have is corrosion starting on the back / inside of the surface. This takes longer to show up because the corrosion needs to eat through most of the base metal before it shows any symptoms on the outside. This is also why it is so much harder to repair properly. There's almost always way more corrosion than you see on the outside - which leads to a much more expensive repair.
  9. Aug 9, 2023 at 6:46 AM
    Waasheem
    Waasheem
    2007 xrunner
    Pick 2.
  10. Aug 9, 2023 at 8:22 AM
    BluberryBCtaco
    BC Canada
    There is a forth option you are not seeing. That’s is Cheap, fast, and good.
  11. Aug 9, 2023 at 8:58 AM
    ARCHIVE
    ARCHIVE Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    Search for replacement rocker panels if available. It will be time consuming. Then spray inside cavity after replacement with Fluid Film etc
    And get your frame oil coated, especially inside the channels where there are sandwiched steel
    SR-71A likes this.
  12. Aug 9, 2023 at 10:05 AM
    Waasheem
    Waasheem
    2007 xrunner
    Thats how people who pay to get it done think. Those who get paid to do it think differently.
    SWPA Tacoma likes this.
  13. Aug 9, 2023 at 1:10 PM
    EL DUDE
    EL DUDE Well-Known Member
    Have never seen a 2nd gen with rust other than the frame
    RedWings44 likes this.
  14. Aug 9, 2023 at 1:26 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
  15. Aug 9, 2023 at 1:31 PM
    BluberryBCtaco
    BC Canada
    Finally stopped raining today.
    Here is her undercarriage photos.
    Other than the fine silt (beige colour).
  16. Aug 9, 2023 at 1:32 PM
    BluberryBCtaco
    BC Canada
    Well, this one is an oddity the frame was replaced by the prev owner at some point of its life.
    As you can tell from the top right of this photo this seems to be the only aged spot.
  17. Aug 9, 2023 at 1:35 PM
    BluberryBCtaco
    BC Canada
    Yes I think I have an idea, of what MAY be causing it.
    I want to take a snake camera and figure out if that hole corresponds with a hole in the left most foot well on the driver side.
    I recently plugged a hole there.
  18. Aug 9, 2023 at 1:51 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Drill the hole out so it's round.
    Spray the inside with cosmoline.
    Plug the hole with a plastic plug (similar to those existing plugs in the area but larger)
    Install some long mudflaps so road spray no longer pummels the area.
    This should get you by another 5 years or so.
    91859706 likes this.
  19. Aug 9, 2023 at 2:43 PM
    Too Stroked
    Tom
    The frame actually looks pretty darn good! The pinch weld on the driver side rear looks pretty well deformed where the tube step rear mount is bolted on. (The tube step mount looks pretty well crumpled too.) Crumpling sheet metal will damage the paint and allow corrosion to start.
  20. Aug 9, 2023 at 2:49 PM
    BluberryBCtaco
    BC Canada
    Thanks! Yes I suspect the prev owner hit something on the side step…. Then me….. hitting a tree stump….
    Didn’t notice that pinch weld.
    (I do plan on treating the frame and cab, but for now she gets power washed, then soapy water with a rag, and about 4 cans of LPS3 from work im “borrowing.”)
